Old 11-17-2005, 06:18 PM   #1
1fastser
Member#: 87158
Default 02 WRX valve cover gasket replacement...
I've searched to no avail. I even scrolled (no search) thru the archives for a while...anyway.
Subaru has informed me that my VC gaskets are leaking and this has a $500 price tag and it turns out I'm a cheap bastard.
I'm mechanically inclined but very busy. Can anyone profide some input on the job. Is it done from the bottom? Can it be done on ramps? Do wheels need to come off? ect... write-ups? links?
By the price, I'm guessing it takes several hours but could be done on a Saturday afternoon.
Comments welcome.
Jody
1fastser is offline   Reply With Quote
Old 11-17-2005, 07:21 PM   #2
veightkiller
Member#: 78967
2011 335i
bump for the input and pictures im also interested about this one..
veightkiller is offline   Reply With Quote
Old 11-17-2005, 08:35 PM   #3
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Knock, knock :-(
Uh, no clue why they said it would be $500!! Check out http://www.subaruparts.com/diag/?mod...category=020-1
Each side has an outer valve cover gasket that follows the perimeter of the VC and then there's two gaskets that go around the area for the spark plugs. I replaced all three for my passenger side and it wasn't bad at all. For the passenger side, I had to take out the airbox, pull the two spark plug coil packs and undo the 8 bolts holding the valve cover on. The gaskets fit right into a groove in the VC. Some people mention using some silicone around the edges too, but I don't think it's necessary- I changed the gaskets back in the spring and no leaks as of yet. Make sure you don't mess with the crescent shaped gasket at the backside of the engine (there might be one on the front side as well) or that could cause you some problems. One thing that is a PITA is getting at the lower three bolts, but gear wrenches worked well in that case. I did the whole job from the topside of the engine bay.
Paulie V is offline   Reply With Quote
Old 11-17-2005, 10:07 PM   #4
1fastser
Member#: 87158
Thanks for the replies.
Hopefully, I'll get some time this weekend to look at it...
Jody
Old 11-18-2005, 05:39 AM   #5
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru quote to use sealant at the 'crescent shaped' seals and gasket joins. Also at the 'corners of the raised Crescents for the cam journals at the front. Personally. I also Threebond the Spark plug seals as on some models they become the outer section of the camshaft 'oil bath'. I threebond the entire lower section of the R/Cover all the way up the crescents front and rear, (basically a little everywhere except the top), I haver had mine in now for 145000kms and not even a stain. I have done dozens like this and same results. Just make sure everything is clean before re-assembly. Don't let any old pieces of sealant fall inside the Head/Cam area. Wipe all surfaces to be sealed with white spirit. Replace bolt seals, I always apply a thin film of Threebond to the lower three bolt seals to aid sealing in the lower section of the rocker cover as this sustains the 'wettest' environment. You will normally notice that the side that the D'Pipe is on will normally leak first. Heat kills the neprene gaskets. I have installed a small heatshield to the affected areas, (adhesive, foil backed-available at good parts suppliers), and I believe this has helped.
Cheers
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 09-13-2011, 01:46 AM   #6
Meguzbeknot
Member#: 290570
2002 wrx
Anyone recommend a specific brand of VCG? Yes...I just brought back a 6 year old thread..
Meguzbeknot is offline   Reply With Quote
Old 09-13-2011, 01:48 AM   #7
typing2hard
Member#: 254819
2007 sti
black
6 years late -_-
typing2hard is offline   Reply With Quote
Old 09-13-2011, 02:54 AM   #8
2.5ReallySexy
Member#: 167943
Oem is best way to go.
2.5ReallySexy is offline   Reply With Quote
Old 09-13-2011, 07:58 AM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I agree - plus they are pretty inexpensive (don't forget the spark plug tube gaskets and the washer/gasket things for the bolts - sometimes you can re-use them, but since they are all 9+ years old, I'd just replace them)
Old 10-15-2011, 05:32 PM   #10
mbarre76
Member#: 295540
2002 WRX Wagon
Note: When you remove the bolt on the bottom at the back, a few ounces of oil may spill out. And then a few more ounces when you get the cover off.
Next time, I'll put some rags and an oil drain pan underneath first. :-P
mbarre76 is offline   Reply With Quote
Old 04-08-2012, 10:10 PM   #11
Galen Moore
Member#: 17032
2002 WRX Wagon
Default 02 WRX VCG Replacement
I just did both of mine this weekend. 5.5 hrs, start to finish. It would have taken about 45mins if I'd had the engine out and on a stand at about shoulder height. The bottom/rear-most bolt needs a gear wrench, as previously stated.
I think the driver's side is fine, but I could see (and smell) wisps of oil smoke from the pass' side after a 40min test drive. I'd like to believe that it's just burn-off of the spillover while the vc was off, but a little more time will tell. I hope it's not warped.
I put a tiny bead of the grey OEM goo in the vc groove and a thin film on the flat side of the vcg, after doing a really good clean and wipe of the cyl head side. Dunno if that was a mistake or not - I couldn't resist on the basis that a little bit of goo between the gasket and the metal surfaces would have to be better than the results with none.
Both needed replacement - I'd been able to see seepage on the driver's side, but the pass' side had a thick layer of goo from ages of seeping. Only recently did that translate to being able to smell the oil smoke from the driver's seat.
I pulled the splash shield so that I could partly remove and wipe the oil out of a heat shield that serves as a nice spilled oil reservoir and to get a better look at the driver's side . Doing so was otherwise not necessary. I did drive the car onto my 4" lift mini ramps before beginning the job to save having to lean over that additional bit.
BTW - what is that black thing with a hose connector and three bolts at the top rear area of both vc? I looked at the pass side one when I had it off, and could not see a passage into the vc space. Re-connecting the hose for the pass side one was a real PITA.
I went with dealer parts for this job. The crescent seals were $11/each, and those washer-things were $4 each! It would otherwise have been a much cheaper project.
Galen Moore is offline   Reply With Quote
Old 04-13-2012, 11:04 PM   #12
Tomato_88
Member#: 204277
Dark Gray Metallic
[QUOTE="Paulie V". One thing that is a PITA is getting at the lower three bolts, but gear wrenches worked well in that case.
Anyone know what size gear wrench is needed?
Tomato_88 is offline   Reply With Quote
Old 04-14-2012, 04:25 PM   #13
Tomato_88
Member#: 204277
Dark Gray Metallic
I get to answer my own question. Looks like a 10mm gear wrench, is the tool for the job.
Old 04-14-2012, 04:47 PM   #14
002sedTim
Member#: 289098
2002 bugeye wagon
Radio Flyer
www.rockauto.com has a whole vcg set with rubber grommets for $27 per side. A lot cheaper than going to the stealership. I went to them for the passenger side without looking at rock auto first and ended up spending just over $90.
002sedTim is offline   Reply With Quote
Old 04-15-2012, 12:25 PM   #15
Stulla
Member#: 316793
Hey i jus changed my passenger side VC gasket on my 04 wrx and it only about an hour and a half. It can be done underneath the hood easily all u have to do is jus remove the air filter box and u get easy access to it.
Stulla is offline   Reply With Quote
Old 12-16-2013, 02:13 PM   #16
BenxJammin
Member#: 363500
Is it possible this valve cover gasket leak could be seen going out the turbo exhasut and down the downpipe?
BenxJammin is offline   Reply With Quote
Old 12-16-2013, 03:43 PM   #17
Dakota D
Member#: 293894
2006 wrx sti
cgm
hey ben!
if your valve cover gaskets were leaking you would see oil on the driveway floor etc as well as the plastic undercover as far as it being on the exhaust,youd only see it on the manifold or uppipe but now down the downpipe as you described.
now when you say out the turbo exhaust and down the downpipe im going to ahead and guess your talking externally,in which case the most likely scenario would be a bad oil seal on the turbo.or even possibly but not as likely would be the oil feed on on the turbo.
hope that helps!
Dakota D is offline   Reply With Quote
Old 12-16-2013, 06:30 PM   #18
daveman33
Member#: 376307
02 impreza WRX
hey i have just replaced the valve gaskets with the ones of rockauto and i havn't had a problem since with the engine pulled took less then a day. done in a 02 wrx
daveman33 is offline   Reply With Quote
Valve cover gasket replacement, ej20k mutiger93gt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-18-2010 11:16 AM
Valve Cover Gasket Replacement 94'325is Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-27-2008 09:57 PM
2001 LLBEAN Valve Cover Gasket replacement Tylerlan Outback Forum 1 01-19-2007 09:03 AM
where to find 94 wrx valve cover gaskets!?!? czo79 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-28-2003 10:25 PM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 08:50 PM
