Old 11-16-2005, 06:55 PM   #1
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
Default Injector Install directions needed
Okay,
My car is going back to NA from turbo, and it's time to put the stock injectors back in. I'm fairly confident I won't have any problems doing this, and searching has turned up a lot of useful info, but does anyone have a link to a site that details the whole process? It's been a while, and I'd hate to forget a step?
Yes, i've been searching. Like I said, found lots of great info, but not an actual write-up of the whole entire process.
-adam
projectrally is offline   Reply With Quote
Old 11-16-2005, 07:58 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
This procedure is for more than just the injectors, but if you take just the areas concerning injectors, it should work for you:
http://www.projectwrx.com/modules.ph...howpage&pid=30
At least, it will give you some idea.
Samurai Jack is offline   Reply With Quote
Old 11-16-2005, 09:33 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i have 99rs injectors for cheap if you need any
alex
Old 11-16-2005, 11:12 PM   #4
projectrally
Member#: 53916
2015 FFR 818S
Red Gel Coat
alex
Thanks, I appreciate it, but I've still got mine. Tomorrow morning before work I get to solder the injector plugs back in...won't that be fun!
Samurai Jack- thanks for the link. Should help.
Somebody should really make a FAQ about this...
Need fuel pump install directions lovemyrex Service & Maintenance 5 01-04-2011 01:58 PM
I Need TurboXS ABC Install Directions! Hayaboosted Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-17-2005 12:15 PM
Need carpet install directions GC8 MadMax Interior & Exterior Modification 9 10-07-2002 03:05 PM
Help I need Clutch Install Directions! MattC Transmission (AT/MT) & Driveline 1 03-03-2002 04:39 PM
Directions for injector install?? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-21-2002 10:41 PM
