Old 11-15-2005, 11:45 PM   #1
ScubyMedic
Member#: 98203
2005 Spaceship/03WRX
both WRB
Default Ahhhhh Chk Engine Light!!!!
Lol ok heres the deal;
2002 2.5RS with a 04 STI body conversion
Has salvage title, and was in very very light accedent. ( When i got it, the bumper and lights were still undamaged. only hood and fenders damaged.)
52,000 miles on it, and its my baby.
I have been building it so it can pass NYS Salvage Inspection but ive ran into a problem... The check engine light comes on.
I have some friends who have connections. I had the car takin to a guy who did a diagnostic test on the car. The reading came up as "Unknown Reason" . Now this to me is a problem, how can i fix it, if i cant even find out what i need?!....
Now everyone tells me not to panic , but i cant help it, almost 10 months into the project and now i got another opstical. So can someone help me out....
Help me out, Please!!!!!
~Drew
ScubyMedic is offline   Reply With Quote
Old 11-16-2005, 12:07 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
maybe get a better code reader...
the local dealership might even help you out if you ask them nicely.
Old 11-16-2005, 09:55 AM   #3
ScubyMedic
Member#: 98203
both WRB
bump^
Old 11-16-2005, 02:14 PM   #4
ScubyMedic
Member#: 98203
both WRB
hmm, i still need help...........
Old 11-22-2005, 05:54 AM   #5
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
If you take it to a Shuck's Auto Supply, or something like it in your neck of the woods, the should hook it up for free to a diagnostics comp. That's what they do in WA anyways. They even provided a free print out of what the code was and what the reasons behind the codes are.
Good Luck
JNUTZ is offline   Reply With Quote
Old 11-22-2005, 11:09 AM   #6
ScubyMedic
Member#: 98203
both WRB
Ok i just got it checked out today, and its the Oxy Sensor. Heres my problem, i found one for a 2003 WRX, will this fit my car? Also, how come i keep hearing about different oxy sensors? Is there more then one, how do i kno which one to get?
Thanks
Andrew
Old 11-22-2005, 11:31 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What was the exact code that was stored, in Pxxxx format? You may not actually have a bad 02 sensor, it is very important to follow the proper troubleshooting procedure for that specific code before blindly replacing parts that may be good.
If you are referring to the front 02 sensor, one from a WRX will NOT fit your RS.
Old 11-22-2005, 07:58 PM   #8
ScubyMedic
Member#: 98203
both WRB
Im not exactly sure which code it was, mainly because my father and brother took the car while i was in class. I came back and all they told me was that it was the o2 sensor. The one that i have from a 03 Rex is a front sensor, so im still unclear which is which on my car. Im a total moron when it comes to simple stuff Can someone tell me what is the front, and wat is (what im assuming) the back. Lol
Thanks
Andrew
Old 11-22-2005, 08:02 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Forget about using that front 02 sensor from a WRX, it won't work.
You still need to know what the code was. If it hasn't been cleared yet the code will still be in the ECU memory so it could be read out again.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 04:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 01:47 PM
ETS dp and custom 3.25" 'trust' exh= chk engine light ohforesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-18-2006 11:13 AM
2.5L chk engine light - boiling coolant - bad? stajerker Normally Aspirated Powertrain 8 05-17-2004 01:46 AM
insalled blitz sbcIII chk eng light on sikey64 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-15-2003 12:43 PM
