Old 11-21-2005, 01:15 PM   #1
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
Default new clutch disk with old pressure plate and flywheel?
i was wondering how detramental it would be to just replace the clutch disc (relatively cheap) than buying a 400+ clutch kit?
i can feel my clutch on its way out, but i just purchased a new (used) transmission.
i dont think i can afford to buy a complete clutch kit before installing the new trans.
but i dont want to really fubar the car if its a bad idea using a new disc with an old pressure plate and flywheel.
i cant get ahold of a resurfaced one locally unless i take it to a shop (no core exchanges.
any ideas? what would be the problem with using a new clutch on old pp and flywheel
psyber_0ptix is offline   Reply With Quote
Old 11-21-2005, 01:28 PM   #2
2fas4u
Member#: 90691
2005 STI / 2009 STI
There is nothing wrong with doing that at all. I would suggest that you spend the small amount to get your stock flywheel resurfaced though before just adding the new disk....
2fas4u is offline   Reply With Quote
Old 11-21-2005, 01:53 PM   #3
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Uhh, you'll be sorry if you use the old PP with a new disk. Believe me, I tried it and wish I had not back then. Learned my lesson and won't ever reuse a PP.
I guess if you are going to baby the car you'll be OK.
Kevin
Crazykev is offline   Reply With Quote
Old 11-21-2005, 02:24 PM   #4
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
thanks for both your inputs.
i just have to find a place to resurface the flywheel and suck it up and just buy the clutch kit all together.
it sucks that this has to happen before the holidays
Old 11-21-2005, 02:38 PM   #5
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I am just saying it takes a lot of work to get to the clutch and I would rather see ya' wait for a while and stretch out the life of the current clutch until you have the cash to do it right.
You might be able to reuse the PP, but only if it is in great condition. If it has ANY blue streaks to it, then you are screwed. You won't know what kind of shape the PP is in until you remove it. If it is bad and you don't have a PP you will be pissed!
Kev
Old 11-21-2005, 02:58 PM   #6
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
yea its understandable.
i just figured i'll try to knock as many stones down as i can. i just dont know when i will be able to pull the tranny back again.
(my current trans has a worn ring and pinion and other misc bearings gone bad...)
hmm.... i may just get another exedy stg1/street clutch kit....
or spec?
any ideas?
Old 11-21-2005, 03:44 PM   #7
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
Talking ideas
bought a stage II exedy/xact racing flywheel on ebay USED , there's a similiar setup for sale now:
'exedy wrx -decal, -sticker' without the quotation marks is the search I use, the one I got I had the fw resurfaced as suggested above, cheap worth the money.
also, clutchcityonline seems to have decent prices for combos, I try not to buy until I feel like I'm 'stealing' something from someone
Justin
cellobro is offline   Reply With Quote
Old 11-21-2005, 04:28 PM   #8
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
humm...... should i get an oem replacement for 250 or should i invest 200+ for a one up "stage1" kit
thanks for the replies so far, i appreciate it.
i've been thinking about spec clutches (exedy disc) after reading a few reviews
Old 11-23-2005, 09:27 AM   #9
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
actually, ordered a stg1 exedy (same as i have currently)
so i guess that puts an end to this thread. i was offered a resurfaced flywheel from andrewtech and will be contacting them further.
thanks everyone for your replies. much appreciated
STI clutch plate w/ WRX Pressure Plate and Flywheel in 5 speed Agentorangemen Transmission (AT/MT) & Driveline 3 12-18-2009 12:18 AM
Which clutch disks work with stock pressure plate and 5-7psi? (td04) Anhdalai Transmission (AT/MT) & Driveline 4 08-28-2007 01:53 PM
FS: Brand new STi clutch, pressure plate and flywheel adesso Private 'For Sale' Classifieds 15 07-19-2006 06:22 PM
OEM Clutch pressure plate and Flywheel from Sti-RA $100 supermoose Private 'For Sale' Classifieds 9 07-02-2005 11:33 AM
After Market Clutches, Pressure Plates, and Flywheels... Scoobyracer1 Transmission (AT/MT) & Driveline 14 04-20-2005 10:16 PM
