Old 11-24-2005, 06:02 PM   #1
awd4ever
Member#: 31573
I found the
meaning of life!
Default Why Upgrade Water pump on Supercharged 2.5 rs? (5psi)
Car: 98 rs 5.5 psi supercharger.
Hello, i've been reading about various projects, and even though most of them deal with Turbo applications, boost is boost.
I saw a number of people suggesting upgrading a water pump on NA rs's to a Legacy or a WRX one.
My question is why?
Thank you
Alex-
awd4ever is offline   Reply With Quote
Old 11-24-2005, 06:14 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I've never heard of having to replace the water pump, but I have heard of upgrading to a bigger radiator. Especially if it was going to be a track car.
My guess would be that the WRX or legacy water pumps flow more. 5 psi of boost isn't that much and I don't you'd need up upgrade the water pump unless you were tracking the car. But in that case i still think the water pump is big enough.
As i said i've only heard of replacing the radiator if it was a track car. Thats just my .02
Master2192 is offline   Reply With Quote
Old 11-24-2005, 08:32 PM   #3
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
A quick look through my parts lists yielded the following:
Code:
Impreza	DOHC	98	21111AA007
Impreza	SOHC	99-01	21111AA007
Impreza	SOHC	02+	21111AA007
Impreza	2.0	02+	21111AA026
Legacy	To 	2-97	21111AA007
Legacy	From 	3-97	21111AA110
So, it does look like the 97+ legacy 2.5 and the 02+ WRX had different pumps, as to what the difference is I have no idea.
Dan Cech is offline   Reply With Quote
Old 11-24-2005, 08:44 PM   #4
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
the reason people se a wrx/ turbo legacy waterpump is when they turbo their car using wrx headers, they use the pump because the NA waterpump goes out straight down, interfering with the headers (it wont fit) the turbo waterpump goes out sideways, allowing space for the headers to pass under. iirc the thermostats are the same, its just the direction of the output of the waterpump
2.5 Blue Roo is offline   Reply With Quote
Old 11-24-2005, 08:58 PM   #5
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
You are correct sir.
Drac9 is offline   Reply With Quote
Old 11-24-2005, 09:07 PM   #6
awd4ever
Member#: 31573
I found the
meaning of life!
Wow, thank you!
Old 11-26-2005, 10:03 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yes the impellers look almost identical in size as well
White 2.5rs is offline   Reply With Quote
06 Supercharged 2.5 RS bwrex General Community 7 04-24-2009 07:29 PM
will 2.0 water pump, belts fit 2.5 block?? Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-01-2006 12:58 AM
TESTING WATERS - Subaru Impreza 2001 2.5 RS *WITH WARRANTY* sebtarta Private Vehicle 'For Sale' Classifieds 7 08-14-2005 12:17 AM
2 or 4 tire replacement on 2000 2.5 RS zakats Tire & Wheel 10 07-17-2005 08:00 PM
