Old 11-25-2005, 06:21 PM   #1
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
Default FP Green fitment problem on 2.5block
I have a 2.5 built block but im still using wrx heads. i have this in my 02 wrx. ij ust picked up a fp green with the upppipe with tial 38 mm wastegate. i went to put it on today and the green was hitting my tranny case and wasnt letting the uppipe and headers meet. there was about a inch gap. has anyone else had this problem? i have the jdm 6 speed in there. the turbo came off a 02 wrx with my same mods but i assume he was using the stock 5 speed and didnt have the problem i had. what has everyone done about this or should it fit with no grinding of the tranny case? thanks for any help
tyler
gotawd is offline   Reply With Quote
Old 11-26-2005, 11:20 AM   #2
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
anyone??
Old 11-26-2005, 12:04 PM   #3
cronic
Member#: 9749
What green is this, and what external gate set-up? Who did you buy it from?
cronic is offline   Reply With Quote
Old 11-26-2005, 12:17 PM   #4
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
need a diffferent uppipe
02WRX2.5 is offline   Reply With Quote
Old 11-26-2005, 01:10 PM   #5
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
it has a flex uppipe with a tial 38mm wastegate welded on. im prettty sure its the Ultimate racing one but im not sure. ill find out from the guy i bought it from. i bought it from subiedoo504. he said he had it on his setup so i just curious what i cna do to make it fit.
Old 11-26-2005, 01:13 PM   #6
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
well i looked on the UR page and there isnt flex so im not sure. i just emailed the guy to find out. the green uses the stock size inlet and is just oil cooled to give more info on the turbo
Old 11-26-2005, 01:42 PM   #7
cronic
Member#: 9749
Yea that is not the Ur uppipe. I asked which green because it sounded like my old set-up which i sold to a member on here. It was the old style green with larger compressor cover, and 8cm turbine, with UR uppipe, and tial. Get out the grinder!
Old 11-26-2005, 01:58 PM   #8
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
is that who you sold it to? yea this one is a flex pipe. is that pretty much my only option is to grind down the corner of the tranny case?? would it be the easiest to just take out the transmission bolt and grind the corner down then put a few tack weld where the bolt should be just for added strength? i think ill have to grind down to much to leave the bolt in. but you had this same problem?
Old 11-27-2005, 07:29 PM   #9
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
anyone else have a fitmentproblem with the fp green???
Old 11-27-2005, 11:05 PM   #10
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
nope, no problems on my car with standard inlet green, SZ49, or 3" inlet Green.
SSFWRX is offline   Reply With Quote
Old 11-27-2005, 11:10 PM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm assuming he was on the 5speed and had the uppipe/wastegate set up fabricated?...
was it a kit made for the WRX with the 5 speed tranny?...
if the tranny is the problem I'd be more than happy to trade
Homemade WRX is online now   Reply With Quote
Old 11-28-2005, 12:25 AM   #12
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
haha....yea that must be the problem. im goin to try my PDE uppipe that i had on there and see if it actually fits and if it does then ill just have the external gate welded on the PDE. im not tryin to grind down my tranny case.
fp green overboost problem [email protected] Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-27-2009 08:35 PM
Fp Green fitment issue nova7176 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 04-22-2009 01:50 PM
FP Green, SZ 49, Blouch 2.5 R on Stock internals k22addict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 02-21-2009 12:21 PM
fp green fit problem avatar71 Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-26-2006 06:20 PM
FP Green Spool up on 2.0L WhiteKnight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-18-2004 04:19 PM
