Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-20-2005, 08:18 PM   #1
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Default Am I gearing myself too low?
This will be the new hybrid buildup for my swap.
V7 heads/cams
Ej257 shortblock
v7 ecu w/ ECUtek + utec
v7 JDM close ratio transmission + Grp N. 4.44 Fd.
With a stock 257, I can rev to about 7250 or so before you start to get hairy. Running a large turbo like a SZ49. I am kinda consirned that the stock torquey 257 might not be the best motor for such a short gearing setup. It seems like I would rev out 6th at around 150mph? maybe less? (how do I do the math on that?)
So, am I selling myself short with this setup by going with a motor that really can't rev out like my former complete v7 setup? Before i was revving to about 8100-8150.
Opinions?
DoctorNick is offline   Reply With Quote
Old 11-20-2005, 09:40 PM   #2
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Horrible set up. Sell your trans to me .
If I ran an EJ257 I would have the cranks oil ports worked on and bump up oil pressure/flow. 8100 rpm should not be a problem.
Scoobie Steve is offline   Reply With Quote
Old 11-20-2005, 10:20 PM   #3
zoophageousbeing
Member#: 53072
I think you'll be fine. Right now I have a JDM six speed in my RS (with a 3.90 final drive). I still have the stock EJ251 in there right now, so I have to shift around 6250. I have absolutely no problem with the gearing being too short. With your higher redline and lower final drive, your gears will top out at almost the exact same speed as mine right now.
Here's where you will be at redline in each gear:
1st :32.1
2nd:49.1
3rd:66.2
4th:86.6
5th:109.8
6th:138.5
And here's where I am at redline:
1st: 31.5
2nd: 48.2
3rd: 65.0
4th: 85.0
5th: 107.8
6th: 135.9
You can use the web-based speed/RPM calculator in the Transmission FAQ sticky in the tranny forum to look up your speed in each gear. Your gears are: 3.636 2.375 1.761 1.346 1.062 0.842 I think you'll enjoy your set up very much. Of course, you'll have a lot more power so you'll pull through the gears a lot more quickly than I do, but I still don't think they'll be too short.
zoophageousbeing is offline   Reply With Quote
Old 11-20-2005, 10:44 PM   #4
silentbob343
Member#: 57307
Gearcalc
silentbob343 is offline   Reply With Quote
Old 11-20-2005, 11:05 PM   #5
zoophageousbeing
Member#: 53072
Or if you want to do the math yourself, the formula is:
MPH = (RPM x Tire diameter)/ (gear ratio x final drive x 336)
Old 11-21-2005, 12:16 AM   #6
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Thanks. Just what I needed
Old 11-21-2005, 03:10 AM   #7
Billy
Member#: 1391
1997 GF - silent ed.
[email protected] untuned
So if the tire size and gear ratio assumption is correct and this is correct...
1st :32.1
2nd:49.1
3rd:66.2
4th:86.6
5th:109.8
6th:138.5
... then you're looking at shifting 5 times before you hit the 1320 mark. Now on a road circuit, you'll always be in the right gear.
Billy is offline   Reply With Quote
Old 11-21-2005, 12:31 PM   #8
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Yeah, I was running the QM in 5th before (trapping around 115).
Guess I'll be shifting even earlier now
This car is setup for the road circuit though. Hence why I stayed away from a 35r
Prepared for snow? Am I too low? Notmare North West Impreza Club Forum -- NWIC 29 11-24-2009 12:56 PM
Am I too Low? speedshark Brakes, Steering & Suspension 10 11-21-2007 11:08 PM
I am using Whitline Flatout springs. Is my car too low? Drew888 Brakes, Steering & Suspension 22 03-23-2005 10:30 AM
engine oil temp readings too low? Am I grounded correctly? voam Electrical & Lighting 1 11-24-2003 12:20 AM
Tein HA coilovers...How low is too low? WRXTACY Brakes, Steering & Suspension 9 05-29-2002 08:43 AM
