Old 11-24-2005, 07:33 PM   #1
V8killah91
Member#: 101299
2004 Subaru STi
Default UTEC Check Engine Light
Hi everyone,
I'm in the process of purchasing a 2004 STI with the all of the modifications required for the UTEC on the car to be set at stage 2. When I was taken for a drive in it, he explained that the check engine light comes on when the UTEC is enabled, but when reverted to the stock ECU configuration, it turns off. I've searched the internet and haven't found anyone else with this problem. I've seen some articles stating that the check engine light will blink when the UTEC detects knock, but nothing like my situation. Anyone know what may be causing this?
Mod list on the car:
UTEC Stage 2
TurboXS Turboback Exhaust
TurboXS Blow Off Valve
TurboXS Manual Boost Controller
Injen CAI
Thanks,
Scott
V8killah91 is offline   Reply With Quote
Old 11-24-2005, 08:14 PM   #2
BigBoosting
Member#: 48553
your car has thrown a code
utec does not turn on the check engine light
the onl thing utec does with the light is blink it when it detects knock
get the codes pulled from the ecua nd see what they say
BigBoosting is offline   Reply With Quote
Old 11-24-2005, 08:20 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
OBDII scanner and see what's what.......post the code....as in "Pxxxx" and that will tell us what to tell you
Old 11-24-2005, 09:02 PM   #4
V8killah91
Member#: 101299
2004 Subaru STi
Hi,
Thanks for the replies. The thing I don't understand though is that the check light is off when the stock ECU is connected. If the "check engine" light were on the time then I would attribute it to the car throwing a code. Any other ideas?
Thanks,
Scott
Old 11-24-2005, 09:33 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
are the dip swithes in the correct position?
testes1010 is offline   Reply With Quote
Old 11-24-2005, 09:36 PM   #6
V8killah91
Member#: 101299
2004 Subaru STi
To tell you the truth, I don't even know what those are. Based on what he said, he had it tuned by a local Subaru tuning shop. So I at least know it was "probably" tuned correctly. I guess I'll just have to give him a call and see what he says.
thanks,
Scott
Old 11-26-2005, 09:42 PM   #7
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
the utec can disable the cel light. so if he just drives and ignores the cruise light, that could be what he was talking about.
either you misunderstood him or he is trying to feed you a line of nonsense.
go get the codes pulled, report back.
also, if the cel is off, and the car idles like crap, ask him why he reset the ecu.
DISCOPOPE is offline   Reply With Quote
Old 11-27-2005, 06:19 PM   #8
V8killah91
Member#: 101299
2004 Subaru STi
Hi,
Thanks for the reply.
I'll probably be picking the car up this week. To clarify, when he took me for a test drive, the light was off when he had the UTEC turned off. As soon as he turned it on, the CEL light turned solid, at which point he explained to me what was going on. The car idled fine and was fast as hell If this sheds light on anything, I'd appreciate any input. I'm getting kind of scared that there may be something wrong, but so far there doesn't seem to be anything other than the light. After I get it, I guess I can go get a diagnostic done at Autozone.
Thanks,
Scott
Old 11-27-2005, 06:28 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by V8killah91
Hi,
Thanks,
Scott
...something is WRONG with that.....shouldn't DO that.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
check engine light comes on and i have utec family wRXagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-28-2009 01:38 AM
UTEC Check Engine Light Paintballguy Mid Atlantic Impreza Club -- MAIC 6 06-22-2005 12:32 PM
does utec block check engine lights gsteclipse33 Engine Management & Tuning 5 01-12-2005 12:18 PM
wierd utec prob.. check engine light on when i disabled it topgrinder Engine Management & Tuning 2 03-14-2003 04:51 AM
