Old 11-26-2005, 11:29 AM   #1
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
Subaru Stars My car starts 50% of the time. Odd symptoms
What happens : Turn the key either strong start or just a click. When it clicks, and Click and click; anywhere from 20 times to 2 and then it will start up no problem.
Whats going on with the car:
The fans on the Heat/Ac is on will usally prevent it from starting. Usally. I have a TT but its never on. I have an amp but it shuts off. I have An viper alarm but ive not armed it over night and issues still there.
What the temp: It's usaly cold out. I can go for 2 hour drive shut the car off to get gas. And bamb it wont start.
My Tire guys things its because i have decent size keychain. and that the weight of the keys killer the cylinder that prevents it from starting.
Hopefully a Guru might have an idea.
No mods were done to my car .. This just happend on its own.
Could this be the starter? Alternater?
I am open to ideas.
Thanks
Chuck
[email protected]
Chandy70 AIM
Chandy69 is offline   Reply With Quote
Old 11-26-2005, 11:34 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Moved to the proper forum.
Get the battery tested, alternator too. If the battery is original it's probably weak no matter what.
Check the battery terminal connections for corrosion, including inside where they contact the posts. If they are loose or corroded inside it can cause these symptoms. The posts and terminals should be clean, shiny and tightly clamped together. Coat the terminals with a light layer of grease to prevent future corrosion.
Check all the grounds as well, look at the frame and engine ground connections and clean those up if necessary.
Yes it could be the ignition switch but I'd check the other things first.
Old 11-26-2005, 11:38 AM   #3
ivwarrior
Member#: 100610
MBP
Sounds like a starter solenoid going bad. If it is, it's a pretty easy fix. Starter comes out fairly easy, take solenoid apart and replace the 2 contacts inside, and clean the plunger up so it gets good contact.
Some will say to just replace the starter, as it will come with the solenoid, but in my experience with reman starters for Subarus you're more likely to get a junk one than a good one. Replacing the contacts is MUCH cheaper, easy, and most likely all that's wrong with yours.
ivwarrior is offline   Reply With Quote
Old 11-26-2005, 11:47 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If having stuff turned on in the car prevents it from starting, it's not the solenoid.
The proper way to check this is with a voltmeter at the solenoid terminals, when the problem is occurring. If the contacts are bad there will be good voltage on one side and low or no voltage on the other.
Also if it's a battery/voltage drop problem the lights will dim while the attempt to start is made.
Old 11-26-2005, 12:51 PM   #5
ivwarrior
Member#: 100610
MBP
True. I musta missed that spot about fans on. I saw about the amp and other stuff being off and still having the problem.......
Old 11-26-2005, 01:30 PM   #6
Chandy69
Member#: 16087
02 WRX
Thanks for the move.
Mulder thanks for your help your a true Guru.
Happy Thanksgiving.
I'll check the connections.
I have an Optima battery Orange top.
Chuck
My Car when I had the time to treat her right??!!! Kastley85891 Rocky Mountains Impreza Club Forum -- RMIC 18 03-17-2008 05:07 AM
Most of the times it starts and once in a while it doesn’t start cbrkp Service & Maintenance 5 02-18-2007 08:58 PM
Past two nights someone has tried to steal my car, a total of 3 times. rites Texas Impreza Club Forum -- TXIC 24 07-22-2005 05:54 AM
75% of the time i start the rs, it backfires through the manifold White 2.5rs Engine Management & Tuning 11 11-18-2004 12:10 AM
lol my car topic contribution of the day IgotWRXed Off-Topic 22 08-04-2003 09:54 PM
