Old 09-03-2001, 09:06 PM   #1
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
Default Connector Near Washer Resevoir
I've looked back at a couple of the previous water spray posts and have found nobody asking what the loose connector is for by the washer reservoir. I can tell its for a washer fluid pump, cause its the same as the one next to it. Does anyone know what the other end of it is hooked up to?
I wouldn't doubt that by merely installing a switch, pump, and some plumming, that you could tie into the factory harness and get a clean install. Is it possible that that connector gets a signal at high boost? I guess the only way to check is to hook up a light and see if it comes on when your booting it.
Just a thought,
-Pete
Chunky_Chicken is offline   Reply With Quote
Old 09-03-2001, 09:17 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You have high hopes for that connector, but it is simply for the rear window washer found on the wagons . I can tell you where and what color it runs on a 99 to 01 Impreza RS, but not on a WRX. It *should* end up near the ignition lock but I have no idea what color it will be at that end.
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
IClub: Now with 20% more caffeine!
Old 09-03-2001, 10:16 PM   #3
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
Nuts...
Thanks for the info, I was just about to get a scope hooked up and everything. So does the rear washer pump reside in the same resevoir? Is that what the other recess is for?
Either way, if I can track down the switch connector, its simply a matter of finding a good signal to run the auto spray from.
Thanks again,
-Pete
Old 09-03-2001, 10:28 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
The wagon *should* have a different reservoir from the sedan, with two holes and grommets for two pumps. The stock washer pump will probably not be strong enough for an IC sprayer however, but I could be wrong. As for signal, you will want to have an on/off switch as well as either a throttle or boost activated switch (ideally, both). MRT in Australia can get you a whole kit.
Brian
You and the Captain make it happen!
Old 09-04-2001, 04:02 AM   #5
XT6Wagon
Member#: 524
04 STi
A washer pump can handle some flow and some pressue, just not for long. I got a cheap $7 one from Walmart to make the radiator spary for my SHO. It would get very unhappy if run for more than 30 sec at a go. IF run for more than a minute it would take nearly an hour to cool off to normal temps again.
XT6Wagon is offline   Reply With Quote
Old 09-04-2001, 03:58 PM   #6
trboCIVIC&WRX
Member#: 6426
Yup, I found that wire at the ignition. (the blue) and I did exactly what you are talking about. I used it to power my IC sprayer pump, which is mounted in the extra pump notch in the washer resevoir. works great, and looks stock.
trboCIVIC&WRX is offline   Reply With Quote
FS::: Intercooler, Stock Air Intake, Window Washer Resevoir ambig Engine/Power/Exhaust 7 11-22-2008 11:56 PM
**SUPER SALE!! 02 WRX PARTS -- Front bumper beam, Stock Bypass Valve, Washer Resevoir ambig Engine/Power/Exhaust 8 11-14-2008 10:01 PM
Unknown wiring near battery/washer bottle specialev Electrical & Lighting 4 06-30-2005 11:46 PM
Rear washer resevoir? Cardiff Giant Electrical & Lighting 3 10-10-2003 07:23 PM
Tapping the washer fluid resevoir Shifty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2002 02:46 PM
