Vancouver Impreza Club
Old 09-03-2001, 07:03 PM   #1
tora
Member#: 5851
09 Forester XT
+ NA Miata
Default minnam intake for legacy??
Would the minnam intake from my RS fit on my new wagon?
(RS was a 98 wagon is a 2001). Thaaanks. Also, looking for opinions on a suspension set up for the wagon. I am not going for coilovers but will get a spring/shock combo.
tora is offline   Reply With Quote
Old 09-03-2001, 07:04 PM   #2
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
guess not....SOHC and DOHC diff man....
KYB + H&R sounds like the only choice for Legacy....hehe....
5 Zigen is offline   Reply With Quote
Old 09-03-2001, 07:24 PM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default It should fit....
Your new car doesn't have a MAF so that's one less thing you'll need to hook up to your intake tube. You may need an adaper to connect your filter to your tube. Ask Keiho or Mirage or anyone else with a Minnam intake and +MY00 how the filter is attached.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 09-03-2001, 07:44 PM   #4
Benjamin Tang
Member#: 4496
2009 Forester
red
tora... if an ej22/ej25 bg/bd legacy intake will work on your year, i might have something used for u in an adapter and filter (no pipe though). i bought a jcsports cai retrofit kit for our wagon and i cannot not use the above listed parts anymore.
ben
Benjamin Tang is offline   Reply With Quote
Old 09-03-2001, 09:06 PM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
I already have the filter and pipe and they are together. I am just wondering if the pipe will connect to the engine correctly and not be in the way of anything. Does anyone have a Minnam on a 2000-01 2.5liter? Is KYB/H&R the only option....then there you have it.
Old 09-03-2001, 09:11 PM   #6
Penphoe
Member#: 269
Thumbs up
Looks like you're good to go tora! Just bolt her up and go for a drive!
LaterZ!
Darren!!
Old 09-03-2001, 09:23 PM   #7
Prostho
Member#: 3388
1992 E34
Mauritius Blue
Hey try posting this on the legacy forum u will probalby get a lot more info! Whiteline also has springs for the BH wagon i believe.
Prostho is offline   Reply With Quote
Old 09-03-2001, 10:00 PM   #8
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
It should fit. I don't see why not...same motor...if anything, you'll have a bigger space to put on the intake.
Kayaba/H&R...can't go wrong with it!
Keiho is offline   Reply With Quote
Old 09-03-2001, 11:42 PM   #9
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
Keiho: it might be good on ur GC....but AC says on his Legacy is kinda soft....probably due to diff of the car weight?
Old 09-03-2001, 11:45 PM   #10
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Hmm...wouldn't know...
But still...it's one of the most economical setup...and it's not too bad so~
Old 09-03-2001, 11:47 PM   #11
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
worse is guess nothing else would fit
Old 09-03-2001, 11:49 PM   #12
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Wouldn't Tein have something for the Legacy?
Old 09-03-2001, 11:55 PM   #13
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
yeah
and Kg/mm
but do u want special order from Japan? hehe...
Old 09-04-2001, 12:02 AM   #14
euroauto
Member#: 249
05 FXT psm
06 E55
Try the K&N insert, then remove all the air chambers and replace that with a hose to the snorkel on the core support. Then remove the air defector from the hood. Better yet bore out the air filter houseing to 3" then hook to overbored air scoop on core support with 3" ABS flexable drain pipe.
PS I'll be in town tomorrow around 3pm I'll be playing at Nick North every AM until Saturday. So I can show you if you need.
euroauto is offline   Reply With Quote
Old 09-04-2001, 08:57 AM   #15
tora
Member#: 5851
09 Forester XT
+ NA Miata
I could go PDM style on the filter but thing is I already have the minnam intake plus GReddy filter from my last car and I would like to use it if possible. If it doesn't work I will sell that unit and do PDM.
As for Springs/shocks, I would like something economical and with performance. I think whatever the best deal is give or take a couple hundred I will go for. If I can get a better setup up for a couple hundred more I will do that. Or, if anyone is selling coilovers for legacy.....yummy!!
Old 09-04-2001, 01:10 PM   #16
Penphoe
Member#: 269
Default Do the minnam thing.....
You've spent quite a pretty penny on the Minnam intake. It should bolt straight up - brackets and everything!
LaterZ!
Darren!!
Old 09-04-2001, 02:10 PM   #17
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
We'll slap it on when you're back in town Tora. Your motor should be broken in already by then right?
Old 09-04-2001, 06:25 PM   #18
tora
Member#: 5851
09 Forester XT
+ NA Miata
3,000 k's in a week and a half....not quite.
I am just hovering over 500k's right now and
I have not even filled with gas yet. Got it from
the dealer (specialty of course) with a full tank
and am just scraping on empty now. I'll fill it before
coming home. Amazing how much gas I save when
driving carefully for the break in.
Minnam it is. UD pulley as well to go on there.
Old 09-04-2001, 07:25 PM   #19
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Cool...you getting George to put on the pulley for you again?
Old 09-04-2001, 10:04 PM   #20
tora
Member#: 5851
09 Forester XT
+ NA Miata
I'll wait until I do my legwork and then get him to do it at the same time.
Minnam Intake for sale! tabolau Southern California Impreza Club Forum -- SCIC 2 08-02-2001 02:38 AM
Minnam Intake for sale!!! tabolau Southern California Impreza Club Forum -- SCIC 1 07-26-2001 03:55 AM
Making cold air intake for legacy, some help needed tonytiger Normally Aspirated Powertrain 5 02-06-2001 12:52 AM
Minnam intake for sale Keiho North West Impreza Club Forum -- NWIC 0 11-17-2000 12:54 AM
Minnam intake for sale Keiho Vancouver Impreza Club Forum -- VIC 0 11-17-2000 12:53 AM
Message Board Statistics All times are GMT -4. The time now is 07:57 AM.
