Old 11-23-2005, 02:44 AM   #1
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Default Turbo 2.5 Forgetting anything?
Ok so my friend has a 2.5 Rs that he put together from a few different cars.
97 2.5L Dohc block and heads
newer pistons from a Sohc block
This makes a slightly higher CR than stock correct?
ANy way he is going to turbo it over the weekend. We are using the front exhaust components, crossmember and turbo from a 93 Legacy turbo, which he plans only to push between 6-8psi
He is installing "7 range" Ngk plugs, a walbro fuel pump and has done the parrallel fuel mod. ON top of the he has added an FMU (fuel management unit thingy)
Besides the obvious engine management that he doesnt have yet, what else is he forgetting? I told him he will need to pull timing a bit with something, but the car is running on a 1.8L ecu which hopefully doesnt have as agressive of timing as the 1.5 ecu would (correct me If i am at all wrong here).
What else would you all reccomend? How much timing are you pulling from your rs-t setups? I am interested for my own swap which would probably be similar. Thanks, hopefully this car lasts more than a week
bmxpunk is offline   Reply With Quote
Old 11-23-2005, 03:38 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Well, common timing pulling for non turbo ecu's for what I have read is a timing degree for every pound of boost.
Old 11-23-2005, 03:44 AM   #3
bmxpunk
Member#: 89599
1995 almost 22B:)
red
OH CRAP!!!!!! maybe I will try that. did you pull any timing on your projects, mr devil? if so how?
Old 11-23-2005, 04:03 AM   #4
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Well you might want to go a little safer than that... and you might not have to?
Get a good knock sensor, and good EM and a cheap labtop and some software, go out and run it at 5-6psi in third/fourth gear and if you hear it knock pull some timing, rinse wash and repeat til it doesn't knock. Mabe go 2-3 degrees more after that "edge" so your not living live too close to the "edge".
Sko is offline   Reply With Quote
Old 11-23-2005, 08:30 AM   #5
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
ok this is what else he will need a water pump off a turbo legacy or wrx cause factory one will not make it around the exhaust manifold. then you will need injectors cause if u max out the stock ones they might be not enuff. also i agree on em. if u go with emanage (speaking from my car project) you keep the timning belt at the same as factory set but the emanage allows u to reatard timing as needed also he would not need a fmu if he gets bigger injectors, fpr off a wrx/sti or u could crush ur facotry one that should be more then enuff fuel to the engine. how are u getting oil and coolant to the turbo? have u tapped the return line to the oil pan for the turbo? A/f guage ?
-matt
GotTurbo is offline   Reply With Quote
comparison between 2.5 and turbo 2.5 Steroid500 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-17-2003 10:00 PM
STi 2.5 Vrs Forester Turbo 2.5 Questions Guyver STi Forum Archive 16 06-25-2003 04:15 PM
turbo 2.5 rs scoobyimpreza Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-22-2001 03:56 AM
Optimum diameter for non-turbo 2.5 exhaust ivbdn Normally Aspirated Powertrain 5 03-30-2001 12:00 AM
Recommendations for muffler for turbo 2.5 Impreza (mine).... Digital_Boy Normally Aspirated Powertrain 12 02-01-2001 10:58 PM
