Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 11-25-2005, 01:21 AM   #1
e8w117
Member#: 64678
04 Grocery Getter
Jvaa Baclk
Default Bad window seal in freezing weather???
well, since our weather has been BELOW freezing, has anyone had condensation build-up on the INSIDE of the car? in my wagon, the rear windows have moisture on the inside. is there a fix for a tighter seal?
e8w117 is offline   Reply With Quote
Old 11-25-2005, 01:27 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
nope...run your a/c to help dry out the cabin
Old 11-25-2005, 01:47 AM   #3
Lexington
Member#: 50221
I'm on internets
Racin on ur bandwidth!
on this same topic... anybody experience small "air gaps" during cold weather...??
My cabin has little to no air noise, but when its really cold out.. there is a constant "window or door open" noise
Lexington is offline   Reply With Quote
Old 11-25-2005, 08:06 AM   #4
Scooby Coupe
Member#: 2746
2002 WRX Sedan
Blasť Yellow
Lightbulb
make sure that you don't have the hvac set to recirculate
(the a/c compressor probably won't run below freezing)
winter sux
Dave Wood
Scooby Coupe is offline   Reply With Quote
Old 11-25-2005, 10:48 AM   #5
peterex
Member#: 27021
2015 WRX
Yes. I have a small wind noise coming from the driver side window when it is cold outside. If I lower the window ever so slightly and then close it, the problem goes away. I never really thought to bring it to the dealer as it only happens when it is really cold (like last night!). Our frameless window design might have something to do with such problems.
peterex is offline   Reply With Quote
Old 11-25-2005, 12:21 PM   #6
squagle
Member#: 93426
2016 STI Limited
Dark Gray Metallic
i got a couple more rattles when it turned cold--but no leakly seals so far.
squagle is offline   Reply With Quote
Old 11-25-2005, 03:15 PM   #7
Charge
Member#: 3313
My 01 2.5RS developed this problem. I bought my car in late Dec. of 00. Two months later, I had this issue. It really got bad when I washed the car and had water leaking inside(albeit in very small amounts). It ended up being a huge inconvenience as my dealership botched the job to fix it. First they just wanted to "fill it" in with that black gorilla snot stuff. That didn't work. Then they ordered a replacement seal for the whole driver's side, which took about two weeks to come in. Then when they did install it...the first time I rolled the window down and back up...gorilla snot all over the window. Took it back, they supposedly fixed it...exact same problem when I rolled the window down and back up.
It was eventually fixed...and I blame the dealership for the issues, not Subaru. If I were you, though...I'd ask that they agree to replace the whole seal initially if it is under warranty. Also, check the window's up/down function before leaving the lot. Unfortunately...I couldn't pick my car up until after 6:00pm when I had my problems, and I was working a M-F 9-5 job then. The local dealerships here all only are open 9-5, M-F for service...so I never got to talk to anyone in person and always had to leave the car again(with no loaners...until the last time when I almost exploded on a salesman).
Charge is offline   Reply With Quote
VF39 BAD SEALS? What are the reccuring effects of bad seals in a turbo? Drewbaru04 North West Impreza Club Forum -- NWIC 2 05-16-2009 11:50 PM
battery in freezing weather, how long before I pull it Sir Punk Electrical & Lighting 10 11-14-2008 11:19 AM
Best oil for freezing weather? wrxrex Service & Maintenance 5 12-04-2006 07:41 AM
2 bad crank seals in 2 weeks? RUN Normally Aspirated Powertrain 12 10-05-2004 04:41 PM
