Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 12-15-2005, 04:49 PM   #1
bboy
Member#: 56468
04 Improved STI
Dirty White
Default STI Hydra favor to ask, quick logging of start up
I'm trying to troubleshoot a problem and I'm wondering if I can get someone to give me some "normal" values since mine seem abnormal.
In version 2.15 V7 of the Nemesis software under Tools-->Input Diagnostic
you will bring up a panel with sensor readings, one for the crank and one for the cam.
With later software it's called something else under the Tools menu.
Could someone please bring up this window with the your map uploaded, the car "online," and then crank/start their car?
I'm interested in the starting values from the two sensors, what happens while cranking, and the final values.
bboy is offline   Reply With Quote
Old 12-15-2005, 04:57 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
Wrong thread
Old 12-15-2005, 06:13 PM   #3
x99percent
Member#: 27108
2004 STi
2004 A4
car on, not running:
trig = 85
sync = 0
edit: These values are likely different every time...
while cranking and running:
both *all* over the place... looks like numbers from 0 to 255?
x99percent is offline   Reply With Quote
Old 12-15-2005, 08:02 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
Thank you!!
On my car it's 80 and 0, the 0 never changes indicating no signal from the camshaft sensor. The 80 fluctuates (crank signal)
On your car and another's it's 85 and 0. Then, both values fluctuate during cranking and operation, and when you turn the engine off, they stop at a random spots. I'm pretty sure the fluctuating values in the two windows are degrees--either crankshaft or camshaft. The two values are "synch'ed" when you start the car. The synch is needed for both start and to control AVCS (AFAIK, since AVCS is closed loop it has a target angle (degree) much like a wastegate and boost pressure).
Huge favor to ask of maic. (need to borrow/rent trailer) HighWayDrifter Mid Atlantic Impreza Club -- MAIC 9 06-04-2006 10:01 AM
A favor to ask of all of you North Ursalia New England Impreza Club Forum -- NESIC 43 05-05-2003 03:27 PM
Favor to ask one of you TX guys AaronB Texas Impreza Club Forum -- TXIC 6 07-03-2001 09:46 AM
I have a favor to ask one of you PA guys AaronB Tri-State Area Forum 2 04-20-2001 12:47 AM
