Old 11-26-2005, 04:24 PM   #1
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
Default 2.5rs block
Hey I have a 98 Subi 2.5 rs. The motor is pretty much built, but how much power can the block take?
PSI87 is offline   Reply With Quote
Old 11-26-2005, 05:46 PM   #2
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
hummm... more info?
NeaD is offline   Reply With Quote
Old 11-26-2005, 10:50 PM   #3
tony_subaru
Member#: 22742
As in built, different pistons, rods?
tony_subaru is offline   Reply With Quote
Old 11-27-2005, 12:08 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
since every "built" motor is the same and "pretty much" means the same thing for every situation...id say if you use more than 1 psi'z of b00st but less than 50, youre in the danger zone
Old 11-27-2005, 12:21 AM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
he is obviously running 87psi, DUH. Which by reverse calculating the tensile stress on the cylinder walls divided by the universal constant of alex's man package=blown motor.
in all seriousness though we need more info, do you just mean the block itself, you will not blow out a cylinder wall before you blow a rod or ring or piston IMO.
Ben
Old 11-27-2005, 12:54 AM   #6
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
Well, I know the motor has JE pistons. Either stock rods or slightly larger. I was just curious about the block its self.
Old 11-27-2005, 02:23 AM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
The block is usually not the problem - the rods, the rings or the gasket would have given up first. So from that I would say 7psi on stock fuel
kgb is offline   Reply With Quote
Old 11-27-2005, 03:25 AM   #8
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
we just put 96lbs injectors in and it has 2 fuel pumps. This thing should be able to take whatever I throw at it. The blockwas my only concern, that and the tranny but thats anouther story.
Old 11-27-2005, 03:40 AM   #9
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
What do you plan on throwing at it with two fuel pumps and injectors that weigh more than my dog?
-Brett
ExecNav is offline   Reply With Quote
Old 11-27-2005, 03:50 AM   #10
bugeyes
Member#: 64494
2001 V7 sti
Here in Australia we dont get a 2.5sti so if we want turbo 2.5 we have to use the non turbo 2.5L block like you are talking about.
Anyone that uses these blocks has to strengthen the top of the cylinders to stop them from moving. There are variations in what can be done. Some convert them to fully closed deck and some fit dowels between the bores and the outer case.
Without strengthening the block you will suffer from leaking cylinders. It wont go boom or crack but you'll have trouble sealing the cylinders.
But after thats done there are guys here running sub 11s 1/4 miles without a problem so the block is capable of good hp.
As for an exact hp number or boost number that the standard block starts to leak its hard to say as it can depend on your tune and timing.
bugeyes is offline   Reply With Quote
Old 11-27-2005, 11:28 AM   #11
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
-Brett
I bought the car with the 2 pumps and 75lb injectors. The injectors went out and I just replaced them with 96. Id like to get 500awhp out of my current setup, but im not sure thats possible.
Old 11-27-2005, 02:57 PM   #12
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Ok, first, figure out the CR of the pistons.
Random guessing leads me to 8.5:1. Now, since it's a 98 and has headgasket problems anyway, make sure you do as the aussie told you. Also, what turbo setup are you using? intercooler? etc.
WE NEED MORE INFORMATION!!!!
tooocool49723 is offline   Reply With Quote
Old 11-27-2005, 05:00 PM   #13
Brady
Member#: 14838
2005 LGT--Garnet Red
197 Iggpoints
OK, so based on the knowlege that you bought the car used, and based on what you've said was done to the car, we can assume there is a good chance it could have been a former member of this board who owned the car previously. If so, do you know who?
Regardless, one doesn't just replace the internals with JE forged pistons without doing other work to the car. So, do you mind telling us what else you KNOW has been done to the car? Is it already running a turbo (I would hope if the previous owner bothered to drop JE pistons in it). What is the new CR? Is the stroke still the same? Was the block strengthened and/or converted to a closed deck or semi-closed deck?
What IS done, and what do you PLAN to do?
This will help immensely.
Brady is offline   Reply With Quote
Old 11-28-2005, 12:54 AM   #14
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
Oh how I wish i could tell you. Im not sure whats done. I dont think the previous owner knew either. His name is Henry Cox. He didnt do the work, but I have all the recipets. Unfortunantly the recepts dont go into enough detail about this. What I know is it has 8.5:1 pistons and orginal rods .25mm over size. Other than that, I really dont know about the motor itself. It has a large bar fin FMIC and a t3/t4 turbo. The turbo is probably blown, its quite laggy. I intend on replacing it with a 3071. It has a tec3r standalone and various other components you would find in a typical turbo 2.5rs. This guy got pretty serious about the car. All the recepts add up to around 50k. It has little things like a oil cooler kit, racing radiator and aluminum skidplates. That sort of thing gives me a little more confidence about the motor being done right. I hope so at least.
Old 11-28-2005, 01:01 AM   #15
PHATsuby
Member#: 13617
2001 Legacy GT back
you didnt get this from colorado did you?
Ben
Old 11-28-2005, 01:06 AM   #16
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
If it's got 8.5:1 pistons in it, then put on your knock sensor and start at 10 pounds of boost and take her up in 2 lb incramintes in 3rd or 4th until she knocks, retard some timing, see how it does.
Anyways, basically tune it and find out.
I suppose 250+ at the wheels, 500whp sounds ridicoulus, but if you dont care about the longevity of your setup its probably possible with a garret 35r turbo or something.
Sko is offline   Reply With Quote
Old 11-28-2005, 01:12 AM   #17
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
+1 for 500whp with GT35R
Old 11-28-2005, 01:16 AM   #18
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
A customer of Rallitek just rebuilt his 2.5 RS block with STI internals and turbo setup. We will see how it goes.....
Old 11-28-2005, 02:38 AM   #19
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
it already dynoed a lil over 300awhp @ 14psi and its at 19 now.
Old 11-28-2005, 10:13 AM   #20
Sko
Member#: 90396
2005 Legacy 2.5i
any knock or bad signs at either psi?
Old 11-28-2005, 02:45 PM   #21
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
it did act up a little at 19psi. Let me rephrase that. I was racing, and everything was perfect, until 100mph, a lil more than halfway through 4th gear, then it made a odd noise and stopped pulling as hard as it should. Im hoping it may have just been spark blowout.
Old 11-28-2005, 02:56 PM   #22
PHATsuby
Member#: 13617
2001 Legacy GT back
let me guess, you have had it tuned for 14psi, and you turned it up to 19psi.
Ben
Old 11-28-2005, 07:05 PM   #23
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
i was told its a boost dependent map. It actually has better air fuels at 19.
Old 11-28-2005, 10:05 PM   #24
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
W0Wz4Z!?!
2.5rs block w/ STI internals??? ONE_1 Built Motor Discussion 2 12-15-2009 12:20 PM
New 2.5rs block (with 11.2:1 pistons) and new heads! AWDrifterz Normally Aspirated Powertrain 8 09-23-2008 09:28 PM
WTB: short block to replace 98 2.5RS block austenf740 TXIC Private Classifieds 3 02-14-2007 02:59 AM
99 SOHC 2.5RS block in need of rebuild ituner Private 'For Sale' Classifieds 0 07-24-2004 10:49 PM
wtb: 2.5RS block or complete engine specificcivic Private 'Wanted' Classifieds 7 01-24-2004 12:54 PM
