Old 11-16-2005, 04:56 PM   #1
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
Default Reading the Dipstick (Engine Oil)
Will it read slightly higher or lower if the car is parked on a (very) slight up-slope (facing up of course)? Thanks.
Gunner is offline   Reply With Quote
Old 11-16-2005, 08:24 PM   #2
lDeez lNutz
Member#: 94339
2005 STi
i don't think that's a question someone has an answer to, but you WILL get an inaccurate reading if not checking on a leveled surface.
lDeez lNutz is offline   Reply With Quote
Old 11-17-2005, 09:42 AM   #3
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
The dipstick is sorta towards the front, so it should read low if the car's pointing uphill. Anyone can check this by jacking the front up some more, then checking the dipstick again.
You could even jack the rear, until the car's perfectly level. Then make the oil perfect by adding or whatever. Then let it down & check again. Now you'll know where it should read on your favorite non-level parking spot. I wouldn't do it this way if it's very steep.
JimBlake is offline   Reply With Quote
Old 11-17-2005, 01:19 PM   #4
Corkfish
Member#: 39503
Subarus are the worst cars I've ever seen for getting an accurate reading on the dipstick. The thing has to be perfectly level. It seems like every time I check it reads differently.
Corkfish is offline   Reply With Quote
Old 11-17-2005, 07:24 PM   #5
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
^agreed
HappyIdiot is offline   Reply With Quote
Old 11-17-2005, 07:46 PM   #6
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Originally Posted by HappyIdiot
^agreed
Same here
Needles is offline   Reply With Quote
Old 11-18-2005, 02:37 AM   #7
garie
Member#: 26607
2002 wrx wagon
^^same its hard for me to get consistent readings.
garie is offline   Reply With Quote
Old 11-19-2005, 08:45 PM   #8
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
It's the first car where I had to check my dipstick 4 or 5 times to get a somewhat accurate reading.
volkl23 is offline   Reply With Quote
reading the manual transmission dipstick. banana_pony95 Transmission (AT/MT) & Driveline 4 01-09-2009 11:34 AM
Reading The Dipstick 510Style Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-29-2008 07:50 PM
Did express oil change place put the wrong type of fluid (instead of engine oil)? ImportVenom Off-Topic 26 07-05-2005 03:53 AM
what the ****? low engine oil on my 05 sti dipstick 005sti Mid Atlantic Impreza Club -- MAIC 5 02-13-2005 04:52 PM
