Notices
Old 11-22-2005, 11:06 AM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default STI AVO 500 Element Hydra CA 91 octane
I though you might be interested in this since I haven’t seen an AVO turbocharger dyno plot for some time. This was tuned by me on Dynamic Autosports Mustang Dyno in California on California 91 octane pump fuel.
Overall l like this setup as it has a very efficient .84 exhaust housing and you can see it wanted to make more top end power but we were limited with ignition timing due to the low octane fuel. For a Mustang Dyno and California 91 these are very good numbers.
This was still using an internal WG but boost was stable up to around 20 psi. On the dyno the turbocharger was on the “laggy” side hitting 20 psi around 4700 rpm but tuning on the road had data logs showing 20 psi by 3900 rpm.
It would be interesting to see what this setup is capable of on race fuel.
Thanks,
Phil
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 11-22-2005, 11:16 AM   #2
Newbie Subie
Member#: 20214
07 Acura RDX
390WHP no more
Nice numbers Phil!
Newbie Subie is offline   Reply With Quote
Old 11-22-2005, 12:00 PM   #3
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Nice Phil.
I'd be curious to know what type of vehicle this was on and what the weight and [email protected] numbers were as that affects the load on the vehicle and the spool up time of the turbo. Also any weather correction factors involved?
Tim
Mustang Dyno
SloRice is offline   Reply With Quote
Old 11-22-2005, 01:08 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by SloRice
Nice Phil.
Tim
Mustang Dyno
Tim,
Unfortunately that information is not printed on the dyno sheet I have. From what I remember they selected "Subaru Impreza" for the settings which had a weight around 3100 lbs and I tuned the car in 4th gear. The car is an 04 STI. As for weather, it was a typical 65 degree day in Southern California.
The differences in spoolup seem somewhat extreme in this car but it's pretty normal for spoolup to decrease a couple hundred rpm in the real world.
Thanks,
Phil
Old 11-22-2005, 02:22 PM   #5
SloRice
Member#: 44351
2004 Mitsubishi Evo
IMO, the weight for a STI or WRX without weight reduction should be around 3500-3600lb in the software. That is the weight of the vehicle with one or two people in the car. That should load the car down more appropriately to what it sees on the street and provide a little better spool up.
Old 11-22-2005, 03:02 PM   #6
cpturbo
Member#: 49175
2004 STI
To answer a few questions.
The Hp @50 was 13.5 and the weight loaded was 3200 lbs
65 F
sea level
91 Octane Shell gasoline
cpturbo is offline   Reply With Quote
Old 11-22-2005, 03:12 PM   #7
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
What do stock STi plots look like on this dyno?
kennyvb is offline   Reply With Quote
Old 11-22-2005, 03:17 PM   #8
cpturbo
Member#: 49175
2004 STI
I was told 210 hp on this dyno +/- 5 hp.
CP
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux Engine Management & Tuning 8 01-26-2013 06:58 PM
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux AccessPort 0 02-09-2010 06:53 PM
CA 91 Octane STIfever09 Water/Methanol Injection, Nitrous & Intercooler Cooling 14 12-21-2008 04:58 AM
Ca 91 octane maps mr. bled UTEC 2 07-31-2006 01:22 PM
I-Speed Tunes Crawford CP30R Kit: 410WHP / CA-91 Octane Crawford/I-Speed Proven Power Bragging 10 07-27-2005 12:49 PM
