Old 09-04-2001, 06:03 PM   #1
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Default O2 sensor problem w/S-AFC and A/F ratio gauge
First off it is a 0V-1.0V O2 sensor. The motor is an EJ22T running on a 1.8L ECU w/idle control valve as the only error given by the ECU. I just put in an S-AFC and a A/F ratio gauge but both are not working correctly.
Would the error confuse the s-afc/gauge?
What's up with it?
Thanks Alan
Scoobyslack1 is offline   Reply With Quote
Old 09-04-2001, 10:06 PM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
I don't see how the S-AFC and A/F gauge should not work. Are you certain that they are hooked up to the O2 sensor signal? Is there otherwise voltage on that wire? What ECU wiring diagram did you use?
The idle control valve code may indicate that you forgot to connect that connector, or if you obtained a complete EJ22T motor, that the idle control valve is different (or wired differently) on that engine? But it shouldn't bother the O2 sensor signal.
-WaC
Wayne
wac is offline   Reply With Quote
Old 09-05-2001, 08:03 AM   #3
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Make sure that you have proper ground. It's very important (maybe that's obvious) and will cause problems, especially with the oxygen sensor.
Steve
SteveS is offline   Reply With Quote
Old 09-05-2001, 08:30 AM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
The idle control valve error is due to the 1.8L sensor getting info from a 2.2L turbo motor, different perameters, hence the error.
The O2 sensor is from the 1.8L motor so the ECU will not have a problem with it. The A/F ratio guage is indeed wired straight into the O2 sensor. The only thing about the O2 sensor is that it has 2 white and 2 black wires...
I'm not sure how the installer picked one wire and not the other, but his skills (not mine) or lack there of is another story .
My next step now is to use a volt meter to check the voltage from the O2 sensor.
Old 09-05-2001, 01:34 PM   #5
HRE | giulio
Member#: 481
This is what i had to do...
disconnect the a/f meter, so only the safc is reading off the o2 wire (at the ECU).
warm up the car (and with it the o2 sensor)- after a few mins you should have 'normal' readings again. Drive it around and see if you do.
If so, then you can disconnect the SAFC from the o2 wire and plug in the A/F meter's wire instead- don't use the o2 from the sensor, use the one at the ECU as you did with the SAFC.
I think when you hook up both and/or a bad ground, the o2 sensor doesnt heat up properly. Resulting in 1/10 the reading that it should.
Good luck,
g
HRE | giulio is offline   Reply With Quote
Old 09-05-2001, 02:04 PM   #6
Scoobyslack1
Member#: 2780
junk yards rule!
The S-AFC is hooked into the ECU and the A/F meter is on the O2 sensor.
Other O2 sensors I've seen have only 3 wires mine has 4, anyone know why or what they're for?
Now that I have the munual for the S-AFC I can try to work w/it.
Old 09-05-2001, 03:38 PM   #7
HRE | giulio
Member#: 481
if you look more toward the o2 sensor, you will see 3 wires. 4 is on the clip to the car.
just use the ones at the ECU and you'll be fine.
EJ20G O2 sensor problems and part number rob Subaru Conversions 4 04-23-2012 05:39 PM
Need help FAST o2 sensor problem and due for insp! fenix_black Normally Aspirated Powertrain 19 05-06-2008 08:30 AM
THERE IS A RECALL FOR MY00 RS FOR O2 SENSOR PROBLEM CALL YOUR DEALER CHACHI Normally Aspirated Powertrain 12 04-07-2001 03:07 PM
o2 sensor problems, lean A/F mixture. Help me! Quart2000 Normally Aspirated Powertrain 0 02-07-2001 07:29 PM
O2 sensor problems ac_gohan Bay Area Impreza Club Forum -- BAIC 0 01-23-2001 01:47 AM
