11-19-2005, 01:01 AM | #1 |
Member#: 89386
Vehicle:98 BLUE DUH |
2.5 RS owners? 1/4 times anyone?
What do some of you run stock? has anyone gotten into the 14's N/A please let me know what your setups are?
11-19-2005, 08:24 AM | #2 |
Member#: 442
NESIC
Vehicle:17 Imp Spurt 00 S2k |
Next forum down: http://forums.nasioc.com/forums/forumdisplay.php?f=79
11-19-2005, 04:11 PM | #3 |
Member#: 89386
just so you all know you dont need to post a pic of your time slip i just simply would like to here some #'s and setups.
11-19-2005, 07:49 PM | #4 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
15.9 to 16.1 completely stock. I'm not the most graceful driver, and everyone seemed to run slow the only day I've had the car at the strip, so I imagine it may have another tenth or two in it on a better day.
11-19-2005, 11:32 PM | #5 |
Member#: 32131
NWIC
Vehicle:2006 Nissan 350Z Was 01 2.5 RS |
14s NA here...
My best: 2001 2.5 RS 5 spd: Injen intake, Borla header, ApexI N1 catback, Perrin Pulley, Exedy street clutch, Exedy Lightweight Flywheel, + added weight of 2 big ass JL amps. 60'--------1.976 330'------6.009 1/8-------9.406 at 71.85 mph 1000'----12.384 1/4--------14.910 at 89.17 mph |
11-20-2005, 02:35 PM | #6 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Wow, that's a pretty healthy car considering the level of mods. Must have been built on a Wednesday when the workers were happy.
Stock I ran 16.027 @ 83 or 84 sumthin, 60' time was 2.1xx. My best is 15.361 @ 89.48mph with a 2.198 60' time. With that said, I think that trap speed may have been a timing fluke, as I've never run anything higher than 88mph except for that one run, and generally the traps are consistent mid 87s. It's worth noting that my 2.5GT weighs in around 275# more than a GC body 2.5RS (excuses, excuses... ). I have Cobb heads, cams, Injen intake, full MRT exhaust, aluminum flywheel, and an S-AFC. I've never been able to pull the sub-2.0 60' times that I see other people running, I don't know if I'm just too nice to my clutch or what. About the best I've gotten is around 2.10 I think. Pat Olsen '97 Legacy 2.5GT sedan |
11-20-2005, 10:39 PM | #7 |
Member#: 32131
NWIC
Yeah, I got a strong one I think. Here is another drag pass I made. It was 2 months after I bought my car and only my second time drag racing.
The car had 35k miles at the time. Only mod was Injen intake on Dunlop allseason tires. I removed my spare tire, jack, and the front plates that block the hood scoop and vents. Other then that, the car was stock. Also had 3/4 tank of gas. R/T--------.610 60'--------1.979 330'------6.039 1/8-------9.465 at 71.37 mph 1000'----12.459 1/4--------15.005 at 88.51 mph @ Portland International Raceway on 4/18/03 |
11-20-2005, 10:47 PM | #8 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Stock at 6000ft above sea level my car ran 17.6, on 5 psi it ran 14.6, on 23 psi it ran 12.4, on 35psi plus nitrous i expect 9's.
11-20-2005, 11:12 PM | #9 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
To give some HP correlation to Ruff, I run just about the exact same. I have dynoed at 152 whp on a Mustang Dyno and was only getting 15.2 with a 2.002 best 60' time. Then I upped the boost some and started getting 14.9 with 1.9 60' time and am an estimated 175-180 whp now.
So basically, Ruff has a badass RS. |
11-21-2005, 12:22 AM | #10 | |
Member#: 32131
NWIC
11-21-2005, 02:01 AM | #11 |
Member#: 90396
NWIC
Vehicle:2005 Legacy 2.5i Brilliant Silver Metallic |
I wanna run 12's in my RS-T... Mabe I can get low 13's if I twy.
11-21-2005, 08:02 PM | #12 |
Member#: 30798
Vehicle:2001 RS-T Hybrid 2.5>2.2T>257>2.35S |
I've pulled a 13.2@101 with a slipping clutch. Two weeks before I ran a 13.5 @106 so I know there is a 12 sec pass in her. This is with about 17 psi.
11-22-2005, 11:34 AM | #13 | |
Member#: 95558
Vehicle:2006 STI OBP |
11-22-2005, 06:32 PM | #14 | |
Member#: 30798
That's probably because you drive an 06 STI. |
11-23-2005, 03:10 AM | #15 |
Member#: 9861
RMIC
Obviously the car does not have a stock engine anymore
06-10-2006, 03:24 PM | #16 |
Member#: 38124
E. Canada
Vehicle:2000 Impreza RS BRP |
Finally got my car together and out to the track last night.
my best three runs were as follows: This is in a 2000 2.5 RS with the following mods: TWE HO headers, cat and cat back exhaust TWE stage II cams with ti springs and retainers DIY polished exhaust ports 4 puck Bully clutch lighten flywheel(not sure of brand or weight) homemade intake Going to go get the car tuned this week and have the redline bumped up to 7500rpm and see if that helps get the times down some more. |
06-11-2006, 05:09 AM | #17 |
Member#: 64673
NWIC
Nice RS times!
06-11-2006, 02:47 PM | #18 |
Member#: 73405
when i had my 2.5 i ran a stock time of 15.3 with no spare tire or jack. i then ran a 15.0 with a cobb intake. i then returned and pulled a 14.6 with twe equal headers, apex'i n1 cat back, random tech cat, n1 pully set, grounding mod. i then ran a 14.5 with the same mods + a smt 6 piggy back. Best time to date is a 13.4 with just a 50 shot of nx nitrous. oh yea the last 2 runs were with no wing, not sure if it made that much of a diff.
06-11-2006, 03:29 PM | #19 | |
Member#: 90513
When you ran the pp6 did you plug in chip with the light to make it stock, then run without the chip? |
06-11-2006, 09:46 PM | #20 |
Member#: 62629
Vehicle:1996 OBS in Green 2.5 N/A w/ full exhaust |
Cool thread, i linked this in my N/A tuning thread. Thanks to everyone posting there mods along with times.
Looked at other WRX times in the Proven forum and stock WRX's pre-'MY06 are running in the mid to low 14s. So some good N/A times here. Saw one COBB STAGE 1 getting kudos for a 14.6 with good launch times. He must be running on a tough strip. Last edited by Rally_wgn; 06-11-2006 at 10:31 PM. |
06-11-2006, 11:50 PM | #21 |
Member#: 73405
not sure what you mean, but i hard wired mine into the cars factory wiring.
07-11-2006, 03:52 PM | #22 |
Member#: 62230
NESIC
ive got a 00 Impreza L, i ran a 15.8 1/4 last month. BUT, if i take out the system and heavy wheels i can do a little better i hope. The car is currently using lightwiewight flywheel, stage 2 clutch, complete adjustable suspension and some other random things
07-29-2006, 04:54 AM | #23 |
Member#: 121012
uhhh 100% stock '99 2.2L 4eat
11 seconds 0-60 |
08-01-2006, 04:21 AM | #24 |
Member#: 121714
NWIC
Vehicle:01 2.2L Acadia/CF |
wow i feel bad for the sac town guy i ran mid to low 15's [one 14 possibly a fluke] all weekend. all i have is an Injen CAI, springs, a DIY cat back, and a Seibon C/F hood (my girl bought it so dont ask) in my 01 2.2L BEAST. but i want more power. what the hell do i do? 06' borla header on the way
wow |
08-01-2006, 05:51 PM | #25 | |
Member#: 32131
NWIC
Can 2.5 rs owners use the stock turbo kit from a 02 wrx? | OutkastWRX2 | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 07-20-2004 11:17 PM |
Auto 2.5 RS owners, autocross question. | V6 | Transmission (AT/MT) & Driveline | 9 | 06-03-2003 01:32 PM |
2.5 RS owners who have bought WRXs: Whattya think? | motorob | General Forum Archive | 18 | 03-24-2001 05:15 PM |
Am I the First '02 2.5 RS owner?? | purduealum91 | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 03-17-2001 08:02 PM |
2.5 RS owners vs I-Club members | STORER | General Forum Archive | 15 | 02-17-2001 12:45 AM |
