Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 11-29-2005, 10:36 PM   #26
Allied Armament
Member#: 87757
1986 GL 4x4 wagon
Its okay to have skepticism, I will just deal with carpal tunnel I am receiving from answering it when I am 60. JJ. Anyways, your correct the 03 would be 4" and the 04 would be 2.5" (but they would still sit at the same overall height and would both be able to fit 29's), for which you do not want to go any higher without extreme modification, thats why we limit our lifts to 4". After 4" inches you are dealing with a number of issues, length of brake lines, electrical lines, shifter etc.... The lift we will be a direct bolt on you should have no problems whatsoever, all parts are made on a jig, and are strut extensions are lazer cut to profile, we have only made one mistake on a lift and that was we added supports in the wrong place and the owner couldn't do the install, but the problem was fixed an wa la. We have built lifts for this chassis before so there shouldn't be any new suprises, although you turbo model guys may want to keep an eye on all of the turbo plumming. Almost all of our customers install their own lifts, most of them do it over the weekend in the garage, but my recommendation would be to let a shop install it. If you don't have an hydraulic lift and a plethora of jacks its just plainly put "unsafe."
Allied Armament is offline   Reply With Quote
Old 11-30-2005, 12:24 AM   #27
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I would agree that it either helps to have alot of friends and jacks and stuff, or a good shop. Lifting my brat took about 3 people and 4 jackstands and 2 jacks to make sure everything was straight and level to bolt on right.
Flowmastered87GL is offline   Reply With Quote
Old 11-30-2005, 11:08 AM   #28
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
awesome, i cant wait, let me know when the special will run so that i can get a lift, i spoke to the girl and she gave me a green flag.
also sense the baja has 17" rims on it what size tires do you reccomend?
jnorth85 is offline   Reply With Quote
Old 11-30-2005, 01:22 PM   #29
Allied Armament
Member#: 87757
1986 GL 4x4 wagon
Well when ever your ready to commit well get this ball rolling, we'll need funds up front to process the order. Hopefully, we can get a couple people in on the buy that way were not just making one or two.
As for tires go "BIG" 29s are my favorite, but if you want you can run 28-27's.
Give us a call if your ready to pay:
(503) 543-5154
Most likely Albie will answer and you will have to tell him your information, or we can accept paypal (although there is a 3% surcharge).
Good going with the significant other
Old 11-30-2005, 02:17 PM   #30
jnorth85
Member#: 76785
SRP
(503) 543-5154
ok i will see what i can do,
also when you say 29's what is the width of the tire?
Old 11-30-2005, 04:23 PM   #31
Allied Armament
Member#: 87757
1986 GL 4x4 wagon
9.5" inch width.
Old 11-30-2005, 04:31 PM   #32
jnorth85
Member#: 76785
SRP
so a 29x9.5x16?
ill have to look up pricing on these.
thanks!
Old 11-30-2005, 06:37 PM   #33
iON Performance Inc
Vendor
Member#: 7673
FYI - We make lifting springs for the Baja, Outback and Forester as well
iON Performance Inc is offline   Reply With Quote
Old 11-30-2005, 09:44 PM   #34
jnorth85
Member#: 76785
SRP
lifting springs, along with the lift kit? how much lift would that give me
also i searched tire rack for 29x9.5x16 with no luck, i have also heard that with the auto trans you cant go more than 3% over stock does anyone have any idea what size that is?
Old 11-30-2005, 10:48 PM   #35
Allied Armament
Member#: 87757
1986 GL 4x4 wagon
From what I have seen springs can net you close to an extra 2" inches, so the accumalation of both will get you around 6" inches of lift. Now your beginning to talk 3-4 inches shy of humvee clearance . As for the 3% they are talking about difference in tire size, all four tires must be the same size or it will create binding 3% is the allowable amount of difference. It has nothing to do with oversize tires (correct me if im wrong).
Old 12-01-2005, 09:18 AM   #36
pgv
Member#: 73808
2003 Baja
I have been told three percent too. I wanted to just get a set of 70's for my auto baja and the guy at Tires Plus said that was too big. He said the transmission would not be able to handle it.
THere is a lot of conflicting info out there. I wish I knew the answer. If you can't go bigger than that, there is not really alot of sense to getting a four inch lift.
But, I want a lift AND the tires to make it worth doing!
pgv is offline   Reply With Quote
Old 12-01-2005, 09:47 AM   #37
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
You can run ANY tires as long as they are the same size. your will run in to a problem with your speedo and milage as they will be off but the problem with stock is the size of the wheel well.
holland_patrick is offline   Reply With Quote
Old 12-01-2005, 09:55 AM   #38
jnorth85
Member#: 76785
SRP
ahh ok, well speedo and stuff i can figure out later on.
so with tires if i want to fit 29's on there what is a size to purchase i searched tire rack for the 29x9.5x16 and nothing came up any ideas?
Old 12-01-2005, 11:58 AM   #39
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
try some 235/70-16's ! i like bridgestone dueler a/t 's (based on reviews and ratings)
cliffhanger is offline   Reply With Quote
Old 12-01-2005, 12:19 PM   #40
jnorth85
Member#: 76785
SRP
^^ thoes are great tires ive had them before, thank you.
for allied, i have to wait until after the holidays (gifts/travel) has me a little low on funds, but as soon as they are done im placing that order for the lift, i also contacted ION about thoes springs so hopefully i can get both rolling.
thanks guys!
after researching tires i think im going to end up going with a 235/70/16 Bridgestone Dueler A/T Revo they are 118.00 per tire from Tire rack
Old 12-01-2005, 04:56 PM   #41
cliffhanger
Member#: 80446
2005 5spd Baja-T
allied, i want your lift real bad too (at the aforementioned price) but the holiday crunch is here and i cannot afford until after christmas/new year's ... any chance we can do the deal afterwards? and ion - tell me a little more about your springs you've got...
Old 12-02-2005, 12:30 AM   #42
Allied Armament
Member#: 87757
1986 GL 4x4 wagon
Actually now that I think about it we can do in January, because like you said "ITS CRUNCH TIME," and we are selling stuff like crazy, so that would be a good way to keep things flowing after christmas. How about the end of January?
Old 12-02-2005, 08:18 AM   #43
pgv
Member#: 73808
2003 Baja
I might have some money by the end of January. My birthday is Feb, so maybe I will be a birthday present to myself!
Old 12-02-2005, 09:13 AM   #44
jnorth85
Member#: 76785
SRP
the end of jan works for me quite well!
Old 12-02-2005, 05:13 PM   #45
cliffhanger
Member#: 80446
2005 5spd Baja-T
sounds good
Old 12-02-2005, 08:17 PM   #46
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Income Tax time means cash back just in time for the lift kit.
ajabobrut is offline   Reply With Quote
Old 12-03-2005, 02:26 AM   #47
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
this is the wrong thread i know, but i have a quick question for allied. is there a kit for the wrx? i saw on the site that you added impreza to your list on the EJ kit.
distorto is offline   Reply With Quote
Old 12-04-2005, 12:46 PM   #48
jnorth85
Member#: 76785
SRP
i cant wait to get this lift.
Old 12-04-2005, 02:57 PM   #49
Allied Armament
Member#: 87757
1986 GL 4x4 wagon
We can build one for the imprezza.
Old 12-05-2005, 08:52 AM   #50
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I wish I wasnt in NJ! But maybe after the holidays I'll see if someone around my 'hood can install this.
Samirr76 is offline   Reply With Quote
\"What/'s with the apostrophe\'s and slashe\'s and stuff?\" Cosworth Off-Topic 5 03-21-2008 09:00 PM
Any E.E.'s or M.E.'s or ppl interested in MagLev out there? sherifx Southern California Impreza Club Forum -- SCIC 16 07-12-2004 11:12 PM
Scorpion Lift springs/Whiteline anticastor lift kit install blaznc Brakes, Steering & Suspension 0 01-14-2004 05:17 PM
was that lift, turn,break, or turn, lift, throttle?????? joe z New England Impreza Club Forum -- NESIC 26 02-20-2001 06:30 AM
turbo ?'s, oil ?'s, trans. ?'s, etc... the spacecowboy Technical Forum Archive 4 08-08-2000 07:28 PM
