Old 11-18-2005, 11:27 AM   #1
rkkwan
Member#: 5596
2010 Honda Fit Sport
Question STi alignment - Track/Street. No Auto-X.
Hi guys. I know this has been discussed to death and I have read like 20 threads on this and the suspension boards, but there's often too much info and opinion.
I'm going to the track in a week (Barber in Birmingham, AL), first time in my '04 STi. [I have track experience with my '02 WRX, Pat Olsen's 97 Legacy w/DMS & my parents' '05 LGT.]
I know there are lots of opinion about this, but everybody's equipment and need is different. So, here's mine.
- '04 STi, stock engine.
- Stock suspension, wheels, tires. [Only mods: Panther+, ATE Gold, SS lines.]
- I'm only doing about 3-4 open-track events a year (Barber, Texas World etc). Just open track, no time-trial, no competition.
- I don't drive the car to work everyday, so not many city miles a year.
- No auto-x
- On the track, I don't push it that hard. Maybe 7/10th - 8/10th. Not trying to beat track records. Just want to learn the car and improve my technique.
Now, I think I'm going to keep toe at 0 for all corners. But what'd be a good camber for my use? I want good cornering performance, and I don't need maximum lives for my tires; but keep in mind that most of my miles won't be on the track. So, I'm looking for something that's kind of "moderate", a "compromise", or whatever you call it.
Right now, I'm thinking about -2 for the fronts, -1.5 for the rears. What do you guys think?
rkkwan is offline   Reply With Quote
Old 11-18-2005, 11:48 AM   #2
ratt_finkel
Member#: 46218
06 EVO 9
Sounds good, if you're not driving too much on the street, you could dial about 1/8" of toe out in the front.
ratt_finkel is offline   Reply With Quote
Old 11-18-2005, 04:50 PM   #3
rkkwan
Member#: 5596
Thanks, ratt. Anybody else?
Old 11-18-2005, 05:10 PM   #4
yobtah
Member#: 48939
If your suspension setup is stock, you'll probably have trouble getting -2 degrees camber in the front and -1.5 in the rear. You'll want cross-camber to be zero (camber equal side to side), so the most you'll probably get without camber plates is around -1.2 front and -.8 rear.
A bit of front toe-out helps turn-in and it tightens the steering... but it also makes the car wander and follow grooves in pavement. True zero toe in the front isn't much better for a daily driver... it reduces the steering's ability to "auto-center". With zero toe in front, your steering wheel will be slightly off center unless you're on perfectly flat pavement. I like aligning for zero toe but erring on the side of slight toe-in. It seems to help the steering remain centered and stable on imperfect pavement.
Edit: yep... AndrewSS beat me to it.
yobtah is offline   Reply With Quote
Old 11-18-2005, 05:14 PM   #5
AndrewSS
Member#: 51674
2005 Subaru WRX STi
WRB/GOLD
um you will need camber plates to get those kinds of numbers, factory you will get really lucky to get near -1.5 and I think thats for 05, 04's to my knowledge seem to have less ability to get near -1.5 so -2.0 is out of the question without plates. Hope that helped.
AndrewSS is offline   Reply With Quote
Old 11-18-2005, 05:19 PM   #6
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
I recently had an alignment done on my car, and if you are interested in reducing the amount of understeer, look into a slight toe-out in the rear. It does not become unstable, just makes it easier to get the back end around in the twisties. Might help, although everyone's tastes and opinions are going to be different. Especially when it comes to handling. Either way, just have fun. that's what your car was made for wasn't it?!
Weedy is offline   Reply With Quote
Old 11-18-2005, 05:20 PM   #7
rkkwan
Member#: 5596
Thanks. In that case I'll just tell the tech to max it out, with both sides equal of course.
I believe the owner's manual say the alignment spec for the rear is -.9.
Old 11-18-2005, 05:40 PM   #8
sciolist
Member#: 50200
2004 STi
I was able to get about -1.3 camber in front with the OEM suspension. You can also probably pull some out in back, even though the OEM gear is "not adjustable".
You could consider camber bolts as a cheap/easy approach, but they aren't as secure as plates. Plates also potentially offer caster adjustment.
If you're not sure about what you want from the toe, 1/8" in front and zero rear is probably a good starting point. The rear is also pretty easy to adjust in situ.
In any case, equalizing the sides and maximizing the front camber are the basic objectives on the OEM suspension.
sciolist is offline   Reply With Quote
Old 11-18-2005, 05:49 PM   #9
rkkwan
Member#: 5596
Well, I'll keep suspension stock for now. The car, while a '04, has under 5,000 miles and I only have it for 2 months. If I were to do camber plates, I may also switch the springs to the pinks at the same time. Probably next spring.
Old 11-19-2005, 01:39 PM   #10
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Stock i believer already has 1.5 degress negative in the back and zero up front. I was able to get 1.2 negative up front and 0 in the rear (using camber bolts). I get very even tire wear at the track and the tire temps are even across every tire. I do auto-x and would like more for that (mostly in the front), but for the track this setup has been good (got 1st in the time trial nationals in STX).
xcdhridr is offline   Reply With Quote
alignment/track width question Sir-Knight Brakes, Steering & Suspension 2 05-18-2008 08:03 AM
alignment on daily driven auto-x track car dntouch Brakes, Steering & Suspension 12 04-14-2006 11:19 PM
Alignment/Tracking problems Scooby Blue Brakes, Steering & Suspension 20 07-21-2004 07:25 PM
street and auto-x alignment spt_impreza Canada Region Forum 33 04-02-2003 04:26 PM
NED - Closed For Track Work - No Street Nights This Week KC New England Impreza Club Forum -- NESIC 3 06-19-2002 11:59 AM
Message Board Statistics All times are GMT -4. The time now is 12:47 PM.
