Old 11-22-2005, 03:00 AM   #1
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Default My parking lights won't turn off!...Seriously :)
***In this case the switch on the steering column only turns off my dash lights and makes my stereo flicker***
My story:
Sometimes (4x in 5 months) my parking lights don't turn off after I stop the car and park it. I can turn the headlight switch on/off but the parking lights stay on.
It's as if the 'switch' that turns off the lights that last click can't quite click over once in a while...
Once, I started the car and turned it off, the lights turned off.
Once, that didn't work so I went in for lunch, drove back to work and then they turned off.
Last night, a drive around the block didn't fix it, but starting it 1/2 hour later and turning it off killed the lights!
I have an aftermarket starter/alarm. While the lights are stuck on, if I press the lock/unlock button, the lights 'click' and dim a bit but don't turn off.
Any ideas as to what my problem is?
02WHITEDUB is offline   Reply With Quote
Old 11-22-2005, 02:09 PM   #2
jaywrx
Member#: 16254
'02 WRX WRB
'07 Tribeca OBP
Bad alarm install.
jaywrx is offline   Reply With Quote
Old 11-22-2005, 02:47 PM   #3
pdxsilverwrx
Member#: 54935
Is there a relay that controlls the parking light flash with arm/disarm? If so try replacing that as it may be sticking.
pdxsilverwrx is offline   Reply With Quote
Old 11-22-2005, 10:17 PM   #4
02WHITEDUB
Member#: 96793
02 ProTuned TD04
That seems to sound right to me. Where would I find such an animal?
Alarm install: Professionally done by THE best place in the city. Very reputable business.
Old 11-23-2005, 02:36 PM   #5
zion168
Member#: 94543
FWIW, I forgot to plug one of the dash illumination plugs back on after I replaced the HU, it flickered if I turned on the P switch just like your case.
zion168 is offline   Reply With Quote
Old 11-23-2005, 02:56 PM   #6
spongejosh
Member#: 62783
Midnight Black Pearl
i would guess it is a problem with some type of aftermarket install on your car. stereo or alarm.
josh
spongejosh is offline   Reply With Quote
Old 11-23-2005, 07:36 PM   #7
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
(even with a reputable company, the switched ground system in the scoobies can be confusing).
My vote is also for something with the alarm. I just haven't heard of the switch not working before, and turning the car off and on wouldn't affect that.
Couple that with the fact that if the car is off, the parking lights (controlled by headlight stalk) also go off. which means the stalk is OK.
Also, when you click the one on the steering column, it does Something, so we know that works OK.
tooocool49723 is offline   Reply With Quote
Old 11-23-2005, 09:09 PM   #8
02WHITEDUB
Member#: 96793
02 ProTuned TD04
A little more background into my electrical goodies:
Pioneer HU
2 amps (200W, 400W)
(Professionally installed)
2-way paging alarm/starter (pro install)
BEL radar (tapped into seat heater switch)
Autometer Nexus - 2 gauges + control unit tapped into seat heater
I suspect the alarm/starter control unit...but I believe I'd have to replace the whole box if it's borked Would like to avoid that
Keep the ideas coming!
My parking lights won't turn off?... Sharky Service & Maintenance 29 03-19-2010 04:55 PM
Parking lights won't turn off ProjectWRX Service & Maintenance 14 07-19-2002 05:00 PM
Need quick Help! Parking lights won't turn off Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-13-2001 12:31 PM
