Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 11-29-2005, 06:26 PM   #101
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
I just started it on my laptop not hooked to UTEC right now and the speach is playing non stop, ALL OF THEM at the same time. Can't stop it.
EDIT
Ok it stopped. Quiting and restarting fixed it.
fatray is offline   Reply With Quote
Old 11-29-2005, 06:29 PM   #102
rainmanjam
Member#: 64581
2004 STI
Originally Posted by TypeC
And that depends on how you're scaling (or not scaling) your maf. Jus to reiterate, this can be extremely dangerous. And you know there is always someone who doesn't rtfm and blows their stuff up.
Oh I know.. Thats why I got a UTEC.. Read and ye shall know...
rainmanjam is offline   Reply With Quote
Old 11-29-2005, 07:16 PM   #103
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
fatray - It does the same thing on my laptop if I disable the "UTI Launched" sound. On my desktop it doesnt do it though...weird.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 11-29-2005, 07:29 PM   #104
antrey
Member#: 87454
2005 SAAB 9-2X Aero
Originally Posted by 2phless
Just used your software to fix my x-over hesitation in one felled swoop. It wasn't bad before but I lost the slightest bit of power whenever the utec took over. Watching it happen live let me target the issue. Made it easier to wrap my head around than perusing a log and trying to remember the circumstances. Big number that transition smoothly is key.
I stopped in a parking lot, made what I though would be good corrections. And they were. Smooth sailing now. Very nice.
One idea. You have those substitutions of AIT and Water temp for a timing value. Can you add an option to have it just repeatedly place the map number there? I like to set a few similar maps up in different locations, then run some loops around town and try different ones on the fly. Then I get home and forget the order. Having the number on the map would help a lot on those occasions.
If that isn't hard, other things like the aux solenoid output, and all that dash stuff you can't get from hyperterminal very easily. They'd almost all be useful on occasion.
Otherwise it's working great. Thanks!
Can you give us more detail about what you did to fix your hesitation? Was it a timing issue as most suggest/believe or something else the interface let you see clearly?
9-2x project car web page: http://9-2x.dynamic-dyno.com
antrey is offline   Reply With Quote
Old 11-29-2005, 07:31 PM   #105
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
The map tuning thing is just a thing that will show you what the program suggest you tune your map to. It wont actually re-do your map and upload it or anything like that.
What I am going to add is something that shows you your overall tune, based off of how far off you are from your target afr, add all the cells up(absolute value for each) then divide by how many cells are populated. This will give you the average amount that you are off by, then score you based on that number. This way you can do some runs, see your tune quality, then adjust your map accordingly, do more pulls and check your new tune quality and see how much you improved. How cool is that?
Jeff
Old 11-29-2005, 07:33 PM   #106
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Originally Posted by rainmanjam
No hot chick for the audio....damn....but the improvements are AWSOME.. Thanks...
Expect to see a choice of voices in the near future...including a woman
Jeff
Old 11-29-2005, 07:37 PM   #107
antrey
Member#: 87454
2005 SAAB 9-2X Aero
I would hesitate about going there if I were you. The logic for that isn't exact (x percent maf vs x percent fuel vs load), not to mention all the variables and the liability.
I for one wouldn't want it editing my maps. Now, if it showed suggestions, that would be great. Kinda like if asking for a favor vs pushing your gf's head in your lap; results could be devastating!
I agree with TypeC. Suggested map changes would be much safer for all involved although not nearly as cool as auto-tuning. With all the good work you've done I'd hate for you to lose interest in the UTEC/WRX community due to a lawsuit.
Old 11-29-2005, 08:04 PM   #108
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
There is no way to actually do real-time tuning with the UTEC. I can only make suggestions to your map.
Jeff
Old 11-29-2005, 08:24 PM   #109
antrey
Member#: 87454
2005 SAAB 9-2X Aero
The version of "auto-tuning" I was picturing was not really real time but automated inputing of new values into the fuel map based on a log file. The fuel map would be changed and saved once without the user keying in the new values manually. A new log file would then be acquired and used to make a further "singular" adjustment to the map cells. This would still be dangerous territory to tread in. Suggestions, as you plan, without directly adjusting the maps sound great to me.
Old 11-29-2005, 09:47 PM   #110
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Update: I just added a nice feature that I was talking about earlier. It analyzes your afr difference and in a nutshell it gives you a Tune Quality for your entire Table, not just the current logger-1 line. It sums up everything except the 0% column and gives you a final score, in real-time. This is very handy for logging pulls and getting a score, then re-tuning and doing more pulls then seeing if your score improved. I thought of this feature today because I wanted a way to tell if I made any real progress in my tuning efforts. I am going to try it out tomorrow when I test out the new map I made which was based on my programs table afr difference results.
Jeff
Old 11-29-2005, 11:16 PM   #111
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Good work Jeff, hopefully I'll have a chance to test it out tomorrow.
TypeC is offline   Reply With Quote
Old 11-30-2005, 06:27 AM   #112
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Of course a cold front would come through town today. It is going to throw off my afr by a bit so as to make it difficult for me to make a solid comparison of before/after with my new map. Anyhow Im sure to figure something out. I'll post up a revision this afternoon.
Jeff
Old 11-30-2005, 11:44 AM   #113
2phless
Member#: 69343
1998 TransAm cnvrtbl
So far so good. Everything is smooth, fast. The resolution on the setup screen got bigger, which is fine... don't know if that was on purpose. I only use that sitting still, so the smaller setup screen was fine too. Just my take on it though.
Thanks for the map number option. Perfect. Working on making an AFR reference table for my setup. I like it a bit richer. I'll post it up here once I get it smoothed out.
The voices are nifty. Problem is it plays through my stereo (along with the knock sensor audio also through the PC) so XM usually wins out over the drone of the detcan.
+1 for adding the sexy (female) voice, and a rap version . Japanese warnings would be extra jDm-TitE!1!
Although the current colors are very good and very easy to read at a glance.... maybe some skins options? I have my desktop set to kinda match my interior. (Lots of red and black and blue) (no pink!)
2phless is offline   Reply With Quote
Old 11-30-2005, 11:48 AM   #114
fatray
Member#: 18150
How long did you have it hooked up to the UTEC when you were driving NavyBlueSubaru? Happened to me 2 times yesterday. After about 10 minutes UTI froze then it was like I was right clicking the mouse on various parts of the screen really really fast over and over again. Then the computer just shut off. This also happened in an older build of UTI. Rebooting and plugging in my USB to Serial adapter caused the PC to shut down again. Only after removing the cord altogether from the TUNER and rebooting did it work again for my 10 minute drive home.
This never happened using Hyper-terminal, or Auto-Logger.
Old 11-30-2005, 11:58 AM   #115
TheMadScientist
Member#: 23717
2005 Big red
I just downloaded UTI.
I opened it up on my desktop and I can't see a full window like the screen shot you posted.
Is this because I don't have a Utec hooked up? Is there a way to resize the window?
TMS
TheMadScientist is offline   Reply With Quote
Old 11-30-2005, 11:59 AM   #116
AaronWRX
Member#: 7194
2011 997.2 Turbo
when i launch this new version the audio goes into an very annoying garbled loop.
AaronWRX is offline   Reply With Quote
Old 11-30-2005, 12:28 PM   #117
fatray
Member#: 18150
Old 11-30-2005, 12:58 PM   #118
rainmanjam
Member#: 64581
2004 STI
Old 11-30-2005, 01:34 PM   #119
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
AaronWRX - My laptop does the same thing if you dont have it set to play the "UTI Launched" sound. It doesnt do it on my desktop so I havnt figured it out yet. I slightly rewrote how sounds are played so that might have fixed it.
TheMadScientist - You must click on "Info" for it to bring up the information like rpm, boost, etc.
fatray - I have had it running for longer than that and I havnt had it crash on me yet. If I have data going into my usb/serial converter before windows boots up then it will crash when it closes the port, so what I do is have it plugged into the computer first, then when UTI launches, I plug in the serial plug and it will almost instantly synchronize. Try it in that order and see if you can get it to crash again.
2phless - I re-did the settings so that it was able to hold more stuff and to be bigger and easier for those with carputers to read.
The main form can be made to be skinnable, however its not like that now. It could come to the point where people actually are making skins for this, which would be pretty cool. I'll see if I can get that in the next version later today.
When I get home today I'll let everyone in on how its going and when to expect a new revision.
BTW, after using my program to better tune my fuel map, I tested it today to work and to where I am at now(eating lunch) and the car pulls much harder than before, it is definitely noticable. My co-worker commented on how the car was pulling considerably harder.
Jeff
Old 11-30-2005, 04:40 PM   #120
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Tuning Update: After analyzing my pulls, I came up with a tuning quality of 83.4%, up from 80% as of yesterday. This is just after 1 round of map adjustments. It is going to take 2 or 3 round of this to get it fully dialed in, but it was definitely pulling harder and throttle response was great. I am using the new feature I added last night that scores your tune in real-time, and also using my afr difference to make fueling changes in my utec map. Im working on getting some of your requests into the program right now and it will probably be available online around 4:30 or so.
Jeff
Old 11-30-2005, 04:48 PM   #121
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Future Updates:
*Realtime readout of horsepower, torque, and Thrust (G's)
- This feature is going to be kinda tricky but im laying it out in my mind just how it is going to work.
*Higher quality sounds for overboost/temp/rev warnings.
*Calculation of boost increase, given in psi/sec, to represent how fast you are building boost
*Peak boost hold/display. Possible that program will read out to you your peak boost after a pull(audible).
Many many more..those are just the ones I can remember for now.
Enjoy!
Jeff
Old 11-30-2005, 06:14 PM   #122
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Update: Version 1.7B is out. Please check over your settings before you use it!
Check the site for update information.
Let me know how it goes!
Jeff
Old 11-30-2005, 06:49 PM   #123
TheMadScientist
Member#: 23717
2005 Big red
I have the sound thing hapening with and without the "UTI Launched" checked.
Ver1.7B On my laptop.
TMS
Old 11-30-2005, 06:52 PM   #124
TheMadScientist
Member#: 23717
2005 Big red
Ver1.7
With the "UTI Launched" checked it is fine. Unchecked it plays all of the sounds. Again on the laptop.
TMS
Old 11-30-2005, 06:53 PM   #125
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
My laptop goes screwy again, yet my desktop doesnt. It is hard for me to fix something like that when it is only on one computer! I'll keep Looking though.
Jeff
Enhanced UTEC Interface ...? ScreaminFast Engine Management & Tuning 4 09-21-2003 12:23 AM
UTEC interface enhancement (Long) LiquidForce Engine Management & Tuning 51 06-09-2003 05:10 PM
UTEC Interface Enhancement LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-29-2003 12:42 PM
UTEC software or interface nekard Engine Management & Tuning 5 10-22-2002 05:16 PM
UTEC interface program question? davidm_sh Engine Management & Tuning 3 10-09-2002 12:07 PM
