Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 12-02-2005, 01:12 PM   #151
AaronWRX
Member#: 7194
2011 997.2 Turbo
Originally Posted by NavyBlueSubaru
I was/am considering adding more tables to the mix. TPS and MAF are probably going in there.
I have considered having a setting that monitors your crossover and checks for stumbling or other erradic stuff, I just havnt had time and other things needed to come first.
What do you mean by "Logs the 'C' note now." ??
Jeff
MAF is a good one because increased MAF indicates you are making more power.
AaronWRX is offline   Reply With Quote
Old 12-02-2005, 01:31 PM   #152
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Yea, MAF is what I use to gauge power to some degree. I am starting to see some 4.7's which is the highest i've ever attained. Im pulling solid 4.6's and every now and then a 4.7 will pop up. Im hoping to pull solid 4.7's when im done with my tuning.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 12-02-2005, 04:02 PM   #153
2phless
Member#: 69343
1998 TransAm cnvrtbl
"C note" = slang for $100 bill... or in this case. The 100% column. Sorry. Slipped into an old gangster movie for a moment.
2phless is offline   Reply With Quote
Old 12-02-2005, 04:19 PM   #154
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Oh ok, yea it logs the 100% column.
I just added a MAFv table and a TPS table. They are both averages, not min or max.
Jeff
Old 12-02-2005, 05:42 PM   #155
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Just so you all know, im working on a map editor as well, its a standalone for now.
Jeff
Old 12-02-2005, 08:29 PM   #156
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Ok, I finally got a chance to use this (before it would crash) and it's great! I didn't realize some of the things it does.
One thing that is wrong is that I changed my port to com 1 vs the standard 4 and it still shows "Port:4" on the bottom even accross sessions.
Jeff
Great. You might want to download "ULame". I use that and it's awesome.
TypeC is offline   Reply With Quote
Old 12-02-2005, 10:15 PM   #157
rainmanjam
Member#: 64581
2004 STI
Jeff
Will the upload and download function be built in?
rainmanjam is offline   Reply With Quote
Old 12-02-2005, 10:41 PM   #158
2phless
Member#: 69343
Mine says com 4 instead of 1 sometimes... then sometimes it prints 1.
Old 12-02-2005, 10:53 PM   #159
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Very easy to do. I didn't end up doing this because you have to have the motor off. The ultimate way would be to edit the load cells that have changed and not upload an entire map at once.
cdvma is offline   Reply With Quote
Old 12-02-2005, 11:22 PM   #160
rainmanjam
Member#: 64581
2004 STI
Very true..but you should be able to limit not only when to make a change in bulk to the map but limit the amount of change to a value in the map based on the difference in the AFR.
Old 12-03-2005, 11:44 AM   #161
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Without external variables such as injector ccs/min at a givin pressure rate, fuel pressure, and RPM you cannot predict the AFR.
IMHO if you limit edits do it to what the UTEC limits otherwise you are in for a world of hurt trying to get the UTEC to accept stuff.
Old 12-03-2005, 01:18 PM   #162
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I think for now the user will be required to upload/download maps themselves, its just that mine will take in your current map as well as your "AFR Difference" table, and based upon your cars configuration, it will make the appropriate adjustments. My technique of adjusting my map directly based off of how far off I am with AFR has worked out really well. I went from 80% tune to 84% then 91%. Its not an exact science but its my car and i take responsibility for what happens and so far it is working fine.
Jeff
Old 12-03-2005, 01:25 PM   #163
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
This problem has just been fixed. I found the mistake and corrected it. I had not included the proper code to setup the status bar upon launch. It was just showing the default text that I see during creation.
Dont worry, even if it says "Com 4" upon launch, its still correctly at the right port, it just isnt updating the status bar when it launches.
I'll release this fix probably sometime today.
Jeff
Old 12-03-2005, 02:16 PM   #164
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Well the map program is really comming along. It opens up your utec map off of your hard drive, then also opens up a csv table log from UTEC Interface. It then combines the existing fuel map with your "AFR Difference" Values and makes a new fuel map for you. I have been doing this manually over the past few days and its a PITA but it is very very effective at getting my fueling dialed in just right.
Now I need to figure out how to calculate the checksums because turboxs probably wont tell me how they do it but im guessing its the sum of all the values in the map...we'll see! If anybody knows what it is and wants to help me out then please throw me a bone.
Jeff
Old 12-03-2005, 03:20 PM   #165
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Silly me............I downloaded today, dragged the executable from the unzip folder to my desktop, and wondered "why won't it connect?"
It's working beautifully here Haven't run into a single bug yet.
Zackbo is offline   Reply With Quote
Old 12-03-2005, 03:26 PM   #166
rainmanjam
Member#: 64581
2004 STI
Old 12-03-2005, 03:27 PM   #167
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
What do you guys think about having the tables save and re-load automatically, instead of resetting after each use of the program? Then you will have a continuous flow of information into it. You will still be able to save it and reset it but this way it will be more filled with information.
Jeff
Old 12-03-2005, 03:35 PM   #168
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
If you see any features that you would like in UTI let me know and i'll see what I can do. I just checked it out, it looks nice but obviously is for the EVO.
Jeff
Old 12-03-2005, 03:48 PM   #169
rainmanjam
Member#: 64581
2004 STI
That'll work but you should have an absolute min. about of data before changes are made.
Old 12-03-2005, 04:46 PM   #170
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
You are referring to when the program changes your suggested map value?
Jeff
Old 12-03-2005, 05:24 PM   #171
2phless
Member#: 69343
Jeff
Yeah, I wasn't worried about it.
Old 12-03-2005, 05:44 PM   #172
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Jeff
Be stupid careful with this and make sure people know they need to verify the map changes. This is a REALLY bad idea to trust blindly because the computer cannot make interpolative decisions and make the appropriate changes to load cells that are not part of your run and smoothness should be added which depends on injector scaling and injector size. Not to mention if you change a load cell you know that somewhere else on the map you might need to make a change as well and the autotunes CANNOT do this. If you release this again, make sure the user knows whats going on. I'd have them go through a double-confirm to enable it.
Old 12-03-2005, 05:53 PM   #173
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
"Use at own risk" definitely applies here! It is going to be a seperate progam from UTI yet work directly with it. If you dont want to use it thats fine, but im writing it for me because im tired of doing it manually.
Jeff
Old 12-03-2005, 08:44 PM   #174
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Well until I can figure out how the heck they derive the checksum the map program is on hold. That is the only thing from holding me back. If you know the answer please chime in!
Jeff
Old 12-03-2005, 09:25 PM   #175
2phless
Member#: 69343
Dont know if it'll help but this program has it figured out
http://www.wrxhackers.com/forums/sho...2&page=1&pp=10
...and go to the next page on that thread to find the regedit method to beat the "software out of date" issue. (posted by the author)
Enhanced UTEC Interface ...? ScreaminFast Engine Management & Tuning 4 09-20-2003 11:23 PM
UTEC interface enhancement (Long) LiquidForce Engine Management & Tuning 51 06-09-2003 04:10 PM
UTEC Interface Enhancement LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-29-2003 11:42 AM
UTEC software or interface nekard Engine Management & Tuning 5 10-22-2002 04:16 PM
UTEC interface program question? davidm_sh Engine Management & Tuning 3 10-09-2002 11:07 AM
