Old 11-23-2005, 06:12 PM   #1
FourStar
Member#: 87042
Default Cel P0038 won't go away
i got this cel so i bought a new rear oxygen sensor and installed it. i didn't have a chance to erase the code until today (its been about two weeks since i switched it out) and i can erase the code but as soon as i start driving it comes back up. i scanned it and it still says the problem is with the rear oxygen sensor. what is going on???
FourStar is offline   Reply With Quote
Old 11-23-2005, 07:29 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Go under there and inspect the wiring to the sensor carefully. It may have been damaged at some point by something contacting the underbody (any off-roading?).
Old 11-24-2005, 03:26 PM   #3
FourStar
Member#: 87042
on the oxygen sensor i replaced the wiring didn't look good but when i installed this one everything looke good.
no off roading
Old 11-24-2005, 03:40 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Did you check the harness that it plugs into?
Another possibility is that the ECU was damaged by whatever happened to the original sensor, hopefully that is not the case.
Old 11-25-2005, 02:59 AM   #5
FourStar
Member#: 87042
ill check out the harness again as soon as i get a chance. is there a way to scan the ecu to see if its damaged? wouldn't that flash a cel? thanks for you help
Old 11-25-2005, 07:55 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well you're already getting a CEL right? I don't know of any way to specifically test the ECU other than swapping in another one and seeing if the problem goes away.
Old 11-26-2005, 07:29 PM   #7
FourStar
Member#: 87042
alright im going to see what i can do.
yeah i have a cel but what i meant is wouldn't there be a specific code for the ecu being messed up?
Cylinder Misfire, CEL won't go away persian prince Newbies & FAQs 6 07-11-2007 06:50 PM
Rear O2 CEL won't go away... UncleMeat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 04-25-2005 05:04 AM
CEL won't go away! pls. help! AK_2002_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-23-2001 03:35 AM
('93-'01) Cylinder #1 misfire won't go away Piusma Impreza Forum 1 06-30-2001 12:37 AM
check engine light won't go away spgavin Normally Aspirated Powertrain 4 06-07-2001 08:46 AM
