Old 11-22-2005, 12:22 PM   #1
a87supra
Member#: 89252
2005 STi
Default STi Water Tank - Freezing?
Ok, this may be the dumbest question ever, but when parking outside, do I need to worry about the water in my I/C sprayer tank/lines freezing? If so, what do I need to do to keep it from freezing?
I feel like an idiot... Thanks for any help
a87supra is offline   Reply With Quote
Old 11-22-2005, 12:28 PM   #2
StiPete
Member#: 96164
2005 STi - SOLD :(
'00 Impreza 2.5rs
AFAIK it just says not to fill it too much so in case it freezes it wont expand and break the container.
I think it mentions something about it in the manual.
StiPete is offline   Reply With Quote
Old 11-22-2005, 12:31 PM   #3
MaSTi
Member#: 41358
06 Forester
I like to empty mine as much as possible. This keeps it from having any chance of expanding and busting the container. Also, DO NOT spray it while frozen. I heard you can break the pump easily that way.
MaSTi is offline   Reply With Quote
Old 11-22-2005, 12:34 PM   #4
a87supra
Member#: 89252
2005 STi
... Next dumb question, where do the water lines run, and is there any type of anti-freezing, or just don't overfill it and don't use it when it's too cold?
Old 11-22-2005, 12:45 PM   #5
drdome99
Member#: 56571
'05 LGT - Stage 2
i had mine around 1/2 full all last winter and never had any issues
drdome99 is offline   Reply With Quote
Old 11-22-2005, 12:49 PM   #6
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
If it gets below 0C, it will freeze.
If you plan on using it below 0C, add antifreeze.
Personally, if its so cold that I have to worry about freezing I don't feel the need for the water spray, so I just leave it empty.
powerlabs is offline   Reply With Quote
Old 11-22-2005, 12:49 PM   #7
Ramsdale
Member#: 1951
08 M3
Pop open your trunk and hood, and look for the clear plastic lines. (Well, they're opaque actually). You'll spot them going from the water tank in the trunk, if you look up at the bottom of your rear deck. Likewise, you'll see the lines on your hood, near the opening by the hoodscoop.
Basically, simply make sure your water tank is not completely full (about 3/4 full or less is fine), and don't use the spray for a week or so before winter hits and it gets below freezing. The water in the lines will dry up enough that the lines won't be damaged.
The only thing you might notice is a clunk from the trunk area, if a block of ice forms in the water tank and it moves around. I never really noticed this last year, and had a bit over half a tank of water left come winter. (I had ice in the tank, but it didn't move around much).
Come spring, you'll just need to give the water spray button a few pushes to repressureize the system.
Anti-freeze could be put in the tank, but all it's going to do is wind up on your intercooler eventually, and be smelly. Plus, you risk staining things. I can't think of a good reason to tempt fate and put anything but water in there.
KR
Ramsdale is offline   Reply With Quote
Old 11-22-2005, 12:51 PM   #8
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
The lines run from the trunk to the inside of your hoodscoop. Don't use it when it's extremely cold out and keep the tank about 1/2 full for the cold season.
conker69 is offline   Reply With Quote
Old 11-22-2005, 12:51 PM   #9
Timmy Burns
Member#: 99348
If I could only
get you oceanside.
add some alcohol to the mix, or anti freeze. unless its like 40 below you wont have to worry about it freezing.
Timmy Burns is offline   Reply With Quote
Old 11-22-2005, 12:51 PM   #10
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
IIRC the line runs to the drivers side of the trunk then down along the car with the fuel line. Best bet, empty the bottle for winter ... it's not like you'll need it anyway.
DO NOT put anti-freeze in the I/C sprayer bottle. Not that it'll harm the system, but you'll wind up spraying your IC with it. Good luck getting the smell out after that ..
Car vs. Driver is offline   Reply With Quote
Old 11-22-2005, 01:00 PM   #11
nate49509
Member#: 22452
2016 WRX
You could fill it up with windshield washer fluid. Its not as toxic as antifreeze an is usally good till 25 below. Or just empty it. When its that cold you not going to have any heat soak problems anyway.
nate49509 is offline   Reply With Quote
Old 11-22-2005, 02:27 PM   #12
a87supra
Member#: 89252
2005 STi
I was thinking about doing this, because it makes sense, and some people do this for added cooling perfomance
Old 11-22-2005, 02:34 PM   #13
iguanamafia
Member#: 23426
2010 Forester
Streetfighter
Check the flash point of your windshield washer fluid some of that stuff is quite flammable
iguanamafia is offline   Reply With Quote
Old 11-22-2005, 02:34 PM   #14
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Not sure how much that would help the IC sprayer really ... the whole purpose is that it takes heat to evaporate water, thus transfering heat from the IC into the evaporation process (in a nutshell).
What product specificaly would add to this effect?
Old 11-22-2005, 02:42 PM   #15
powerlabs
Member#: 45790
SUPERCHARGED
All I ever use in fall and spring is windshield washer fluid. No smells, no stains, and no fires so far.
Old 11-22-2005, 02:54 PM   #16
CaptinMorgan97
Member#: 57634
2005 STI
My evo's manual said to put windsheild washer fluid in it during the winter. So when I got the STI last December, I just emptied out the water and put windsheild washer in it. I didn't like the idea anyways of water in the rubbler lines freezing.
I havent had anyproblems so far.
or you can just empty it out, but I hate that yellow light that turns on when you have no water.
CaptinMorgan97 is offline   Reply With Quote
Old 11-22-2005, 03:06 PM   #17
o2sys
Member#: 43842
200? WRX STI
Do you even need to use it when is that cold outside?
o2sys is offline   Reply With Quote
Old 11-22-2005, 04:37 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Do NOT!!!!! put anti freeze in the tank!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!1
....I'd pump it almost dry...pour a bottle of rubbing alcohol in it and and fill it to ~2/3 full and spray it until it was 1/2 full and pull plug on the pump until spring....and done
.....but what do I know.....
Old 11-22-2005, 05:51 PM   #19
k mier
Member#: 98000
05 sti [email protected]
Uncle Scotty: Why not use winshield washer fluid? I understand that if it is cold enough out to freeze water the spray isn't needed, just thought it might be an easy remedy.
k mier is offline   Reply With Quote
Old 11-22-2005, 06:22 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
...dye it blue.........no need to do that
Old 11-22-2005, 06:33 PM   #21
CaptinMorgan97
Member#: 57634
2005 STI
I agree with not using the antifreeze.
But windsheild washer fluid is kosher considering the pumps are simmilar with the I/C spray and the windsheild washer.
Old 11-22-2005, 08:04 PM   #22
k mier
Member#: 98000
ooooh....I see. Too late though, all ready filled with the blue washer fluid. No more than I will use it through the winter hope it won't stain too bad. Maybe it will clean off, Simple Green and a brush? They make pink colored fluid too.
Old 11-22-2005, 09:28 PM   #23
powerlabs
Member#: 45790
SUPERCHARGED
Uncle Scotty,
I've been using windshield washer fluid for 6 months now and it hasn't dyed anything on my engine bay the slightest amount.
Furthermore, I would not want to use rubbing alcohol; it will harden rubber seals and lines and cause them to fail prematurely.
Just my 2 cents worth...
Old 11-22-2005, 09:54 PM   #24
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
I made a sprayer for my WRX with:
STi button + harness from wrecked Forester
Generic pump
Rad overflow tank from mid-80's Nissan Pulsar - Fits nicely between the battery & headlight.
I plan to empty it, put in a tiny bit of washer fluid, pump it into the lines, and run the winter with the tank pretty much empty.
My $0.02
02WHITEDUB is offline   Reply With Quote
Old 11-23-2005, 03:01 AM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by powerlabs
Uncle Scotty,
Furthermore, I would not want to use rubbing alcohol; it will harden rubber seals and lines and cause them to fail prematurely. Just my 2 cents worth...
....bullspit
FS MA: 05+ Legacy Parts + STI Water Tank DJHiRoller NESIC Private Classifieds 8 10-27-2008 12:49 PM
Sti Water Tank vatorn10 Private 'Wanted' Classifieds 21 06-16-2008 02:39 PM
WI + STI water tank + Utec: Where do I begin? AaronWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 10 03-23-2006 12:31 PM
STi water tank connector Alizarin Electrical & Lighting 6 06-25-2005 05:56 PM
