Old 11-25-2005, 03:20 PM   #1
thsiao
Member#: 72260
2006 Cayenne
Question Anyone know how thin brake pads have to be before dealer is forced to change...
Anyone know how thin brake pads have to be before dealer is forced to change the brake pads under warranty? I think the stupid lady at the Monrovia Subaru told me it had to be 2mm or something... anyone know? I think I need my pads replaced at my next visit and would like to rebuttle if she's being stupid like she always is. And if you're wondering why I go to them if they suck... its because they're close and its just a minor maintenance... for more important maintenance I go to Long Beach. Thanks.
thsiao is offline   Reply With Quote
Old 11-25-2005, 03:30 PM   #2
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
A dealer is ever "forced" to replace brake pads under warranty? IMO pads are never covered unless there is something very obviously wrong on a very new car.
LordBass is offline   Reply With Quote
Old 11-25-2005, 03:32 PM   #3
solbey11
Member#: 89234
I know Subaru recommends replacing them with 2/32 of an inch left. Also to pass a PA state inspection they have to be over 2/32 or they fail. So they are probably right.
solbey11 is offline   Reply With Quote
Old 11-25-2005, 03:34 PM   #4
solbey11
Member#: 89234
My mom took her WRX to the dealership due to a brake pulsation and they turned the rotors and replaced the pads under warranty. Her car had around 30k on it. I don't remember what the readings were on the pads, but they replaced them under warranty.
Old 11-25-2005, 06:50 PM   #5
leecea
Member#: 37359
2003 WRX
The Suby warranty is unusual in that it does cover pads, but they do have to be down to the wear limit as others have said. At 30K I felt that mine needed changing but the dealer wouldn't do it because they had a bit too much pad left. I figured I'd rather pay the money myself for the peace of mind.
leecea is offline   Reply With Quote
Old 11-25-2005, 06:59 PM   #6
thsiao
Member#: 72260
2006 Cayenne
So 2/32 of an inch is what I need to have them replaced?
Old 11-25-2005, 09:07 PM   #7
legacy2005
Member#: 94720
2005 Legacy GT 5EAT
Silver AP
its usually between 2-3 /32 that they get replaced, sometimes earlier if you go in for a pulsation. if you really want the pad replaced and still have quite a bit of pad left you can take them out and sand them down so that you are "under spec" next time you go in.
legacy2005 is offline   Reply With Quote
Old 11-28-2005, 11:21 AM   #8
WilkinsSubaru
Vendor
Member#: 43552
:o) Need Parts Now?
Brakes are covered under 3/36 bumper to bumper. I am not sure of the exact specs but most dealers should replace if it gets close.
Thanks,
Jackie
WilkinsSubaru is offline   Reply With Quote
Old 11-29-2005, 08:02 PM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
IIRC, the minimum spec is 1.2mm, which is pretty darn thin.
Samurai Jack is offline   Reply With Quote
Old 11-29-2005, 08:39 PM   #10
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
mine were at the indicators - however much pad that is - and they replaced them under warranty.
Old 12-01-2005, 08:21 PM   #11
Samurai Jack
Member#: 21145
2002 Enemy of Aku
New pads = 10mm. The indicators are set at about 1/2 that, so 5 mm. This gives you a fair amount of time to get them replaced w/out putting yourself in a bad spot.
Who wants to listen to all the grinding noise anyway? It's nasty to get you to change them.
Old 12-05-2005, 09:44 PM   #12
kendogg41
Member#: 90822
1995 LS Swapped Volv
Nope, incorrect. I work at a dealership, and have done these under wanretnee before. Subaru will not cover unless pads are down to either the wear indicator (of which there is only 1 wear indicator per axle, it's normally the inner pad on the pass. side), or a pad that doesn't have a wear indicator has to be I metal to metal. They will turns rotors with a pulsation at any time under 3 year/36, but will still use whatever pads you have as long as they aer still decent.
kendogg41 is offline   Reply With Quote
Old 12-05-2005, 11:14 PM   #13
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
No - the indicators are at 1.5mm - so pretty thin (you still have plenty of time to change them out, though, for normal driving)
Old 12-06-2005, 12:07 AM   #14
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
There is usually 2 in the front. 1 in the rear pads, on passenger side.
-paK +1
Pakin is offline   Reply With Quote
Old 12-07-2005, 07:27 PM   #15
Samurai Jack
Member#: 21145
2002 Enemy of Aku
So I guess you went backed and checked?
Not disagreeing with what you found but I just recently changed mine out and the indicators on the new Hawk pads were at 5mm. I adjusted to something more reasonable.
Nope, incorrect. I work at a dealership, and ...
If you are going to say something is incorrect, that's fine, but at least state what you believe is incorrect. Your post concerned warranty coverage and mine said nothing about warranty coverage.
Makes it easier to reply back to your post, like, "Gee, I didn't know that" or whatever is appropriate.
Old 12-07-2005, 08:15 PM   #16
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Yup.
Old 12-07-2005, 10:59 PM   #17
kdogae86
Member#: 99139
02 wrx
bluey
im surprised your dealerships arnt willing to be happy to change pads, mechanics get paid to do work and usually brake jobs pay real well. we charge 1 hour per axle, 2 if you include rotors.
does anyone know the price difference between turning rotors and buying new ones. rotors are usually cheap enough that it doesnt make sense to cut down a rotor even more.
kdogae86 is offline   Reply With Quote
Old 12-07-2005, 11:11 PM   #18
legacy2005
Member#: 94720
2005 Legacy GT 5EAT
Silver AP
lol. turning rotors is usually a lot cheaper then buying new ones. where i work its 1.8 for turning rotors. but for new rotors/pads its 1.5(pads/rotors) or 1.0 (rotors) and the price of rotors. $110.00 each. so total it comes to $295.00. where as just turning its $135.00.
the reason dealerships dont want to change the pads is cus if they say they are worn out before the warranty is up the dealership/soa has to pay for it. and dealerships get in trouble if they do a lot of warranty work. each dealership usually has a warranty "budget" and anything over that they get audited by the district/regional managers. and in the end the managers make the dealerships internal some of the work.
so in laymans terms:
a lot of warranty work = bad for dealerships
Old 12-09-2005, 09:10 PM   #19
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Yup.
Gee, I didn't know that.
Seriously, I could have sworn I had seen it in the manual as 1.2mm, but thanks for clearing that up, for me at least.
Old 12-10-2005, 04:05 PM   #20
kendogg41
Member#: 90822
Sorry about that. I meant A: Pad wear indicatrors were not at 5mm, and that warrentee will not cover them untill they are basically 100% worthless.
Old 12-11-2005, 01:55 PM   #21
T-boner
Member#: 57608
All your boost are
belong to us! Mwahahahaaa
Maybe you won't have to worry about it much longer! My front pads were worn, but not yet to the wear indicators. Then one morning I heard what sounded like rivets on rotor when I hit the binders.
The dealer replaced my front pads and rotors under warranty (they didn't mention anything about having to do that at 18K miles). Talking to the service advisor, I found that sometimes these pads will shatter and that's what happened to me.
T-boner is offline   Reply With Quote
So how big do they have to be before... in your country? redwagon Off-Topic 16 06-27-2008 01:52 PM
Anyone know how to change C to F? ruckussnamedchuckuss Electrical & Lighting 3 10-22-2005 01:24 AM
How sick do you have to be before you skip work mordy_2v Off-Topic 29 03-23-2005 08:11 AM
does anyone know how to set the valves once u change them White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 31 02-26-2004 01:01 PM
How many have to die before it is enough? Hiroki Tada Political Playground 114 11-07-2003 01:14 PM
