Notices
Old 11-19-2005, 10:03 PM   #1
Peeblesmx445
Member#: 92202
Default DIY TGV/Sensor Deletes. step by step(pics)
Just did my own TGV/Sensor delete and thought I'd share with you guys how it went and how to do it for that matter.
First off, I did this whole procedure because am putting a 3" FPRED on the car so I need to get rid of the sensor completely,otherwise it would have broke off eventually.
2nd, Air tools are your freind for this job, if you have em or know somebody who does....use them
3rd, I am not a professional at this! Im just posting how I did it so maybe someday someone will use this info to do there own , save some money, and learn something new.
Step 1: Remove intake manifold. Not gonna get into to much detail here. If you cant figure out how to do this than you prolly shouldnt be doing this at all.(I will say.... the stock fuel lines suck! There are a few bolts under the manifold that hold the fuel lines and the cars wiring that are a B**ch to get to ,but....good luck
Step 2: once the manifold is off then remove the TGV housing. You will be romoving all stock hard fuel line when you do this.Plug the holes to the cylinders w/ a few paper towels or something. Just make sure nothing gets down there including whatever your using to plug it! Now you should have something that looks like this...
Step 3: remove both black plastic ends(1 sensor and 1 motor) off each side of the tgv. Motor side should look like this..
Step 4: once that is done you are going to remove the gold butterfly flaps. you must grind the bottom side of the screws before trying to un-screw them!otherwise you will strip them out like I did take the flaps out and it should look like this...
Pics will be in next post
Step 5: With the flaps out you should now be able to remove the bar w/ a lil tap from a rubber mallet on the sensor side. There is a bearing on the motor side that needs to come out. On one of mine it came out w/ the bar , on the other it didnt and I just had to punch it out. There is also a copper insert on the sensor side that will be a b**ch to get out.. but that comes later. heres what it should look like now...
Pics will be in next post.
Step 6: This is where the air tools come in. The wall that seperates the air flow and the fuel inj. hole will be cut out.Ive read about the way to hack-saw it out but I had air tools so I used a di-grinder ,it cut through the alluminum very easy. Smoothin out the cut and you can begin porting or whatere else you like. I just cleaned it up and made it smooth but...rough. Remember you dont want mirror like finish otherwise the fuel and air wont mix properly before entering the cylinders...I think thats why??anybody? Not sure what all the bits were called but lots of sand paper and I remember a flapper something bit worked really nice Now it should look like this...
Pics will be in next post said I had to many
Step 7: Since I was removing the sensors too I needed to do more work
Go buy (4)3/8-24X1/2 allen head set screws from home depot or lowes, also pick up some teflon paste. You will use these to plug the holes on each end of the tgv housing were the bar went through. You dont need to worry about the holes in the middle of the the tgv connecting each passage way since they are both under the same air pressure/velocity ummm... something like that?? I would have but didnt have a tap small enough to get it in there so.. ohwell. Tap out each outter hole using a 3/8-24 tap, even the one with the copper insert( this is how we get this out) thread the copper insert with the tap and then hit the end of the tap inside to out from the inside of the air passage way. It should come right out. Now tap each hole. Not all the way through because then the set screws will never tighten. Tighten the set screws in after applying some teflon paste to each set screw. If you went to far and have some of the set screw hangin over on the inside of the tgv housing then just grind/sand it down till flush.
I think that is it! Remember , I am not a Professional, but if you have Q's I'll be on here to answer them.. if I can.
I Plan on sealing off the plugs and I hope my car doesnt go into limp mode( pdx said it would be fine) FPRED is in the mail and will be here on mon. YIKES. A RED on a 2.0 ............TURBO LAG. Looks like Im gonna have to use the funny gas to get her to spool I'm on the stock block so we will see what happens..... maybe a new stock block ej205 1/4 record?????? Ill post all that later after I install the turbo and have an impression to give. Well, thanks for reading and I hope this help. Flamers! take it somewhere else..please
Peeblesmx445 is offline   Reply With Quote
Old 11-19-2005, 10:05 PM   #2
Peeblesmx445
Member#: 92202
Step 4 pics
Step 5 pics
Old 11-19-2005, 10:07 PM   #3
Peeblesmx445
Member#: 92202
Step 6 pics
Old 11-19-2005, 11:21 PM   #4
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Well done!!!! I hear ya on the fuel rails. Those suck but everything looks great and a very informative write-up. You should think about submitting it to www.scoobymods.com
Rasmusson14 is offline   Reply With Quote
Old 11-19-2005, 11:25 PM   #5
fat angel
Member#: 81630
agreed!!!
how hard do you think it would be to put the rod back in?
fat angel is offline   Reply With Quote
Old 11-20-2005, 01:00 AM   #6
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
The next question is how are you going to deal with the CEL's from the TGV's being gone?
TypeC is offline   Reply With Quote
Old 11-20-2005, 01:10 AM   #7
MrH00nel2
Member#: 80474
2002 Z06
1200whp
you can do all what he did and leave the sensors on and get no cels. thats what i did
MrH00nel2 is offline   Reply With Quote
Old 11-20-2005, 08:04 AM   #8
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
It only takes a week or two before you get used to the yellow light on your dash board. I went with v7 risers and there's no EcuTek fix for it. Guys have been bugging APS to sell just the sensor blocks, maybe they'll do the right thing.
PeteDucati is offline   Reply With Quote
Old 12-10-2005, 01:34 AM   #9
joeyd02
Member#: 16742
07 STI UGM
AP Stage2 Clark Tuned
Great write up. I emailed a link of this to my friend who is working on my motor about this since I am going to be getting the FP Green.
joeyd02 is offline   Reply With Quote
Old 12-10-2005, 08:54 AM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Excellent write-up and pics.
Arenít you a little concerned about those set-screws backing out after being exposed to all that heat, pressure, and stress? I wonder what other options are out there to seal those holes, or I suppose one could just put the rod w/motor and sensors back in (less butterflies of course)?
Great work!!
xcntrk75 is offline   Reply With Quote
Old 12-10-2005, 05:51 PM   #11
garie
Member#: 26607
2002 wrx wagon
great work. i will be doing this mod soon
garie is offline   Reply With Quote
Old 12-10-2005, 07:39 PM   #12
Peeblesmx445
Member#: 92202
I only threaded the holes 3/4 of the way through, used locktite, and tighend em down. shouldnt come out...I hope!
Old 12-11-2005, 12:34 AM   #13
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
StreetTuner can turn off the CEL, I dont see why the EcuTek cant do it as well. But yes, as long as you leave that bar in, CEL is fine. But it looks so nice P&Ped
darksands is offline   Reply With Quote
Old 12-12-2005, 11:39 AM   #14
AmolaitoPR
Member#: 38609
2004 STI
You should submitt this to scoobymods, if you haven't already.
Good writeup.... I'll try to do it soon...
AmolaitoPR is offline   Reply With Quote
Old 01-24-2006, 11:38 PM   #15
boosted20
Member#: 79576
ok so if you pull the rod then you have to plug the rod holes by welding them shut right? I wouldn't trust some little plastic actuator or sensor to plug those holes. I guess I will have to look at it again. I left the rod in mine cause I heard something about limp home mode even when using a UTEC. looks like im taking it out sometime soon.
boosted20 is offline   Reply With Quote
Old 01-24-2006, 11:49 PM   #16
Peeblesmx445
Member#: 92202
You do not have to plug the inner holes. Just the outer ones. I just tapped them and put some set screws in with a little teflon paste. (very easy to do) My car never went into limp mode after this mod.
Old 01-24-2006, 11:56 PM   #17
boosted20
Member#: 79576
tape? or you threaded the holes then screwed them shut?
Old 01-25-2006, 12:04 AM   #18
Peeblesmx445
Member#: 92202
teflon paste. Yes I threaded the holes and then got the proper size set screws from lowes and screwed em in.
Old 01-25-2006, 03:14 AM   #19
boosted20
Member#: 79576
yeah that sounds like a good idea. I had a big difference in flow after just taking the clips off. im sure if I pull the rod and try the screw thing then get it tuned for the summer it will run much better.
Old 01-25-2006, 09:49 AM   #20
SolidSnake
Member#: 74034
2004 426whp 403wtq
Top Speed Tuned STi!
Would you sugest this mod for a daily driver, are there any negatives to the mod?
SolidSnake is offline   Reply With Quote
Old 01-31-2006, 09:28 PM   #21
subaman81
Member#: 93441
2003 Subaru
Great write up. And good question Solidsnake
subaman81 is offline   Reply With Quote
Old 01-31-2006, 09:38 PM   #22
veightkiller
Member#: 78967
2011 335i
what did you do about teh cel??
veightkiller is offline   Reply With Quote
Old 01-31-2006, 10:19 PM   #23
subeforlife2002
Member#: 100667
2002 WRX stage 4
Does anyone know what the hp gains could be from doing this mod? Has to be something, cause your bringing a lot more flow in.
subeforlife2002 is offline   Reply With Quote
Old 02-11-2006, 05:46 PM   #24
bah14
Member#: 52012
2005 Subaru WRX STi
CGM and Gooold!
subscribed ...
I'm wondering how "reversible to stock" a mod like this is.... that's what's keeping me from a 3" FPgreen over a sz55FB.
bah14 is offline   Reply With Quote
Old 02-11-2006, 06:38 PM   #25
djviper
Member#: 107276
99 V.R.Special
WRC blue
FPRED
sorry confused on this abreiveation whats it mean?
djviper is offline   Reply With Quote
How To: DIY TGV Deletes Jasper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 125 01-18-2016 08:00 AM
Meatys DIY TGV Delete Guide Meatbawl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 107 07-07-2014 07:33 AM
anyone know how to do diy tgv deletes? harrisont Southern California Impreza Club Forum -- SCIC 20 05-06-2010 03:53 AM
DIY TGV Delete yzblazr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-24-2006 08:42 AM
TGV Deletes/ step by step??? Peeblesmx445 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-07-2005 02:16 PM
