Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-21-2005, 07:24 PM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Default problems after injector install////
ok now that the wrx inj are in, i had a fuel leak, going into throttle the car will buck a bit once turbo spools up the car seems alot better, also i had a bad fuel leak fixed it and now the car runs better, but after driving sometimes the idle will suck kinda bounce up and down about 300 rpm, seems like power dims lights etc, i was reading about hwo the car might be running super rich, im leaning out about -40% at idle with emanage, and going into light throttle where it hesitates about -30 then goes a little richer -20 then up what gives? could air be getting into the manifold under vacuum?> then once boost hits its ok? so basically not leaking at the fuel rail but leaking at the base of the inj?
anyinfo will help
thanks
Greg
GregBolby is offline   Reply With Quote
Old 11-21-2005, 08:01 PM   #2
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
i would check to make sure that you dont have an air leak. i had a crappy idle when two of mine had air leaks. double and triple check all of them. you lubed them good right?
darioc is offline   Reply With Quote
Old 11-21-2005, 08:05 PM   #3
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
at the base of the inj??? did it stumble off idle? liek before turbo spools, once spooled it smooths out
Old 11-21-2005, 08:18 PM   #4
darioc
Member#: 35695
02 RST
well it could be that, or like you said, it could be too rich. it would make sense that it would be too rich and get better when the turbo spits all that air in there. whats your complete setup?
problem after injector and fuel pump install boob8282 Newbies & FAQs 6 03-04-2010 11:29 AM
Rough initial idle and hard start problem after injector install Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-23-2009 10:32 AM
Problems after injector mod VegasWRX03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-11-2008 06:08 PM
Problems after injector install. BW-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-20-2006 02:21 PM
Help!!! AC relay fails after injectors install!! Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-22-2003 04:02 PM
