Old 11-21-2005, 11:06 AM   #1
hotshot2109
Member#: 94785
04 WRX STi
Default Should i take the heat shealds off my header and up-pipe and wrap them in fiberglass?
Just wondering if i should take off the factory heat sheilds and wrap the pipes in fiberglass header tape or leave the stock sheilds on them. This is on my JDM tdo4 twin scroll setup also..
hotshot2109 is offline   Reply With Quote
Old 11-21-2005, 11:29 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
take the shields off off, wrap the pipes, put the shields back on.
ride5000 is online now   Reply With Quote
Old 11-21-2005, 12:13 PM   #3
checque
Member#: 68562
RIP Edwin
I haven't heard many, but there are horror stories out there that involve wrap + oil = fire. Everyone on here seems to be pro-wrap, but after reading a bit on corner-carvers.com, I'm staying far away from it. The chances of anything bad happening are very minimal, but I still won't risk it.
I guess you could wrap them, then wrap foil tightly around the heat wrap and seal it off somehow, that'd be pretty safe. Or you could get them coated and not have to worry at all.
Nice setup.
Edit: I guess the wrap and replacing the heat shields is pretty safe too, on the heavy side, but I wouldn't worry so much about a fire breaking out anymore.
Last edited by checque; 11-21-2005 at 12:15 PM. Reason: ride5000 makes a good point
checque is offline   Reply With Quote
Old 11-21-2005, 01:11 PM   #4
testes1010
Member#: 47145
2012 Gas Saver
Send them to Crucial Racing for ceramic coating/porting....then put the heat shields back on...
their standard WRX manifold extrude hone port & ceramic coating runs $200...probably be a little more w/ the twinscroll setup...definately worth it IMHO...
testes1010 is offline   Reply With Quote
Old 11-21-2005, 01:33 PM   #5
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
leave them on so your car doesnt light up
99subi is offline   Reply With Quote
Old 11-21-2005, 01:38 PM   #6
hondaeater69
Member#: 60324
send them to CR for ceramic coating/porting, then wrap them, then put your HS's back on. talk about heat retention. (this is my plan in the future when i get the duckets).
Old 11-21-2005, 02:08 PM   #7
testes1010
Member#: 47145
2012 Gas Saver
actually send Crucial Racing everything...headers, turbo & downpipe...have them matchport everything & ceramic coat all the pipes & hotside of the turbo...
Old 11-21-2005, 03:20 PM   #8
hotshot2109
Member#: 94785
04 WRX STi
LOL, good idea, but im not going to do it, thats alot of money i dont want to have invested... i dont need faster spool then 14.7 psi @ 2600 rpms... when i wraped the stock headers and installed an aftermarket cat-back that eliminated the second cat on my 1998 ej22 people thought i would get CEL codes for the oxygen sensors being to cold or some nonsence... I just wanted to make sure this wouldnt happen with the twin scroll setup installed.
Old 11-21-2005, 03:27 PM   #9
hondaeater69
Member#: 60324
if you don't send them in, i would wrap them and put the HS's back on like Ken said. And if anything, that will make it hotter when your 02 sensors are, not cooler.
Old 11-21-2005, 03:36 PM   #10
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
one word.....SWAINTECH.....nuff said.
jam69007 is offline   Reply With Quote
Old 11-21-2005, 05:04 PM   #11
rexsquared
Member#: 71748
2002 WRX Sedan
World Rally Blue
If not an internal ceramic coating then wrap, seal with Thermotec, etc, and re-install heat shields.
rexsquared is offline   Reply With Quote
Old 11-26-2005, 01:43 PM   #12
hotshot2109
Member#: 94785
04 WRX STi
i also have to take in effect that this will be used on my winter car and in NY they do use salt on the roads.
Old 11-26-2005, 01:57 PM   #13
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
Just wrap them and put the heat sheilds on, like said before. For the rest of you, the twin scroll headers are tube steel, they don't need to be extude honed like our crappy cast manifolds.
J-Rex2004 is offline   Reply With Quote
Old 11-26-2005, 04:23 PM   #14
pdxsilverwrx
Member#: 54935
I am also scared of the wrap soaking up oil and starting a fire. I say wrap then put the heatshields back on, seems the safest most cost effective route.
pdxsilverwrx is offline   Reply With Quote
Old 11-26-2005, 04:31 PM   #15
XR8TED
Member#: 101506
96 Turbo Cobra
If it were me I would coat them... Talk to Jeremy at Crucial tell him Dave aka. xr8ted sent you.. The turn around time isn't very long It is worth it in the long run you ever see the effects of what a wrapped pipe and a little water does?? Doesnt matter what kind of metal it is it speed up the corrosion process big time..
XR8TED is offline   Reply With Quote
FS. GT spec header ewg up pipe and dp, carbon drive shaft 02subbysnack Engine/Power/Exhaust 34 03-22-2013 07:44 PM
Should I take the snow tires off? upnygimp Off-Topic 39 03-30-2009 12:43 AM
FS: Vibrant UEL header /w up pipe and Snow Performance 5v MAF meth kit Cyclops NWIC Private Classifieds 1 12-02-2008 01:46 PM
Deadbolt sz55 w/ 3"inlet +porting, also APS headers, Aps up pipe, and E bay top mount west Engine/Power/Exhaust 35 03-02-2008 10:33 PM
My silver 04...should i take the body kit off? ThirdEye Member's Car Gallery 51 03-09-2007 06:55 PM
