Old 11-17-2005, 11:10 PM   #1
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Oil Leak (Photos)
1998 Subaru Impreza L, 120,075 miles
I've had an oil leak progress. However, I'm not quite sure if it's the oil pan seat right above the jack plate near the tranny or if its the valve cover. Hopefully you can draw a conclusion from the pictures. Opinions?
-Charles-
ImprezaVA is offline   Reply With Quote
Old 11-18-2005, 03:18 AM   #2
JPX
Member#: 44504
1996 Legacy L Sedan
Front or rear oil seal? My front seal has had to be replaced twice.
JPX is offline   Reply With Quote
Old 11-18-2005, 05:09 AM   #3
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
Rear 'cam-plate' o ring leaking. Common as mud. Don't really need an o ring. undo the 12 mm bolts, turn as you remove it, this makes it easier to pull it out straight. If you **** it sideways it will lock up. Remove the plate, clean it and apply some threebond or simillar. No more leaks!!
Hope this helps
Sixpack Subaru
This is on the RH side isn't it??
sixpack subaru is offline   Reply With Quote
Old 11-18-2005, 07:27 AM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Sixpack, I think I saw this "cam plate" last night. It was a plate with what looked like two 12mm bolts. Seems like a straight forward righty tighty lefty loosey fix. Yes, it is on the right side. It's hard to tell by the pictures.
JPX, I replaced both the front main and cam seals last year. I figured it to be a an oil separator plate or oil pan gasket.
-Charles-
Old 11-18-2005, 07:38 AM   #5
sixpack subaru
Member#: 64974
You got it Charles,
stick your camera down there and have a go at it from the back of the cyl head, you will see it plain as day. Two bolts, offset, and a central circular body where the o ring goes.
Too Easy!! LOL
Cheers Mate
Sixpack Subaru
Old 11-18-2005, 09:19 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
when you replaced the front main?
did you replaced this oil pump o ring as well?
lots of folks forget that bit, & the car will continue to seep oil if it's missed.
i agree, that's got to be the source
Jamie
www.subiegal.com
Old 11-18-2005, 09:53 PM   #7
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
I bought the o-ring today for the cam plate. I'll try to remember to take some pictures. In the mean time I'm fighting a pesky rear lateral link bolt and wheel bearing job
-Charles-
Old 11-18-2005, 09:55 PM   #8
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
did you replace the oil pump o ring as well?
Yes.
-Charles-
Old 11-19-2005, 04:41 AM   #9
sixpack subaru
Member#: 64974
I thought the picture clearly showed the origin/area of the leak, looked like a cyl head to me ...??LOL!?!
CHeers, (thanks for the laughsLOL!)
Sixpack Subaru
Old 11-21-2005, 07:01 PM   #10
tmeh
Member#: 30800
2000 .7 RS
i had oil goo that resembled that and all 3 spots under the flywheel - rear main, the piston pin or whatever access hole, and that plastic plate were all leaking
it looked like the pan was leaking but it wasnt
2.2L, same mileage
tmeh is offline   Reply With Quote
Old 12-29-2005, 08:57 PM   #11
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Just to conclude this thread, after replacing the Cam Service Hole O-ring and a week of driving, I'm happy to confirm no more leaks.
-Charles-
Old 01-02-2006, 03:03 AM   #12
sixpack subaru
Member#: 64974
Yeehah, another happy ending!!!!
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
Oil leak just above oil filter Big_Hitter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-28-2003 09:57 AM
New Omori Oil temp install and oil leak mhbrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-22-2003 07:10 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 07:44 PM
