Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 11-24-2005, 10:31 PM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Default RS-T: 0-60 Video
http://media.putfile.com/ImprezaSixty/320
Thought I would share. The 2nd-3rd shift seems to be adding about .6 seconds to the time. Still though, seems slow. Is this about the same as everyone else on 6-7psi?
The cars been running filthy rich for almost two years now on a base map. I'm getting 14 mpg on friendly, non-jerkoff city driving. I think it's time to hit the dyno.
-Brett
ExecNav is offline   Reply With Quote
Old 11-24-2005, 10:40 PM   #2
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
BTW: I realize a 0-60 time hardly means jack. It's just all I have until I can finally afford to have it tuned.
-Brett
Old 11-24-2005, 10:56 PM   #3
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
a working gearbox is worth more then that extra .6
Car sounds great. Im sure you dyno somewhere around what a stock wrx makes. Maybe a few ponies more. Although, your advantage is that dam lowend torque!
Very nice though. How much work was involved in getting that FMIC to fit well?
DoctorNick is offline   Reply With Quote
Old 11-24-2005, 11:20 PM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
A whole lot!!1 Had to hack a ton off the front bumper cover along the bottom to keep it from bulging out. The fender lining was almost completely cut out to accommodate the driver-side charge pipe. I actually tossed a few of the pipes that came with the kit and rearranged them. The turbo-intercooler pipe runs over the top of the motor rather than underneath it like the directions say. It's a couple less bends and clamps. It also looks better in my opinion. Only major problem was the pipe that connects to the inlet of the intercooler on the driver side. It doesn't fit AT ALL. There's about a 160 degree U-bend in the pipe that's supposed to run through a slot in the chassis, normally on the WRX. That slot is too far aft on the GC and I need to get that pipe custom made. In the second pic, you can see how the pipe hangs down. Luckily, it's high enough to not scrape.
-Brett
Old 11-25-2005, 12:11 AM   #5
shemoves
Member#: 80663
2005 STi
that front mount looks slick
shemoves is offline   Reply With Quote
Old 11-25-2005, 12:12 AM   #6
deathinacan
Member#: 76826
2013 delorean
P.I.T.A. to clean silver
zero to sixty twin scroll style on my sti - with a bad clutch... check it out
http://www.freewebtown.com/deathinacan66/kory.MOV
- i'll get an updated movie as soon as i get some dry road this next week - just installed my exedy stage III clutch and its grippy as hell!
exedy stage III ...heaven at my feet...
deathinacan is offline   Reply With Quote
Old 11-25-2005, 12:29 AM   #7
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
aftermarket turbo forum?
2.5 Blue Roo is online now   Reply With Quote
Old 11-25-2005, 01:44 AM   #8
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default My input...
I have a black turbo 2.5RS as well
My 0 - 60:
You should get a G-Tech or similar device to measure your times; it helps a lot with tuning. I'm still running a TMIC though... Couldn't afford a FMIC so I tell myself that there is less lag to justify using a smaller intercooler
Nice car; sounds great!
powerlabs is offline   Reply With Quote
Old 11-25-2005, 02:30 AM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
nice very nice!
Kawikid20o2 is offline   Reply With Quote
Old 11-25-2005, 02:48 AM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
One of these days I will get a vid of my accelleration. I'm good for the 0-60' time, ie the 330' times, but after that I peter out a bit.
But from my 1/8 mile time and speed, I get a calculated best of about 5.8 for my 060 mph time. Pretty respectable. Although I suspect it is a little slower in reality, probably a tad over 6 seconds.
Old 11-25-2005, 10:44 AM   #11
powerlabs
Member#: 45790
SUPERCHARGED
Good part of the reason I can get such a quick 0 - 60 is that my 8000RPM redline allows me to only have to shift once.
Old 11-27-2005, 03:33 AM   #12
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I decreased my timing retard across the entire map and took a datalog in E-Manage tonight doing the 0-60. I noticed that as I'm accelerating through each gear, the relative pressure in the manifold is decreasing slightly. Is that normal?
Also, given that 60mph/3rd gear is exactly 4980 rpm, this data is indicating that the car did the 0-60 in 4.4 (1) seconds. The clutch was engaged at 2.6 seconds and 4980 rpm occurs at 7 seconds into the datalog. It would be nice if the time lapse rate was accurate but with GReddy, who knows.
-Brett
goQuality STI @ 30psi goes 0-60 in 3 secs, 0-120 in 10.26 secs. VIDEO 13rus Alaskan Impreza Club Forum -- AKIC 12 08-18-2008 01:10 PM
0-30, 0-60, 1/4 mi, 50-70, skidpad, 60-0... blah blah blah... snvin Off-Topic 40 09-11-2007 01:49 PM
Car-Videos.com estimates '04 STi 0-60@4.59s!? Janq STi Forum Archive 9 02-28-2003 04:14 AM
('93-'01) What do you think 2002 2.5 RS auto 0-60 times would be? driver Impreza Forum 6 04-28-2001 12:20 AM
gt wagon 0-60 times vs rs sedan 0-60 times iceman Legacy Forum 0 11-11-2000 08:48 PM
