Closed Thread
Old 12-30-2005, 09:37 AM   #26
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Originally Posted by kool168
my car is 05, but the vin # is < 502352, mine is 5017xx. so i would have the problem as well?
will my the dealer fix it for me under warranty?
Since this is a TSB and not a recall unless they can reproduce the rough idle they won't be able do anything. It's so easy to check though you can do it yourself in no time.
Peaty is offline
Old 12-30-2005, 07:39 PM   #27
boxered
Member#: 61884
I'm doing this tomorrow..I can't believe Subaru isn't issuing a recall over this..
boxered is offline
Old 12-31-2005, 12:12 PM   #28
boxered
Member#: 61884
Did mine this morn..driver's side was down in teh banjo, passenger's side was still good and stuck in teh union. Took a bit of effort to get that filter out but worth it for peace of mind. Thanks for teh heads up Peaty.
boxered is offline
Old 12-31-2005, 02:25 PM   #29
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
Just finished and had the same results as ^^
driver's side was in the banjo and passenger side fine
thanks peaty!!!
I'll post back with some idle results later.
SupraScooby is offline
Old 01-02-2006, 04:14 AM   #30
BoostdBoxer
Member#: 53163
I did the fix on my car today 01/01/06 at 1245PM had the day off of work and BAM Smooth idle and hyper ultra awsome steady AFR at idle engine warmed up no pitch change just steady idle. And this is on a Crawford motor with ECUtek and 30R.... HKS AF KNOCK AMP was reading AFR
BoostdBoxer is offline
Old 01-05-2006, 06:48 AM   #31
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Both of mine had fallen out of the banjo bolts into the housing when I removed them, been driving with them removed for awhile now, didn't really notice anything but i wasn't having problems to begin with
piece of mind i spose
overdose is offline
Old 01-15-2006, 02:11 PM   #32
SupraScooby
Member#: 52123
05 WRB STi
Before: Sometimes when I come to a complete stop and throw it in neutral, my rpms would shoot to 1500ish and back down to normal.
After: Hasn't happened yet.
Review: It definately solved some idle issues I was having.
Old 01-17-2006, 01:58 PM   #33
iateyourcheese
Member#: 101670
2004 BMW 330i, 04XT
I tried to get my dealership to look at this on the 04XT but they refused. They just blew me off entirely.
Guess I'll do it myself and send them the pics if the filters have dropped.
iateyourcheese is offline
Old 01-25-2006, 02:59 PM   #34
imprezivSTi04
Member#: 105961
2007 ram 3500
600ftlbs STOCK!!!!!!
just a tip i found out the hard way, the stock washers can be used...just turn the top ones over so they have a new sealing surface
imprezivSTi04 is offline
Old 01-26-2006, 11:43 PM   #35
hayasa
Member#: 44405
2004 SVX (DD)
If I want to replace the washers, any idea what the part number is? I guess you need four of them, right?
hayasa is offline
Old 01-27-2006, 12:14 AM   #36
west
Member#: 45828
2004 impreza wrx sti
black/gold
I also had this issue of idling recently. In 5 min. time it was all fixed!
Way better when cold but not much diffrence when warmed up. Both sides were not in the banjos! One was realy lodged tight in the botom of the banjo hole (pasenger side) but with some small plyers it came loose!
I simply reused the washers. Over the years I have never had a failure or leak from a copper washer as long as it was not groved or scratched. I am glad I found this info
Thank you
West
west is offline
Old 01-27-2006, 05:45 AM   #37
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
That info is in the link at the top...
Peaty is offline
Old 01-29-2006, 03:31 AM   #38
wadejg
Member#: 41649
2004 Forester XTi
Did mine today. I've always had a slightly erratic/rough idle. However, my car stalled twice today at idle. Decided to give this a try to see what happens. Both my screens were dropped and my idle seems steadier now. I'll report back longer term. Oh, and if you have a really long socket extension this is a piece of cake. You won't even have to remove the air intake hose on the passenger side. DO IT PEOPLE.
Regards,
Justin Wade
2004 FXTi
wadejg is offline
Old 01-29-2006, 01:23 PM   #39
2phless
Member#: 69343
1998 TransAm cnvrtbl
Done this morning. FMIC plumbing made the drivers side hard, but still pulled nothing out to get the job done. 30 min tops.
Both screens had dropped, both were clean @ 43k miles. I wonder what they were designed to catch since whatever it is, it isn't floating around my motor.
Didn't make a difference at all so far. I have an odd issue where the car will raise RPM as I came to a stop (clutch in, foot off throttle), sometimes running up to 2000 rpm and it won't drop to idle until it come to a full and complete stop. Rolling 1/4 mile per hour it still revs... once I stop dead, the idle drops to normal. Been doing that for a long time. My condition isn't what I'd call a "rough" idle, but an erratic, or uneven idle. No pops or misfires.
The other idle issue I had/have, and I won't know until tomorrow AM if it's fixed, is when I remote start the car cold, and after the engine warms for about 5 minutes, the idle pulses. Slow RPM climbs for about 2 seconds, then drops back rapidly to idle, and repeats immediately.
Also, the car, since installing the UTEC, takes like a moment for the ECU to come to life on startup. Key in, ignition,start sequence too quickly and the initial idle was always nasty, or would stall back out. But it'd clear up after the O2 warmed up and idle fine. Or if I wait 2 seconds-ish between ignition and start, it's always fine. The UTEC may be part of my whole issue too.
2phless is offline
Old 01-29-2006, 02:43 PM   #40
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Brought mine into the dealership to get this done. My vin didn't match the TSB so it wasn't done. I still think I have a rought idle though.
Should I pull them anyways?
I did pull them out of my v7 STi swap and that did make a big diffrence in idle. Even with 800cc injectors and cusco motor/tranny mounts.
DoctorNick is offline
Old 02-04-2006, 09:30 AM   #41
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
I had the errant filters removed from my '04 STi last night. Both had become dislodged from the bolt and wedged into the passage below. I had been experiencing an intermittent rough idle. I had not noticed anything else, but this could have been affecting performance in other areas. I hesitate to say it feels better, because of course even the headlights seem brighter after you make a change like this.
STI_FFY is offline
Old 02-05-2006, 03:31 PM   #42
Thumper23
Member#: 11571
Finally got around to removing these filters this morning, and good thing I did. First off, thanks Peaty for a great write-up, it took me a whole 20 min this morning to do this. Sure enough, when I removed the banjo bolt on the driver's side, the filter was no longer in the bolt but in the recess below. The passenger side filter was still in the bolt, so that was nice to see, nonetheless, that sucker came right out. I wasn't even really noticing any rough idle but I figured, wth, this will be a quick thing to do and glad I did.
Thumper23 is offline
Old 02-05-2006, 03:45 PM   #43
BigBoosting
Member#: 48553
I jsut did this since my car is in peices right now
both of mine were disslogged and had fallen down
BigBoosting is offline
Old 02-14-2006, 09:21 PM   #44
drew21180
Member#: 49684
2004 Forester XT 5MT
I just did this...be sure you have a long enough extension for the drivers side. Otherwise you have to move the wrench close to the positive battery terminal. Unfortunately I shorted out so I removed the negative terminal and continued.
drew21180 is offline
Old 02-16-2006, 04:30 PM   #45
SkylineR35GTRx
Member#: 25119
2005 Impreza WRX STi
So basically what we're doing is removing the bolt and checking to see if the filter dropped down below? And if it did drop, just remove it and throw it away? Peaty, any reason why you ordered the new parts in your other thread at scooby mods? How come you needed a new union screw?
SkylineR35GTRx is offline
Old 02-17-2006, 12:10 PM   #46
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
OMGHi2U
just did this today. took 5 minutes, both filters were dropped in the hole when i took the banjo bolt out. car idles a little smoother cold, same when warmed up,but i my vavle tick sounds mor eliek normal now. i always thought mine ticked a little louder than other subies. it's all good now. filter was perfectly clean to.
vtecTHIS is offline
Old 02-17-2006, 01:30 PM   #47
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
There is a switch on top of the steering column to turn and off the parking lights, all you did was hit that by mistake:
http://www.scoobymods.com/forums/showthread.php?t=3661
Peaty is offline
Old 02-17-2006, 06:21 PM   #48
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
yeah i know took me a minute,but i got it
vtecTHIS is offline
Old 02-18-2006, 11:48 AM   #49
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Thumbs up
I just did this and what a difference. I would constantly have a rough idle cold or warm. My main problem was when I would slow down at a stop and put the car in neutral the car would hesitate do a quick shake and then idle, after taking the filters out everything is smooth. No more rough idle and I feel that shifting is smoother in the lower RPMs Iím very happy thanks for this info.
AndyM is offline
Old 02-22-2006, 07:04 PM   #50
80884
Member#: 56783
2004 sti
Aspen white
I just did mine today, BOTH filters were not in the bolt. I don't know yet if it fixed anything but it may have fixed an oil burning problem when the car is cold. I will know tomorrow if it did. And if it still smokes when cold and given gas then i have other issues but we will see.
80884 is offline
Closed Thread
Questions on Rough idle on 06 STI with the following mods... origonalp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-07-2006 11:34 AM
low/rough idle on warm starts raginbull74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-23-2006 06:23 PM
Rough Idle on 2.5 Short Motor my99maddog Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-12-2005 04:50 PM
Rough Idle on new car? Alfaneggio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-06-2004 04:39 PM
rough idle on wrx clashman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-13-2002 06:56 PM
