Old 11-19-2005, 06:13 PM   #1
leeden
Member#: 41654
2005 Impreza WRX STi
2012 Sport Limited
Default floor jack slipped out
Today was the first day I used my new floor jack to swap tires. I was jacking up the front when it slipped off the jack point. I don't think anything got bent. What am I doing wrong? The pavement is a little coarse and I don't think the jack moved.
leeden is offline   Reply With Quote
Old 11-19-2005, 06:42 PM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Are you jacking it from the centerplate right behind the oil pan in the front?
try putting a small (6 inch long) piece of 2 x 4 between the jack and the car.
z is offline   Reply With Quote
Old 11-19-2005, 08:42 PM   #3
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
I've been using a hockey puck to jack up my car for a while and it works wonderfully. It's small and quite grippy. It also protects your rear diff and centerplate from scratches (why add unecessary scuff marks). They usually have it for a buck at sports authority.
Also make sure that you're using jackstands and NOT the actual jack to keep the car suspended. This can be a very fatal mistake if you're under the car.
volkl23 is offline   Reply With Quote
Old 11-19-2005, 09:02 PM   #4
Hayes
Member#: 11808
The jack pad swings in an arc as it goes up so you need to keep the rear jack wheels in line with the front wheels. You should put a 2x4 behind the wheels at the oposite end of your car before jacking.
Hayes is offline   Reply With Quote
Old 11-19-2005, 09:22 PM   #5
z
Member#: 41762
04 STi
Good idea with the hockey puck!
And yeah. Always use jackstands. I was switching my tires out yesterday and had the car jacked up with my fairly new "aluminum race jack" from pep boys. All of a sudden the damn car starts slowly coming down!!!
i don't know what the hell happened but I pulled it out, raised it to it's upper limit, went back down to the bottom and jacked the car back up and it held. Scary to think of what could have happened. I'm usually pretty paranoid about that so not only do I use jackstands but i'll throw a couple of ramps under the car for extra insurance too.
Old 11-19-2005, 10:56 PM   #6
leeden
Member#: 41654
2012 Sport Limited
I have the aluminum race jack from Pep Boys as well, actually its the combo with the aluminum jack stands. I put wheel chocks behind the rear wheels. I'm pretty sure I'm using the centerplate. I have a skidplate covering the oil pan so I know I'm not touching that by mistake.
I'll try the hockey puck suggestion.
Old 11-19-2005, 11:02 PM   #7
z
Member#: 41762
04 STi
yeah, I got exactly the same combo with the aluminum jackstands. Better use 'em.
Old 11-20-2005, 12:02 AM   #8
leeden
Member#: 41654
2012 Sport Limited
I hope you guys aren't under the impression that I'm not using the jack stands. I never got the front end high enough to put the jack stands under the car. The front wheels were still on the ground when the floor jack slipped out.
Old 11-20-2005, 03:57 AM   #9
kdogae86
Member#: 99139
02 wrx
bluey
even if your doing tires just put it high enough to get a jackstand in there anyway. breaking stuff is expensive compared to the time of just jacking it up a few inches higher. at work i dont take even small chances when dealing with a 120000 dollar customer car. customers get pissed than i lose my job, or possibly my life.
kdogae86 is offline   Reply With Quote
Old 11-20-2005, 07:59 AM   #10
Vinky
Member#: 96363
2006 STI
Steel Gray Metalic
I was swaping out my tires for winter and went down to walmart to get a jack. I always used the ones that came with my cars but I thought better of it with this one. Anyway, the jack points for the cheap one that came with the car can't be used with a hydrolic floor jack. I put the jack under something that appeared to be solid and changed my tires. I don't think I did any damage, but after reading this thread I'll have to re-think where to jack the car in the future.
If you use the central location for lifting the car, then where do you put the jackstands?
Vinky is offline   Reply With Quote
Old 11-20-2005, 02:17 PM   #11
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Don't use the jacks on the factory location as it will crease that very thin piece of sheet metal. This is where I normally jack up my car:
http://www.scoobymods.com/forums/showthread.php?t=2673
Old 11-20-2005, 02:42 PM   #12
Vinky
Member#: 96363
2006 STI
Steel Gray Metalic
I have about 6 inches of ground clearance. My jack looks something like the silver one in this link. I can't get myself under the car to find the lift point behind the engine. My wife has a forester but I have the STI and don't think I can get it on ramps. Any ideas???
Old 11-20-2005, 03:10 PM   #13
z
Member#: 41762
04 STi
Rhino ramps fit.
I have to pull my car up onto a couple 2 x 12 square pieces in order to have enough travel on the jack arm to jack it up.
just look for the square plate directly behind the oil pan.
Old 11-20-2005, 06:31 PM   #14
Vinky
Member#: 96363
2006 STI
Steel Gray Metalic
Thanks, I'll have to give that a try. I'm sure that after doing it once or twice I'll be able to find that spot in the dark.
Old 11-20-2005, 07:57 PM   #15
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
I use pads from these guys for my stands and jack:
http://www.protechproducts.net/
They also make an adaptor for the factory locations. I had a block from jc whitney though before I even found out about them. Their protectors are incredibly tough.
singletrack is offline   Reply With Quote
Old 11-21-2005, 06:14 AM   #16
garie
Member#: 26607
2002 wrx wagon
my stock jack points are all mangled up. The most retarded design ever.
garie is offline   Reply With Quote
Old 11-21-2005, 05:14 PM   #17
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Originally Posted by leeden
...I was jacking up the front when it slipped off the jack point. I don't think anything got bent. What am I doing wrong? The pavement is a little coarse and I don't think the jack moved.
The jack *should* be moving forward. As Hayes said, the jack pad moves backwards as well as up when you raise it. Since you don't want to be dragging the whole car, the jack body needs to be allowed to roll forward to compensate as you are jacking.
Old 11-22-2005, 04:45 AM   #18
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
you should try jacking up one side first and placing the stand and then the other side.
JNUTZ is offline   Reply With Quote
Old 11-22-2005, 07:10 AM   #19
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
It's stories like this that make me glad I have an inground lift in my garage.....
ScoobyNubieToo! is offline   Reply With Quote
Old 11-22-2005, 07:47 AM   #20
tmeh
Member#: 30800
2000 .7 RS
just to add, since the jack does lift in an arc, we usually find it more stable to release the parking brake and let the car roll forward while lifting the front of the car, so that the jack isn't forced to move. only on flat surfaces of course.
safe lifting.
i lifted my RS so so many times with a small jack that the plate was actually curved in. is that a sign?? lol...
tmeh is offline   Reply With Quote
For those out there with floor jacks nick04263 Service & Maintenance 2 12-09-2007 12:18 AM
Where should I jack up my car using a floor jack? Loki General Community 1 04-16-2004 02:53 PM
floor jack or bottle type jack SocialButterfly Service & Maintenance 11 11-27-2003 09:52 AM
Where to jack up my car with a floor jack? Sordid Philosopher General Community 1 11-17-2002 03:52 PM
