Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 11-21-2005, 11:14 AM   #1
jvs04wrx
Member Sales Rating: (2)
Member#: 87813
Default 2004 subaru wrx, one of a kind
http://www.autotrader.com/fyc/vdp.js...rdist=0#vdptop
also just featured in city beats.com
http://orlandocitybeat.metromix.com/...imedia&index=1
2004 subaru wrx with 25,XXX miles in white
Fully loaded with sport package
Estimated 400 hp at the crank
Exterior mods
Charge speed body kit 4 pieces
Painted center grill and cleared out headlight assemblies
De badge and wingless trunk lid
Subaru RS hood “ no hood scoop”
Hand made exhaust guard
Handling
Progress lowering springs 1.8”f + 1.6”r progressive rates
Cross drilled/slotted rotors
Hi temp painted calipers “original pads”
White line steering rack bushings
AR front strut tower brace
18”+8.0 buddy club p11 rims 265/45/18s tires zr rated 50% trade life
Engine
PE1820 DBB turbo older version with p-20 housing “more flow then new version” upgraded adjustable waste gate, 720 cfm flow rate
UTEC engine management system tuned by jester tuning one of the best in the business. Hi/low boost maps and launch control systems and boost map switch fuel cut set at 25 psi
Turbo xs FMIC with turbo xs RFL B.O.V all wrapped in DEI wrap
Modded stock injectors 820 cc flow rates
Cooling mist methanol injection system with pressure switch and upgraded holding tank 150 psi pump,
“TGV deletes” with ported manifold
Turbo xs dual stage boost controller
Samco turbo inlet hose
Un-specified short ram air intake
Walbro 255 fuel pump
Unorthodox aluminum racing pulley “under driven”
4” bell mouth down pipe with a 3” turbo back system from bltzz usa
HKS upipe
Interior
Carbon fiber center gauge pod with boost//egt//afr autometer gauges
LED for cooling mist activation
Hi/low boost switch
STI shift know and shift pedal
Sti short shifter linkages sti short shifter linkages and cusco shifter bushing
The low down
This car has been garaged kept and is one of the fastest wrx in Florida the current set up will run in the low 12s the car has never been wrecked or abused in any way the oil has been changed religiously every 2,000-3,000 miles
The clutch and tranny is stock and show’s no wear
This car ran 12.80 @ 107 on low boost setting 14 psi before the injectors and FMIC was installed
Low boost is set for 17 psi hi is for 22 psi off meth or race gas 0 knock on any boost levels AFR is tuned 12.5 AFR conservative settings @ 22 psi
Original sticker was 26,000 there has been another 7,000 invested not including the dyno and tuning time
Asking 25,000 $ OBO
Kbb value =20,185$
Nada value=21,300$
James Sterman
407 758 8110 –cell
Location Orlando florid
jvs04wrx is offline   Reply With Quote
Old 11-21-2005, 11:57 PM   #2
dreamofwrx
Member Sales Rating: (7)
Member#: 72866
05 WRX
sick car, bump for you
dreamofwrx is offline   Reply With Quote
FS: 2004 Subaru WRX One Owner/Unmodified $8500 turbodrabbit Private Vehicle 'For Sale' Classifieds 5 12-18-2009 08:13 PM
FS: one of a kind 04-05 wrx vented headlight blowbyu24 Exterior/Styling 32 02-05-2009 12:35 PM
2002 WRX sdn, yellow, one-of-a-kind Errance Private Vehicle 'For Sale' Classifieds 11 07-07-2007 08:34 PM
One Of A Kind Wrx For Sale joeroket General Community 3 02-11-2007 06:34 AM
WRX w/ one of a kind 18" Speedline GT-1 "Pinoy edition" hehe djerickd Member's Car Gallery 33 10-17-2001 11:48 AM
