Welcome to the North American Subaru Impreza Owners Club Saturday December 20, 2014
Old 11-21-2005, 04:20 PM   #1
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Question Questions about WRX AC pulley
I was looking around under the hood of my WRX and I noticed that the AC pulley tensioner was broken. I picked up the part at local Subaru dealer and now I have a question: Is that pulley suppose to turn when the AC is going or is it a static pulley that does not spin? The other two pulleis appear to spin but I'm not sure about this one.
ScoobyNubieToo! is offline   Reply With Quote
Old 11-25-2005, 10:09 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
all pullies in contact with moving belts should spin!
Old 11-25-2005, 10:44 AM   #3
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Hmmm....I better have this looked at then.
Old 11-25-2005, 10:52 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are you referring to the AC compressor itself? If so the compressor has an electric clutch on the pulley that drives it, so when the AC is not running only the outside (the part that contacts the belt) will be turning, while the inside (which is actually attached to the compressor shaft) will not turn until the clutch engages.
Old 11-25-2005, 11:56 AM   #5
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Actually I'm refferring to the bottom pulley. The AC belt loops around 3 pulleys: The Crank Pulley, The top ac pulley (the one you are referring too) and the lower ac pulley. The bottom pulley does not appear to spin at all. This is the pulley that had the pulley tensioner bracket that broke and I replaced. Probably anyone who's bored and looks at their engine compartment can probably tell me if there's spins.
Old 11-25-2005, 12:14 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Does that pulley spin if you turn it by hand with the belt off? If it doesn't it's NG and has to be replaced. It would make sense actually, the pulley bearing probably seized and that's why the bracket broke. Check it and if it's bad (which it sounds like it is) make another trip to the dealer for a new pulley.
Old 11-25-2005, 06:03 PM   #7
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Thanks....I'll check it out.
Old 11-26-2005, 01:25 AM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....loosen the nut a bit....
Old 11-26-2005, 11:16 AM   #9
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
See, I wasn't sure if the nut should be loose......Is the tensioner pulley bracket the sole part that will keep the tension because it seems like a pretty week part.
Old 11-26-2005, 12:22 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...if it is gorilla'd the pulley won't turn, NO????
Old 11-26-2005, 12:48 PM   #11
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
But I wasn't sure if that pulley is suppose to turn....but then again I guess they wouldn't have put a pulley there if it was meant to turn.
dumb question about the crank pulley ScoobyRacing03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-07-2008 04:29 PM
Question about lightened crank pulley brokemypiston Transmission (AT/MT) & Driveline 8 03-11-2004 10:59 PM
Someone QUICK!!!..questions about installing racing pulley AustinSTi General Community 19 01-31-2002 10:07 PM
('93-'01) Question About WRX Fog Lights and Factory Alarm jzinckgra Impreza Forum 6 04-27-2001 01:46 AM
Question about WRX seat question Impreza22B North West Impreza Club Forum -- NWIC 2 04-12-2001 04:52 PM
