Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 07-01-2011, 01:53 PM   #1
BradsWRX
Member#: 157249
2003 WRX
Default Stage 3 is crap!
Went from a xpt stage 2 map to th UTEC with its stage 3 map and what a difference, the stage 2 map pulled so much harder. Mods are as follows TBE, Up-Pipe, MBC, Walbro 255, SRI, and FMIC. Looking for a map that runs better, please help.
BradsWRX is offline   Reply With Quote
Old 07-01-2011, 02:00 PM   #2
ionthecrawfack
Member#: 240140
2012 WRX DGM
03 VF34'd WRX - sold
Do you still have the TD04?
What is the max boost you're seeing. What's the target?
ionthecrawfack is offline   Reply With Quote
Old 07-01-2011, 02:17 PM   #3
BradsWRX
Member#: 157249
2003 WRX
Yes still using the factory td04 turbo, all boost settings are set to whatever the stage 3 map comes with.
Old 07-01-2011, 02:26 PM   #4
ionthecrawfack
Member#: 240140
2012 WRX DGM
Okay. You also have a manual boost controller?
Does the stage 3 map utilize the mbc or the stock electronic boost solenoid?
Old 07-01-2011, 02:44 PM   #5
AREA1320
Member#: 112508
All txs ots maps use the stock bcs with the abc bleeder. Your map feels like crap probably because its just an ots map. Not a tuned map like the xpt.
Bigger question is did you reflash the car back to stock when you went utec?
AREA1320 is offline   Reply With Quote
Old 07-02-2011, 09:22 PM   #6
BradsWRX
Member#: 157249
2003 WRX
The car was not flashed back to stock, my laptop hardrive went shortly after the the reflash. I talked to a few people (Agile Auto) and was told it would run just fine on top of the xpt map because the utec takes full control after the crossover. I guess what I'm looking for is to see if anyone sells or has a better ots map than the turbo xs map.
Old 07-02-2011, 11:28 PM   #7
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
It would be best to put the stock map on underneath.
Honest Bob is offline   Reply With Quote
Old 07-05-2011, 03:45 PM   #8
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Hill at Agile doesn't like using the UTEC.
Admittedly, he is not a good source for information on this device.
TurboXS is just a call away, and they will tell you the same thing everyone else here says:
You have a base map, not a tuned map. Get it tuned, or tune it, and you will get a similar performance level (if not better).
Abnormal is offline   Reply With Quote
Old 07-05-2011, 03:51 PM   #9
AllAWD
Member#: 17079
You bought a UTEC=User Tunable Engine Computer.
You (the user) can adjust it for your car or pay a professional like TurboXS to dyno tune it.
I had a safe road tune from a reliable source, then a Jermain tune at TXS on the dyno. Big difference! As a cheap-skate that also avoided a real dyno tune for a long time, my advice is call TXS and just get it done.
AllAWD is offline   Reply With Quote
Old 03-03-2012, 07:59 PM   #10
jrock4194
Member#: 295925
09 WRX
BLK
does anyone know what the specs could be on my stage 2 wrx 2009 with the parts i can list if it's tuned right for stage 3? and i'm at altitude in tahoe, which makes a big diff, anyway however, I am planning to get new perrin eq headers, new id injectors, new dw pump, a new grimspeed uppipe and a new torque solutions intercooler. can anyone tell me what i should be expecting to see as a percentage increase?
jrock4194 is offline   Reply With Quote
Stage 3 is almost upon me... Impreza541 North West Impreza Club Forum -- NWIC 20 05-28-2010 01:35 AM
Which is faster? Cobb Stage 2 or UTEC Stage 3 disque71 Engine Management & Tuning 17 07-02-2005 11:01 AM
Is there a thread on Cobb Stage 2 vs. Prodrive Stage 3 Power Pack? casualsurfer Newbies & FAQs 4 05-03-2004 05:06 PM
TXS Stage 3 Is Up HS WRB-rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-22-2003 09:01 PM
turboxs stage 3 is here wrxblu02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-02-2002 11:16 PM
