Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 11-20-2005, 11:43 PM   #1
alaska jack
Member#: 97415
Question B9 Tribeca Fuel Mileage
As a Subaru salesman, I would really appreciate some feed back about Tribeca gas mileage and anyones experiences with regular, or, middle grade fuel.
alaska jack is offline   Reply With Quote
Old 11-21-2005, 11:41 AM   #2
Spec_Ops2087
Member#: 97889
2011 STi
from the dealer ours started at 11.9 (thanks to my heavy foot seeing how the car felt) -- after a week it is up to 19mpg (I have no idea how to reset the fuel mpg, any ideas?)
Anyway, on the highway going 75-80mph I was getting 24-26mpg, so all in all average is probably 21-22ish
Hope this helps
Spec_Ops2087 is offline   Reply With Quote
Old 11-21-2005, 05:20 PM   #3
Mann Engineering
Member#: 77164
2015 STI CWP
2013 BRZ Limited
Your fuel mpg is calculated based on the trip distance traveled. If you reset the trip counter, then I believe that resets the MPG. At least that is how it is on the MY05 Legacys.
Regards,
Gary
Mann Engineering is offline   Reply With Quote
Old 11-21-2005, 06:20 PM   #4
alaska jack
Member#: 97415
Gary is correct. You can reset both A and B. If you look in the owner's manual on page.....LOL
Old 11-22-2005, 02:10 AM   #5
Spec_Ops2087
Member#: 97889
2011 STi
lol, I have to stop being lazy!
Old 11-22-2005, 01:23 PM   #6
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Local driving is about 16 to 18 mpg. Highway aound 21 to 24. I do not use anything other than Premium as the car is already under powered. Others have tried lower grade fuel but does not seems to improve mpg.
Foxbat is offline   Reply With Quote
Old 11-27-2005, 05:17 PM   #7
Bobsprit
Member#: 77749
We get 19 on average split between local and highway. On the highway we get close to 25 now at times, but typically 23-24. We find no lack of power at highway speeds and the manual mode works very well. Still, when they upgrade the power, we'll probably get the newer model. We like it that much!
Robert B
NY
Bobsprit is offline   Reply With Quote
Old 11-28-2005, 12:53 AM   #8
totald
Member#: 35753
2012 Trail Teams FJ
formerly silverwrx3
I average over 20 in the city between my wife and me driving it. HWY has been between 25 and 27 depending on which one of us is driving.
totald is offline   Reply With Quote
Old 12-22-2005, 01:59 PM   #9
jmax
Member#: 103196
06 TRIBECA
SILVER
Got my tribeca about a month ago. Started with 11-12 city. Have 500 miles jumped to 15-16 in city moderate driving style.The more car loosens up the better it should be.
jmax is offline   Reply With Quote
Old 12-26-2005, 01:23 AM   #10
Airborne Guy
Member#: 68516
2015 YAMAHA R1 RAVEN
R.I.P. MasterTuned©
We are getting about 20mpg with every tank. City and Highway driving. Mostly city though.
Airborne Guy is offline   Reply With Quote
Old 12-27-2005, 02:33 AM   #11
mbutkus
Member#: 103713
Yea, about 20 - 21 mpg. Lots of long distance driving, no traffic
mbutkus is offline   Reply With Quote
Old 01-01-2006, 12:10 AM   #12
wm07
Member#: 26529
04 STi
was getting 18mpg at the beginning, after 2k miles, now is around 20-21 mpg. 80% freeway mileage though.
wm07 is offline   Reply With Quote
Old 01-05-2006, 01:11 AM   #13
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
Yeah but lower grade fuel is cheaper, 10 to 20 cents a gallon . The owner of my dealer has 2 Tribecas and is using regular in both. I drove his for my test drive for 2 hours and it drove fine.
3rdsub is offline   Reply With Quote
Old 01-05-2006, 01:28 AM   #14
STI Orenji
Member#: 63466
2005 wrx sti
$0.20 is $3.38 per 16.9 gallons... That's chump change
STI Orenji is offline   Reply With Quote
Old 01-05-2006, 01:33 AM   #15
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
So if regular gives the same mileage, performance and doesn't negatively eefect the motor then we spend the 3.38 because?
Old 01-05-2006, 11:06 AM   #16
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Believe me it won't be the same perfomance. Some one did a test a while back with original 212 HP H-6 in OB VDC. Regualr gas degrade the engine for about 10hp IIRC. Now the Tribeca has the same engine but highly tuned to produce 250HP. The power loss will be even more. Off the line, Tribeca is a dog even with premium gas.
Old 01-06-2006, 10:13 AM   #17
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Still trying to figure out why everyone thinks the B9 is a dog
It makes plenty of power its just higher up in the band, we've gotten so used to the N/A subie surge then nothing we don't resepect the pull-to-redline power that we're getting now.
That said, I hope for a 3.5 or 3.3 tweaked for more midrange torque... lower redline and screw the peak power number
Old 01-06-2006, 11:20 AM   #18
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
That's exactly why it is a dog, no power on low end. It's noticably slower than my '98 2.5 N/A OB and '97 2.2 N/A OBS off the line.
Old 01-06-2006, 11:48 AM   #19
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
Why is it I never see the word "chip" when discussing Subarus?
I have a friend who chipped an Audi S4, not that it needed it.
Old 01-06-2006, 11:57 AM   #20
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Did you check out those NASIOC Technical forums yet? You will find a lot of "chip" word there.
And, of course, "chip" on Subarus usually means paint "chip"
Old 01-06-2006, 12:17 PM   #21
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Subaru's don't have a place to put a :chip" like some cars. Either you get the ECU replaced or reflashed. Somehting like a Cobb AP or similar. There are some piggyback systems too but no matter what it's not similar to a plug in chip.
Peaty is offline   Reply With Quote
Old 01-06-2006, 04:39 PM   #22
Bobsprit
Member#: 77749
That's exactly why it is a dog, no power on low end. It's noticably slower than my '98 2.5 N/A OB and '97 2.2 N/A OBS off the line.>>>
But on the highway in real world driving it has better power than my Outback by a mile. I've also had the Tribeca at some pretty high speeds...very stable and secure.
Robert B
B9 Limited
Old 01-06-2006, 04:48 PM   #23
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
But in real world, people only test times from 0-60mph (where low end torque counts) not 60-80mph. 2.5 and 2.2 N/A engines run out of steam at high speed or high rpm.
Old 01-06-2006, 04:55 PM   #24
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Robert, Did you have an H6 in your Outback? Just wondering what you are comparing it to. We had the OB VDC Wagon and that had the H6. I don't feel that the B9 is any worse off the line right now but we are going easy on the B9 as it is new. Currently I consider the power fine but have not had a lot of seat time.
I'm also interested in what you consider high speed? PM me with that answer I have no intentions of finding out if the B9 has a speed limiter but I'm curious none the less If I want quick and fast I'll drive my F-XT. I got the B9 for traveling in comfort, the way my Forester is set up I would not want to go for more than 2 - 3 hrs max in it
Old 01-06-2006, 04:57 PM   #25
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
That depends where you drive most I suppose, around town or the highway. In car mags they test 0-60 in the real world I think people spend most of the time 60 - 80 MPH
B9 Tribeca Chop Thread bob655 News & Rumors 13 01-27-2005 02:32 AM
Ordered a B9 Tribeca Brochure only1agam General Community 3 01-26-2005 05:02 PM
B9 Tribeca pamphlet--my impressions Mike Wevrick News & Rumors 54 01-21-2005 03:57 PM
Hoy Introduccion de nueva SUV Subaru B9 Tribeca William WRX Puerto Rico Impreza Club Forum -- PRSIC 4 01-18-2005 05:00 PM
Just got back from the B9 Tribeca event at the LA Auto Show... HB_Dad News & Rumors 53 01-14-2005 10:10 PM
