Old 11-16-2005, 10:10 PM   #1
krexken
Member#: 100901
Default Loud valvetrain noise suddenly began!
I don't know if this engine has hydraulic lifters or no lifters, rockers or anything but this loud tick suddenly began in my 93 1.8l impreza with 160k. It began my last cold startup. The noise is definitely coming from the valve cover area. The engine still runs fine. The noise doesn't change at all with engine fully warmed up and is there at all rpms. I poured a can of mystery oil into it and warmed it up again, drove it a few miles with no change in the noise at all. Does this engine have solid, adjustable rockers, hydraulic lifters, shims and buckets, ?????? I'm kinda like to know what to look for before I pull the valve cover and have a look. TIA
krexken is offline   Reply With Quote
Old 11-17-2005, 07:50 AM   #2
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
You have an EJ18, it has Lifters located inside the rocker arms. Remove the rocker covers, THree bolts either side. Remove the rocker assembly and press down on the lifters, (put rocker on bench upside down), whichever ones move are faulty, you can try to bleed them up by submerging them in oil, pushing the relief valve in with a small pop rivet or simillar and pushing the plunger up and down. If it works you will see tiny bubbles coming out of the relief valve hole. remove the pop rivet. Repeat for all 16 Refit in vehicle and test. Note: this model also known for oil pump backing plate screws coming loose and lowering oil pressure enough to make lifters noisey but not enough to bring oil light on or make engine knock.
hope this helps
Cheers
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 11-18-2005, 04:01 PM   #3
krexken
Member#: 100901
Thanks for the info, sixpack. I added some Seafoam to the mix of Marvel Mystery oil and engine oil and drove it around about 10 minutes and the noise went away completely! Drained that concoction and put some fresh dino juice in it and hopefully she's ready to roll for another 100k or so.
Old 11-18-2005, 08:16 PM   #4
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Wow. What the hell is in that SeaFoam stuff, anyway? I assume it's not detrimental to our engines if people are recommending it?
z is offline   Reply With Quote
Old 11-19-2005, 05:22 AM   #5
sixpack subaru
Member#: 64974
Subaru Stars
Cheers Bud
That's why I post here, (Sixpack Kicks Back; Enjoys warm fuzzy feeling.... )
any ideas what grade/brand of engine oil you had when the noise occurred?
Cheers
Sixpack Subaru
Old 11-21-2005, 07:35 AM   #6
krexken
Member#: 100901
I've used Wal Mart's Super Tech 20-50 oil in it since I bought the car 40k ago. I've been hesitant to post the brand since I'm not really sure if it would've made a difference or not. Typically I'm not swayed much by the usual oil company scare tactics although I did switch to Super Tech's full synthetic 10-30 for this last refill. At $12 for a five quart jug, it eases my conscience a tad.
Tranny is all of a sudden making a very loud whining noise fatcircles Transmission (AT/MT) & Driveline 4 02-06-2008 07:37 PM
Excessive valvetrain noise? AK'S REX Factory 2.0L Turbo Powertrain 4 03-23-2004 08:52 AM
Really loud valvetrain Mancini Service & Maintenance 4 02-22-2003 05:08 PM
Valvetrain noise Z1 Performance Legacy Forum 3 08-10-2002 12:00 AM
Lifter/valvetrain noise Grap Mid Atlantic Impreza Club -- MAIC 11 05-19-2001 06:20 AM
Message Board Statistics All times are GMT -4. The time now is 04:51 AM.
