Old 11-23-2005, 09:31 AM   #1
mrtrex
Member#: 12223
2005 WRX
Default Using Turbo XS ABC to Run More Boost With Cobb AP??
Will this work? We could only get 15.5 psi out of the stock system on stage 2. We adjusted the wastegate. We got the boost higher but in 5th gear I would get boost fluttering. Or should I just use a boost controller?
mrtrex is offline   Reply With Quote
Old 11-23-2005, 11:05 AM   #2
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
No idea on this one although the ABC should be able to help with a few extra PSI. You will need more fuel to handle the boost and keep your AFR's ok. I have no idea whether you AP can keep up with the larger change in boost.
Might be good to get some kind of control of the situation.
J
crystalhelix is offline   Reply With Quote
Old 11-23-2005, 11:07 AM   #3
fat angel
Member#: 81630
i talked to trey at cobb about this awhile ago. he said you could do it as long as you dont go anove the recomended boost.
fat angel is offline   Reply With Quote
Old 11-23-2005, 07:46 PM   #4
mrtrex
Member#: 12223
2005 WRX
bump up
Old 11-23-2005, 08:52 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
the ABC sucks...just replace the stock BCS w/ a GM one or a Perrin....then get a COBB Protune/Streetune....
testes1010 is offline   Reply With Quote
Old 11-23-2005, 08:54 PM   #6
mrtrex
Member#: 12223
2005 WRX
I have one of those sitting here as well the GM. Why do you say the abc sucks?
Old 11-23-2005, 08:57 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
The ABC is an effective way of bleeding off air. Use it if you want.
cdvma is offline   Reply With Quote
Old 11-23-2005, 09:00 PM   #8
testes1010
Member#: 47145
2012 Gas Saver
since replacing the stock BCS & ABC w/ the GM BCS, my boost does not fluctuate w/ temperature....during winter it was always a constant battle w/ the ABC & the boost map to keep from overboosting...now I have had no issues... ...rocksteady boost...
DO I have to run stage 2 with the Cobb ap? Corpuz04 AccessPort 9 03-05-2010 11:41 AM
Boost Spiking Using After Changing Maps with Cobb AP (kind of long) Gray_Scale AccessPort 2 07-03-2006 01:08 PM
How much boost with cobb ap stg2 sti? boostinscooby AccessPort 3 02-10-2006 03:53 PM
FS: Turbo XS ABC (adjustable boost controller) bren wrx Private 'For Sale' Classifieds 2 12-20-2005 05:11 PM
FS: Turbo XS ABC (auxilary boost controller) Pedestrian Private 'For Sale' Classifieds 4 11-25-2004 12:47 PM
