Old 11-22-2005, 08:15 PM   #1
XenoWolf
Member#: 64029
1999 Impreza L Wagon
Sun Bleach Red
Default So who else has tried to double clutch into R
... double clutch into reverse.
I tried it once back when I was a complete noob to driving stick (and didn't know **** about transmissions). I've never heard such a horrifying sound come from my gearbox. Just clearing my concience and wondering whoelse has done this..
XenoWolf is offline   Reply With Quote
Old 11-22-2005, 08:21 PM   #2
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
What does that mean, exactly?
You're stopped, pump the clutch, and pull it into reverse?
Yes, you'll hear a bit of a clunk/grind/noise from time to time. Don't worry, it's because the reverse gear is straight-cut and harder to mate together.
If you're moving more than 1"/second it will probably grind like crazy if you try to find reverse.
If you're having trouble engaging reverse, try rolling the car even the tiniest bit and it will slide right in.
02WHITEDUB is online now   Reply With Quote
Old 11-22-2005, 08:27 PM   #3
Bman
Member#: 64351
2005 Legacy GT
When you were moving forward? Did that once, terrible grinding noise.
Bman is offline   Reply With Quote
Old 11-22-2005, 08:31 PM   #4
kcook
Member#: 78074
2005 STi
i get a grinding noise almost everytime... when the cars not level... or its barely moving... or anything. it usually takes me 2 tries if i just get off work or out of the gym or some place where i get tired... but if im like doing a uturn and i need to reverse... i get it on a dime but, usually takes me 2 tries to get it in reverse... IMO out of all the stick cars ive driven, mines been the hardest to get into reverse
kcook is offline   Reply With Quote
Old 11-22-2005, 08:32 PM   #5
XenoWolf
Member#: 64029
Sun Bleach Red
To clarify, I was rolling forward ~5mph, moved to neutral, let out the clutch, revved, disengaged the clutch, and shifted. It doesn't work, I didn't really know what a synchronized gear was back then, let alone that reverse wasn't one of them.
Old 11-22-2005, 08:36 PM   #6
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Originally Posted by XenoWolf
To clarify, I was rolling forward ~5mph, moved to neutral, let out the clutch, revved, disengaged the clutch, and shifted. It doesn't work.
That's one of those things you only do once I have
Old 11-22-2005, 08:42 PM   #7
rally_on
Member#: 86849
2005 GMC Savana
white
in my miata, i can swing the car around 180 degrees in a drift and slam it into reverse and keep going the same direction the i started you in, JUST THE THE FAST AND THE FURIOUS... but 10x slower... and in the rain...
-Greg
rally_on is offline   Reply With Quote
Old 11-22-2005, 08:57 PM   #8
Hogie
Member#: 97017
2015 Mustang GT PP
Competition Orange
I almost always have to shift into neutral and let clutch out, push back in clutch and then grab reverse. I thought this was another one of the Subaru idiosyncracies that everyone of us lived with and loved?
Hogie is offline   Reply With Quote
Old 11-22-2005, 09:42 PM   #9
02WHITEDUB
Member#: 96793
02 ProTuned TD04
-Greg
Yes, but are the wheels locked while you engage reverse? You could probably do that in a Subie...not that I'm about to try.
I can do forward 360s on snow w/ a FWD car!
Old 11-22-2005, 10:58 PM   #10
Shavenyak
Member#: 7156
1999 Jeep Cherokee
When I had my WRX, I couldn't GET INTO reverse without "double clutching" it from a stop.
--Roman
Shavenyak is offline   Reply With Quote
Old 11-23-2005, 07:52 AM   #11
XenoWolf
Member#: 64029
Sun Bleach Red
Well, from a stop I usually either have to engage/release the clutch or pump the brakes once to get it into reverse.
Old 11-23-2005, 09:25 AM   #12
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
Our transmissions don't "mate" gears together, do they? I was under the impression that the gears in a gear set are always mated together. When we shift, we are merely selecting which set of gears to use. It's the job of the synchros to help the dog teeth to engage the gear set we select. My general understanding of transmission comes from How Stuff Works, so please correct me if I'm wrong. (By the way, the fifth or sixth page discusses the noise you hear when shifting into reverse.)
thorongil is offline   Reply With Quote
Old 11-23-2005, 02:38 PM   #13
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Well, you are correct. BUt that is a dogbox transmission that your talking about. Our transmissions, you have to select the gears you want and then engage them, when you shift, you engage gears. In a dog box, all gears are always engaged. In a dog box, the gears are straight cut making more noise. Our reverse gear is straight cut and out regular 1-5 or 6 are helical cut gears.
When you double clutch, all your doing is matching the speed of the gears so they align better. if you are moving forward, and want to go into reverse, you dont try to match the speed to go into gear. I only use double clutching when I down shift and even then, you really dont need to do that couse we have syncros. I just started doing it for practice and it turned into a habit.
darksands is offline   Reply With Quote
Old 11-23-2005, 03:01 PM   #14
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
All the gears but the reverse gears are mated and you are sliding synchro hubs to engage gears. Reverse has a idler gear that mates up with the 1st/2nd synchro hub to engage reverse. That hub gear and reverse idle gear are the only ones not always meshed together.
Kevin
Crazykev is offline   Reply With Quote
Old 11-23-2005, 04:18 PM   #15
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
You can't "double clutch" reverse while your moving forward! thats just stupid! its like trying to double clutch 1st while your rolling backwards, your making the gears go the opposite way you want them to even faster
ElmnTfrliF is offline   Reply With Quote
Old 11-24-2005, 02:48 PM   #16
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Unfortunately, this isn't exactly correct.
Dog transmissions and synchro transmissions are very similar except in how they actually select the gear.
With a dogbox, you directly engage the shift collar to the gear. With a synchro, there is a brass ring that aids the shift collar into gear. Of course, this is an extremely simple explanation of how a synchro works.
Reverse is the ONLY gear in our transmission that isn't always engaged. With Reverse, you are actually sliding an idler gear between the first/second shift collar, and the reverse gear machined on the input shaft. It IS synchronized, and it DOES often grind when the idler is unable to slide between the collar and the input shaft.
To prevent this, simply shift into 4th (or any other gear, obviously not 5th), and then into reverse. This will stop the internals of the transmission from moving, and make it easier.
Revmatching doesn't really work, because the input shaft and the output shaft counter-rotate. Blipping the throttle while in neutral will spin up the input shaft, making it even LESS likely for it to engage into reverse. You need to STOP the input shaft in order for the idler to slide into place.
Phil
Andrewtech Automotive
AndrewtechAutomotive is online now   Reply With Quote
Old 11-24-2005, 03:10 PM   #17
jtmcinder
Member#: 80430
1997 Eagle Talon
(plus a Legacy beater)
You are way too polite. - Jtoby
jtmcinder is offline   Reply With Quote
Old 11-25-2005, 08:28 AM   #18
Dave_Clark
Member#: 1015
Actually, in your transmission reverse IS one of them. Synchronized, that is. Sort of...
Dave_Clark is offline   Reply With Quote
Old 11-25-2005, 12:37 PM   #19
REX8
Member#: 24038
+100. You made the problem worse with the throttle blip. You send them spinning in oposite directions instead of together...
Old 11-25-2005, 12:44 PM   #20
XenoWolf
Member#: 64029
Sun Bleach Red
I realized that approximately .05 seconds after I tried it.
I'm not looking for a lecture (I read up alot on transmissions lately so I know why it won't work), I was just curious as to how many newbies tried it too.
So who else has a transmission cooler? ws6fiero Legacy Forum 7 04-11-2004 08:05 PM
So who else has Monday (16th) off? Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 27 02-13-2004 08:42 PM
So who else has Martin Luther King Jr. Day off from work? Stroke Off-Topic 53 01-18-2004 09:11 PM
So who else has paint missing on their door handles? Hank3 Interior & Exterior Modification 3 09-10-2003 10:41 AM
So who else has school starting up agian? motorcitywrx Mid West Subaru Owners Club Forum -- MWSOC 18 08-26-2003 02:55 AM
