Old 06-08-2001, 06:02 AM   #1
Rubik
Member#: 6543
Angry 1500 miles and CE light comes on.
Hi all,
As the topic says, my car has 1500 miles on it and my CE light is on. This is really frustrating. The dealer has told me to check the engine oil cap, which i did, and well, it wasn't exactly tight. I had my engine oil changed 6 days ago and yesterday the light came on. I've tighten it and the light is STILL on today. I was planning to attend my first Subaru gathering in New England tomorrow, which is about a 1 hour drive but it looks like this annoying light is gonna change all that.
Rubik is offline   Reply With Quote
Old 06-08-2001, 10:52 AM   #2
Loki
Member#: 4543
2003 WRX
Post
Check your gas cap to see if it's missing/loose. that accounts for 50% of subaru CE lights. Other than that, my guess is that it's your O2 sensor. Get the dealer to pull the code for you for a reason why the CE light is on if the gas cap trick doesn't work.
~Loki
Loki is offline   Reply With Quote
Old 06-08-2001, 11:24 AM   #3
Rubik
Member#: 6543
Question
You mean engine oil cap right ?
Old 06-08-2001, 11:29 AM   #4
inpreza kid
Member#: 3334
Post
he means the gas cap. when i first got my car i forgot to tighten the cap till it clicked and it caused a CE light.
inpreza kid is offline   Reply With Quote
Old 06-08-2001, 11:54 AM   #5
Rubik
Member#: 6543
Post
ok, i've done that, i've clicked it many times now and it still looks like my CE light is on
Old 06-08-2001, 07:21 PM   #6
v6scoobie
Member#: 1563
Talking
First of all was it raining out while you were driving your car?
What happens is there is a sensor near the gas filler tube in the wheel well and it gets wet and causes the light to come on.There is going to be a recall on it but for now they are replacing the sensor and protecting it with a shield.
v6scoobie is offline   Reply With Quote
Old 06-08-2001, 07:29 PM   #7
STiTuner
Member#: 5778
09 135i
Jet Black
Post
The gas cap CEL will go away after a while with out having to reset the ECU but I'ld take it in.. its probably an 02 sensor.. I was told by a suby mechanic that they got a bad batch of o2 sensors when they were building the cars.
Brad
STiTuner is offline   Reply With Quote
Old 06-09-2001, 12:53 AM   #8
25psi
Member#: 3086
2001 2.5 RS
Post
Go ahead and reset your ECU.
Disconnect battery
Wait like an hour
Connect Battery
Start the car without stepping on the gas
Leave running for like 20 min
Shut down
Good to go. Bet it'l fix your light.
Eugene
25psi is offline   Reply With Quote
Old 06-09-2001, 11:41 AM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Post
I've got a 00 rs. my cel came on and I took it to the dealer. they had to replace the catalytic converter. If it's your first one, take it in. It's driveable though. Go have fun this weekend.
Tim Sanderson is offline   Reply With Quote
Old 06-09-2001, 04:15 PM   #10
robz
Member#: 4378
2007 WRX Limited
Urban Gray Metalic
Post
I had the same deal at about 10k. Checked the gas cap and all that according to the manual and dealers advice. It went on and off for a week before i could take it in. It did end up being the o2 sensor, which was quickly replaced under warranty. i think it was a recall anyway. Its been fine since.
robz is offline   Reply With Quote
Parking Brake and Battery light come on as I drive WangDAT Electrical & Lighting 8 09-10-2011 05:44 PM
brake light and ABS light coming on when ebrake is down slapaho_ca Brakes, Steering & Suspension 16 11-26-2008 10:00 PM
Rpms fall and abs light comes on simplebirdy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-27-2008 01:25 AM
Blew a fuse. Now ABS, Ebrake, and CE light are on? drapes Electrical & Lighting 0 01-20-2008 09:12 PM
ABS and brake light coming on randomly? crtillmanspeed Brakes, Steering & Suspension 9 04-07-2005 10:34 PM
