Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 11-16-2005, 09:31 AM   #1
Member#: 80770
2005 v7 spec-c
Default alky injection nozzle, point up or down?
should nozzle be pointing up inside of IC pipe ( spraying alky upward) or pointing down?
i've heard that you should install pointing up because of some presure might suck out alky from nozzle or whatever. is this true? does it matter at all
nuhga is offline   Reply With Quote
Old 11-16-2005, 09:35 AM   #2
Member#: 56902
2009 VW Jetta SE
Most setups that I have seen have the nozzle facing up...
lowblow is offline   Reply With Quote
Old 11-16-2005, 10:21 AM   #3
Member#: 23717
2005 Big red
It doesn't matter. The only reason I put mine in pointing up is it hides the nozzles and hose.
Most WI systems use a check valve to stop boost from "blowing" the lines empty.
TheMadScientist is offline   Reply With Quote
Alky Injection nozzle on 2.5" FMIC pipe. metoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 12-27-2006 12:36 PM
Tilt steering, up or down? Atlas' Kids General Community 31 05-01-2002 12:49 PM
Progressive springs: tight coils up or down? Snowphun Brakes, Steering & Suspension 6 02-14-2002 03:29 PM
Do I go up or down? Adhesiv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-13-2002 01:35 AM
Windows won't roll up or down at all! jwaters Service & Maintenance 7 11-13-2001 03:30 PM
