Old 11-15-2005, 11:37 PM   #1
crusher145
Member#: 93512
2004 STi
Default So my friend blew up his WRX
Well, my friend took his 2004 WRX to the track on Sunday. The car has STi pinks, STi TMIC, 3" turbo back, perrin short ram, and a UTEC. At the end of his third pass, he said he was shifting into fourth and and the car "dove" when he let in the clutch. He put the clutch back in, shifted into 5th, and drove back to the staging area. A short while later he started his car to make another pass and the car was making a clunking noise inside the engine on the passenger side while idling. When it was turned off, the engine continued clunking while it was winding down. It clunked 3 or 4 times after the ignition was killed. We called a tow truck, and the car is currently sitting in my driveway.
From what I can tell, the reason the car "dove" is because he shifted into second and not fourth at 90 mph, redlining the engine.
Any ideas on what could have broken inside the engine?
crusher145 is offline   Reply With Quote
Old 11-15-2005, 11:39 PM   #2
2ndGearFling
Member#: 64466
05, STI on green
Built in electronic rev limiter.....I hit it every day leaving my place.
2ndGearFling is offline   Reply With Quote
Old 11-15-2005, 11:42 PM   #3
JRSCCivic98
Member#: 67080
Probably everything. If he did shift into 2nd instead of 4th after redlining 3rd then he basically overspun the entire engine assembly. Did he say if he noticed the rpm needle just rocket up after the shift to 4th or if he really did indeed put it into 4th and the engine just blew?
JRSCCivic98 is offline   Reply With Quote
Old 11-15-2005, 11:46 PM   #4
JRSCCivic98
Member#: 67080
Umm, ya... the electronic revlimiter isn't going to save you from overreving the engine by shifting into a lower gear then the current one after redlining the current gear.
Old 11-15-2005, 11:47 PM   #5
Docsuby
Member#: 88598
03 impreza wrx
blue
OOOO! Can't Find em.......
Docsuby is offline   Reply With Quote
Old 11-16-2005, 12:32 AM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Yea if the car went into a dive he probably missed a gear and sank the needle in the tach.
cdvma is offline   Reply With Quote
Old 11-16-2005, 12:44 AM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
clunk, rod bearing
mick_the_ginge is offline   Reply With Quote
Old 11-16-2005, 04:33 AM   #8
ncarn8
Member#: 71419
could be bearing or busted rod as well but not necessarily. REv limiter wont do crap whn rolling and the road speed is barrelling up the gearbox and getting reverse multiplied so your engine goes mental. In my 2wd its easier to get away with as overrevving from average changes most times itll just compression lockup but in 4wd the wheels aint gonna slide so something will go bang. BANGBANGBANG.
ONly one way your friends going to find out whats broken. ooh the anticipation.
I hate breaking stuff now.
ncarn8 is offline   Reply With Quote
Old 11-16-2005, 04:40 AM   #9
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
From what you are saying about 'side of the engine etc...
I would say if it has indeed had a big gutfull of revs that the cambelt may have spun a tooth or 6 and that may be the clunking. Failing that I would say you have spun a bearing or worse. I have seen a EJ20E spin to 9800rpm on a 'driver error'!! spun the cambelt a few teeth and bent 4 valves, other than that-FINE! I fitted later model cambelt covers with the belt guides and never had another problem!
Cheers
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 11-16-2005, 09:07 AM   #10
crusher145
Member#: 93512
2004 STi
The engine is coming out Thursday. What really concerned me was the fact the engine continued to make the noise after it was shut down. I am hoping for something minor like a rod or main bearing, but I am beginning to think something is screwed up in the head as well. I imagine the noise would have stopped after the engine was shut down if it was a rod bearing or something related to the piston ring.
I am reluctant to start the engine again, so the car needs to be pushed uphill into my garage, which is going to be loads of fun. Now I am going to have two dead '04 subies in my garage
Anybody have any suggestions on a reliable shop to send the engine to to be rebuilt?
Old 11-16-2005, 09:27 AM   #11
lowblow
Member#: 56902
2009 VW Jetta SE
Don't rebuild the EJ205...get an EJ207 in its place
lowblow is offline   Reply With Quote
Old 11-16-2005, 09:42 AM   #12
crusher145
Member#: 93512
2004 STi
Hmmm, I am doing some research and the ej207 doesn't sound like a bad idea. He needs to sell his UTEC, TMIC, Pinks, etc. and do the full swap. His car should be faster in the end anyway.....
Too bad he doesn't have a working ej205 to sell to help make up some of the cost.
Old 11-16-2005, 02:07 PM   #13
jamesfacts
Member#: 51282
98 RS
black & blue from parking
How much does he want for the dead 205?
jamesfacts is offline   Reply With Quote
Old 11-16-2005, 02:50 PM   #14
wizzman
Member#: 84405
2007 V8 4Runner
1994 flaming red Miata
intake and pinks on a stock turbo?
wizzman is offline   Reply With Quote
Old 11-16-2005, 02:52 PM   #15
b00st3d
Member#: 9891
2015 RC-F
Ultra White
miss shift usually bends valves doesnt it?
b00st3d is offline   Reply With Quote
Old 11-16-2005, 03:41 PM   #16
crusher145
Member#: 93512
2004 STi
How much would you pay for a dead 205? Make me a reasonable offer.
Old 11-16-2005, 04:43 PM   #17
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
And the problem is???
Old 11-16-2005, 07:55 PM   #18
crusher145
Member#: 93512
2004 STi
I was wondering the same thing....
Old 11-22-2005, 01:12 PM   #19
USF97J4x4
Member#: 83035
ive heard 04's are prone to spinning bearings
Seems like they cant take the abuse the earlier models can
USF97J4x4 is offline   Reply With Quote
Old 11-22-2005, 01:49 PM   #20
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
rod knock or piston slap?? Clunk Clunk... Car dove cause you just lost power in one cylinder. That ones not creating power anymore. Its like your car turning from a 300hp machine to a 200 hp machine in one shift. The numbers are exagerated and not exact by all means, just to illustrate an example. He blew his engine at the end of third.
I say UTEC was the problem.
darksands is offline   Reply With Quote
Old 11-22-2005, 01:55 PM   #21
DLBWRXR
Member#: 98036
i did that a month ago, was racing a 911 turbo and went from 3rd to second got the clutch half way out and rev's shot up to 8,000. with a flywheel grinding noise. (like when you turn the key in a car thats running) no damage, im just lucky i caught my mistake before the big bang. KABOOOOOOM
DLBWRXR is offline   Reply With Quote
Old 11-22-2005, 02:22 PM   #22
x99percent
Member#: 27108
2004 STi
2004 A4
You heard it here first! The UTEC makes you misshift!
x99percent is offline   Reply With Quote
Old 11-22-2005, 02:35 PM   #23
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
assuming the following is true...
I'd put my money on the mis-shift being the cause for the clunking.
sucks, but do the v7. and you could get rid of that motor quickly
SBW is offline   Reply With Quote
Old 11-22-2005, 03:07 PM   #24
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
OK, so help me here, in the OP, you said it was a friend's car yet in this quote you are speaking of it in the possessive, as though it was actually YOUR CAR.
Acostafan is offline   Reply With Quote
Old 11-22-2005, 06:16 PM   #25
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Utec problem being a bad tune. Now, when he shifted into fourth, did his RPM's shoot up? It wasnt said so I guess he blew his motor in third.
So my Dad wrecked up his porsche JewPac42 Off-Topic 67 07-25-2007 06:41 PM
So... my roomates blew up the toilet... t3hWIT Off-Topic 41 12-04-2005 07:06 PM
my friend blew up his GT.. what should he do? Rexman Legacy Forum 9 02-22-2003 12:27 PM
so my friend is selling his 99 RS coupe mkh North West Impreza Club Forum -- NWIC 1 08-12-2002 02:08 PM
