Old 11-18-2005, 12:57 PM   #1
laura_thieret
Member#: 90202
Default 2 Bad Sensors, Hard Starting
I have a 1995 Subaru Impresza 2.2 litre 4WD which has had its check engine light on for some time. The only real noticeably symptom was an occasional hard start. This was completely random, but it seemed that during the hot months it was more frequent. I finally took it into the shop and it turns out its a fairly easy fix. There are 2 bad sensors; the coolant temp sensor and the oil pressure sensor. My mechanic is fixing both for around $60, labor and parts. I am also getting a tune up to clean out the throttle body, etc. My question is actually related to the hard start however. Does anyone know if either of those sensors were causing the hard starting? One other thing that happened rarely was surging. If I was at a light idiling, it would jump forward at times and the rpms would also leap. I didn't know that this would be caused my the coolant temp or oil pressure sensors. I was convinced it was the MAF, but thats fine.
I just hope this solves the problem. Any help or comments are appreciated!
laura_thieret is offline   Reply With Quote
Old 11-18-2005, 01:05 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The coolant temp sensor was most likely the cause of your problems. When it fails or goes out of range the ECU does not get the proper information it needs to set the fuel mixture for starting and running. The result is symptoms like you have been experiencing.
The oil pressure sensor is only there to operate the warning light or gauge on the dash and would not have any effect on how the car runs. If it's being replaced it was either leaking or not reading correctly.
Old 11-18-2005, 02:57 PM   #3
laura_thieret
Member#: 90202
Thats what I was thinking, I just couldn't find any articles on it. Thanks for your help. you've eased my mind.
Old 11-23-2005, 11:49 AM   #4
laura_thieret
Member#: 90202
Sometimes my mechanic and I don't understand eachother..sigh. He has a very thick, indian accent and he talks really fast. He only fixed the oil pressure sensor, and "cleaned up" the coolant temp sensor. When I picked up the car he said the coolant sensor WILL need to be replaced. I was like, weren't you fixing that today? Well whatever. I bought one at checker, but my chilton's manual shows no pictures of where it is. Can anyone tell me where it is located? I have a handle on what to do, I just need to know where I can get at it.
Old 11-23-2005, 05:28 PM   #5
solbey11
Member#: 89234
Under the intake manifold on the passanger side. You will probably have to remove some vacuum lines to get to it. You will see that it has a brown connector on it. You need a deep 19mm?? socket to get it out. And when you do pull it out, coolant will run out so have the new one handy.
solbey11 is offline   Reply With Quote
Old 11-25-2005, 05:09 PM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
It's located in the coolant crossover pipe, under the intake manifold.
Drac9 is offline   Reply With Quote
For Sale: Aim Sport MXL Pista 2 MSI pressure sensors, 2 temp sensors, mount. complete syoung0298 Interior/Dressup/Audio & Security 12 02-24-2010 11:14 PM
FS: Viper 5701 Remote Start/Alarm plus 2 extra sensors kubafett Interior/Dressup/Audio & Security 18 03-09-2009 05:15 PM
Hard starts- '98 2.5RS rhdude Normally Aspirated Powertrain 3 09-21-2004 09:55 PM
What if coolant temp sensor didn't fix hard start? Max Umbarger Service & Maintenance 3 12-22-2003 08:17 PM
