Old 11-23-2005, 04:16 PM   #1
sb427f-car
Member#: 93766
2005 Busted WRX
Thanks to being rearended
Default Fram Part No. for 05 motor?
So, I've joined the dark(er) side of things and just recently got an 05 WRX (well really recently) and it's time for its first oil change. Anyways...the computer @ the parts store (and the Fram website) list the same filter. PH9715 is the 2005 filter listed and it was a little thing, like the size of a garden tractor filter. The 2004 model listed in the book and on the computer (parts store and fram site) is a PH3593A which looks to be about the same size as my old 2000 malibu's filter. So the question is, which one is right? Did Subaru make an oil filter change in 2005, or is someone's database incorrect? My money's on the db, but just wanted to double check. Thanks guys.
sb427f-car is offline   Reply With Quote
Old 11-23-2005, 04:22 PM   #2
battousai
Member#: 44977
2015 Mustang GT
Don't buy a Fram filter .
Get a Purolator or something.
battousai is offline   Reply With Quote
Old 11-23-2005, 04:23 PM   #3
sb427f-car
Member#: 93766
2005 Busted WRX
Thanks for answering my question...perhaps you can now answer the question why?
Old 11-23-2005, 04:28 PM   #4
Hzracing
Member#: 77294
2005 WRX Wagon
Fram filters suck
the smaller one is the correct filter, just dont get fram
read this thread
http://forums.nasioc.com/forums/showthread.php?t=434057
This is why fram filters suck(disregard the Honda part, there filters are all the same)
http://effinmotorworks.com/Filters.htm
Scroll down to the pictures at the bottom, the fram uses cardboard backing were the better filter manufactures use metal. That cardboard can break apart and get into the oil system.
Hzracing is offline   Reply With Quote
Old 11-23-2005, 04:30 PM   #5
sb427f-car
Member#: 93766
2005 Busted WRX
Originally Posted by Hzracing
Fram filters suck
So there was a change between the years on filter sizes? Ok, that's what I needed to know.
Already getting hated on about my filter choice...interesting.
Old 11-23-2005, 04:33 PM   #6
hondaeater69
Member#: 60324
IIRC subaru themselves have changed filters a couple times due to QC, but aftermarket filters should have the same number. I know from previous experience the PH3593A was the filter i used on my 2.5 Legacy when i racked up about 150K miles on her, not so sure it should be the same filter used on a turbo 2.0 Ltr.
Changing the filter and oil at proper internvals is 1000X more important than the name brand on it.
Old 11-23-2005, 04:34 PM   #7
sb427f-car
Member#: 93766
2005 Busted WRX
Couldn't agree more with that statement. Thanks for the info.
Old 11-23-2005, 04:38 PM   #8
Hzracing
Member#: 77294
2005 WRX Wagon
check this link as to why fram sucks
Old 11-23-2005, 04:44 PM   #9
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
I've used Fram's without incident quite a bit with my old 95 L but I recently switched back to OEM(when I got my WRX) when I read about the crappy filter media and lack of pleats and anti-drainback valve.
<----takes no chances with his EJ20
Acostafan is offline   Reply With Quote
Old 11-23-2005, 04:59 PM   #10
hondaeater69
Member#: 60324
yea, i've yet to see the thread titled "my wrx engine blew up because i didn't use the super specialz OEM filter!!", and we never will.
Old 11-23-2005, 05:14 PM   #11
Jasper
Member#: 80136
2006 Ford F-150
ehh. OEM is just as cheap as Purolator and whatnot for me. i think i paid JUST over $6 a piece at the dealership. picked up 6 of them. already used 3. gave me free crush gaskets too.
Jasper is offline   Reply With Quote
Old 11-23-2005, 07:27 PM   #12
Senorpablo
Member#: 71328
2005 WRX Sedan
It's the: PH3593A
The new books/computer's are wrong. I've done 8 oil changes with that part number. The older books had the correct listing.
I love the black grippy stuff Fram uses.
If this is your first oil change after the factory installed the filter, you may be in for a shock. My factory filter was on rediculously tight. The filter ended up tearing and crushing before it came loose.
Senorpablo is offline   Reply With Quote
Old 11-23-2005, 08:30 PM   #13
testes1010
Member#: 47145
2012 Gas Saver
Originally Posted by Senorpablo
It's the: PH3593A
^ correct part number, I've been using Fram filters since the car was new(Dec '02), it now has almost 75k miles on it, at STG4+ levels(zero problems), & yes I've heard/read all the reviews on Fram filters....the deal is, as stated above, as long as you change your oil & filter regularly(3k mile intervals) you should have no issues w/ the cheap Fram filter...
testes1010 is offline   Reply With Quote
Old 11-23-2005, 08:32 PM   #14
hondaeater69
Member#: 60324
wow, that means it's the same filter as used on the older (my 98) 2.5 leggies. I wonder how many models that filter spans. ..
Old 11-23-2005, 08:53 PM   #15
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I have used fram in the past without incident, but not on my WRX - or even my old Corolla... while there have certainly been no engine failures blamed on the filter, I think the cardboard and glue construction of the Fram is just not a good idea...
Here's a link to some pics comparing the OEM (an 080, I think) to the Fram filter (lots of other comparisons on that site if you look around)
http://www.bescaredracing.com/sti/oi...em_vs_fram_tg/
Old 11-23-2005, 09:11 PM   #16
prometheum
Member#: 92003
04 bicycle!
so their crap filters why would you buy a crappy filter or your car when you can get a purolator or napa gold filter for not much more?
so if you're gonna put quality oil in your car and want to maintain it correctly why put a filter made of cardboard and glue in there? it defeats the purpose
prometheum is offline   Reply With Quote
Old 11-23-2005, 10:27 PM   #17
sb427f-car
Member#: 93766
2005 Busted WRX
It's the: PH3593A
Thanks for the ref number, looks like I'm good to go. I'll continue reading about these Fram filter issues. I appreciate those that clued me in with a genuine reason behind their statements.
Old 11-23-2005, 11:12 PM   #18
quazimoto
Member#: 70395
You might want to check on what the bypass rating is for the Fram.That is most critical as the Subaru oem (made by Purolator) is set at around 20psi and most others are using 8-11psi.
quazimoto is offline   Reply With Quote
Old 11-23-2005, 11:17 PM   #19
sb427f-car
Member#: 93766
2005 Busted WRX
That's good info, thanks, I'll look into it.
MY99: New MAF part no. for recall? TwoPointFive Normally Aspirated Powertrain 3 07-29-2002 08:52 PM
K&N panel filter Part No. for MY99 RS? (for stock airbox) RallyOttawa Normally Aspirated Powertrain 6 04-05-2002 07:47 AM
Part no. for sway bar mounts? dead-eye Brakes, Steering & Suspension 10 01-18-2002 11:27 PM
Part No. for stock exhaust flange springs Fred Zaplitny Normally Aspirated Powertrain 8 01-25-2001 09:35 PM
Part no. for K&N filter for Legacy GT? gtguy Legacy Forum 17 01-15-2001 09:54 AM
