Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 11-18-2005, 08:37 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Container landed!!! 2X 2005 STI Spec C JDM Transmission 6spds. Tons of other items!
How often do you see these?
2005 STI Spec C JDM 6spd. Transmission
$3900 + Shipping
*DCCD, Helical front diff.
*Race ready transmissions, intended for Subaru motorsports program
*1000km transmissions (next to new).
Slightly different:
*Pre setup for external oil cooler - $54 + labor to convert to external oil cooling (like stock).
*Inny axle stubs, $150 to convert to outties (for older than 2004 WRXs).
Please contact us for a shipping quote.
Thanks,
Preston
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston/Geoff
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 11-18-2005, 08:52 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
STi Transmission Mount - GDA 02+
$69 shipped !
The STI "Group-N" Transmission Mount is designed to reduce excessive motion of your transmission during shifting and launching. This is done by increasing material stiffness over your stock transmission mount. By decreasing this type of motion, more energy is focused to the drivetrain and chassis rather than spent twisting your transmission. These should be replaced with your engine mounts.
STI "Group-N" Engine Mounts - GDA 02+
$95 shipped !
The STI "Group-N" Engine Mounts are designed to reduce excessive motion of your motor during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine. These should be replaced with your engine mounts.
STI Engine and Tranny Mount Combo - GD 02+
$159 shipped ! IN STOCK READY TO SHIP !
Only replacing either the engine or tranny mounts and not the other can lead to severe failure of the mounts that aren't replaced. Because the STi mounts are so much stiffer, using stock mounts with the STi mounts will put excessive stress on the stock mounts because they are so much softer. As such, the engine and tranny mounts should be replaced at the same time.
Cusco Shifter Bushings - 02+ WRX / 04+ STi
-The Cusco Shifter Bushing is designed to replace the soft rubber bushing found at the anchor point of your shifter assembly. This upgraded bushing greatly improves the feel of the shifter by eliminating that spongy feel you get when changing gears.
$37 shipped!!!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
product name: XXXX
Shipping address.
Gruppe-S is offline
Old 11-18-2005, 08:53 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box; the way it was designed to be. This conversion will be particularly useful for those of you who regularly track or drag race your car. As I'm sure you've noticed, their is a large space in gear ratios between 4th and 5th gears on the USDM 6spd. This oftentimes causes a grinding when shifting from 4 to 5 quickly because the synchros cannot catch up quickly enough to compensate for the large difference between gear ratios. Professional installation is recommended.
- Excellent upgrade for motorsports guys
- Better accelleration in 5th and 6th gear.
- Eliminates grinding when shifting up from 4th to 5th gear
- Restores 6 spd. to intended gearing
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
2) Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood, if a transmission rebuild is necessary, these synchros and bearings also need to be replaced. Replacing these synchros and bearings can also cure many "mystery" gear box issues such as, "why does my tranny always grind going into 3rd gear," or "how come I sometimes can't shift down into 2nd gear." These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
- Should be replaced when rebuilding your tranny
- Cures many transmission gremlins
$419 Shipped for Synchro and Bearing Kit
$869 for rebuild w/ new Bearing and Synchro Kit
Save money if you do both at the same time!
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
Gruppe-S is offline
Old 11-18-2005, 08:53 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 11-18-2005, 08:54 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
4) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
-Clamp Load: 2205 lbs/ft.
Thanks,
Preston
[email protected]
510-783-5300
Gruppe-S is offline
Old 11-21-2005, 09:20 AM   #6
mpaone
Member Sales Rating: (30)
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Anxiously awaiting 4.44 5 spds.
-Mike.
mpaone is offline
Old 11-23-2005, 06:49 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
One six speed sold!
Gruppe-S is offline
Old 11-29-2005, 02:41 PM   #8
stratos
Member Sales Rating: (9)
Member#: 5583
96' Ver.2 Wagon
-Mike.
Same here!!
stratos is offline
Old 11-29-2005, 05:27 PM   #9
Kreeger
Member Sales Rating: (4)
Member#: 37558
2003 TS wagon
JDM bukkake white
Me three... (for the 5 spd)
Kreeger is offline
Old 11-30-2005, 10:56 PM   #10
Wayne_Coots
Member Sales Rating: (1)
Member#: 70481
95 Impreza
Semi-Flat Black
Have any JDM non-DCCD 6-speed with a helical front diff?
Wayne_Coots is offline
Old 12-01-2005, 03:23 PM   #11
kumaWRX
Member Sales Rating: (2)
Member#: 91323
Chapter/Region: HIIC
2004 WRX
Aspen white
How much would the engine mounts be, shipped to 96817? Pm me your answer because I may forget to check this thread, thanks.
kumaWRX is offline
Old 12-01-2005, 06:30 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Sorry, not at the moment.
kumaWRX - Pm sent
thanks,
Preston
Gruppe-S is offline
Old 12-03-2005, 11:12 PM   #13
DoctorNick
Member Sales Rating: (5)
Member#: 7022
heh, DC ITCA are
my rides
You guys have the ability to get 4.44 R&P sets for the R180?
DoctorNick is offline
Old 12-05-2005, 04:32 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I will find out and PM you.
thanks,
Preston
Gruppe-S is offline
Old 12-07-2005, 12:35 PM   #15
Sevaru
Member Sales Rating: (17)
Member#: 63242
2008 Accord V6 Cpe
6 speed Grey
Hey guys I sent a PM regarding an order confirmation.
Sevaru is offline
Old 12-07-2005, 08:09 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
PM returned.
Thanks,
Geoff
Gruppe-S is offline
Closed Thread
Tons of Paintball Items! New and Used BRiles Non-Subaru Stuff 6 02-25-2010 12:01 PM
06 STi Parts, 04-05 V-Lmtd. Lip, tons of other parts back in stock!!! Gruppe-S Exterior/Styling 43 01-30-2006 02:34 PM
parting a stage4 plus tons of other stuff 2002whitewrx Private 'For Sale' Classifieds 9 08-06-2003 03:34 PM
Saw Jai sighting + tons of other on my bike ride(LA/PA area)... veloLexus Bay Area Impreza Club Forum -- BAIC 1 09-11-2002 04:17 AM
