Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 11-16-2005, 08:10 PM   #1
nuhga
Member#: 80770
2005 v7 spec-c
Default help! trying to install alky injection
hi, I have snow performance kid and trying to mount alky bottle... and i figured it would be better to use my stock windshield wiper bottle for alky like lot of ppl does.
what do I do about the tiny waterpump that is attached under the windshield wiper bottle?
how do i connect hoes to that bottle?
is there snow performance bottle can be mounted other than having to drill or taking out fender ??
nuhga is offline   Reply With Quote
Old 11-16-2005, 08:56 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
I used the existing windshield washer tank for my install...all you need is a 3/4NPT-hose barb(whatever size hose you're running to the pump) & some epoxy-superglue...I used the existing rubber seal also...smeared the NPT end of the barb w/ epoxy then screwed it into the rubber seal while it was in the tank...no leaks...
testes1010 is offline   Reply With Quote
Old 11-16-2005, 08:59 PM   #3
stu
Member#: 25768
35R bugeye
Slowbaru
I just drilled a hole in the bottle and ran a rubber hose from the top works great.
Later Jeff
stu is offline   Reply With Quote
Old 11-16-2005, 09:12 PM   #4
nuhga
Member#: 80770
2005 v7 spec-c
get rid of the little pump that is attached to the whindshiled whiper tank? what did you guy sdo about whiper ?
Old 11-16-2005, 09:44 PM   #5
stu
Member#: 25768
35R bugeye
Slowbaru
i just left mine there.
Old 11-16-2005, 09:58 PM   #6
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Here is what you do,
Pull tank out, drill hole to fit this fitting
http://www.fastenal.com/web/products...l.ex?sku=68323
(By the way all the fittings I list can be found at home depot in the plumbing section. They are the Watts brand connectors. They are plastic connectors. I am just using fastenal because they have pics of all of this stuff. I am going to go to all Fastenal stuff though.)
Anyway, thread fitting into the lowest part of tank where you drilled the hole.
Silicone the fitting in so there is no leaks.
Then get some of these. Get a few extra just in case.
I use them if I have to cut my tubing at all. They make great splices, and don't leak.
http://www.fastenal.com/web/products...l.ex?sku=68424
Get only 1/4 inch stuff as this is what the snow kits come with for push to connect fittings, and tubing. You can buy more tubing at home depot also. Get the 25 foot roll of 1/4 inch. It will hold the pressure fine. You need it since snow only gives you like three feet of the stuff.
Make sure you use the check valve between your tank and pump.
DP
DonkeyPunch is offline   Reply With Quote
Old 11-16-2005, 10:13 PM   #7
nuhga
Member#: 80770
2005 v7 spec-c
thanks guys.
how did you guys mount the pump? drilled the hole??
i guess i'll have to find a new smaller bottle for windshiled whiper?
Old 11-16-2005, 10:55 PM   #8
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Originally Posted by nuhga
thanks guys.
You can buy the $25.00 windshield wiper spray bottle and internal pump at autozone. I used it for my IC water sprayer before I got WI. I still have it mounted. I put it in the trunk, and it has more than enough pressure. It is part # 9-400. I a plain on off switch on the dash to run it.
DP
Here is where I mounted my pump. The pump is upside down. I drilled up into the engine compartment, and used plastic wall anchors to hold it in with good screws. No problems at all. The tank is right next to it. I just pulled the fender liner out of the way to do it.
Edit: this isn't my car, I just used the pic as a representation so you would know where I mounted it. DON'T mount it in the trunk. I burned up my first pump in about 3 days. It is to much work for the pump to push all the way forward and up to the IC. Plus you lose a lot of pressure.
Mount the pump and tank somewhere in or close the the engine bay. Behind the front fenders works well.
Old 11-17-2005, 08:42 PM   #9
nuhga
Member#: 80770
2005 v7 spec-c
hey, where did you guys tab for power ???
Old 11-18-2005, 01:49 AM   #10
dust12
Member#: 13417
I would tap the battery since its in the engine bay, make sure you have a fuse and relay. I'm sure it came with the kit.
dust12 is offline   Reply With Quote
Old 11-20-2005, 03:16 PM   #11
nuhga
Member#: 80770
2005 v7 spec-c
hey where did you guys ground the controller and pump ?
i grounded wrong place so ecu isnt getting enough power for reflash
Old 11-20-2005, 03:27 PM   #12
testes1010
Member#: 47145
2012 Gas Saver
I tapped the battery(+12v) for the pump(+12v) then it goes through the relay to battery ground, pump grounded also to the battery & I tapped the ACC(yellow/green wire) running into the radio for power on the relay. Any chassis ground will work. I used one behind the radio housing & one by the ecu but that was because my UTEC is switching it ON & OFF.
DO NOT TAP THE BATTERY FOR POWER TO THE RELAY.
Need help trying to install video card! Rev Off-Topic 18 02-03-2004 04:21 PM
Help! Trying to install os, but cd drive not recognizing liigod Off-Topic 10 09-26-2003 11:24 PM
Trying to install a cold air intake...need help gimpless Legacy Forum 4 07-04-2003 12:02 AM
Trying to install my Blitz FATT (timer), need help SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-30-2001 02:53 AM
Trying to install TEINs, is something wrong here??? Help!!! Andrew Technical Forum Archive 7 10-03-2000 10:19 AM
