Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-26-2005, 07:25 PM   #1
hermit
Member#: 26886
2004 WRX
Platinum Silver Metallic
Default few cel codes
I just got some cel codes(pulled them with accessport) then googled them.
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1095 Tumble generator valve circuit #1 (over current)
I was just wondering what exactly's wrong and how serious it is...can i just reset the ecu and see what happens?
04 wrx...just stage 1 AP
thanks
hermit is offline   Reply With Quote
Old 11-27-2005, 09:53 AM   #2
04URABUS
Member#: 100566
05 STi
WRB/Silver
I had a long battle with TGV codes. After quite some time, i determined that
all of my problems were related to the installation of my up pipe. There is
the tgv angle sensor right behind the turbo, that i guess i smacked with my up
pipe. I would suggest taking a good look at that sensor and make sure it doesn't
have even the smallest scrape. If it does replace it. It will be the exact same
part number as your TPS.
04URABUS is offline   Reply With Quote
Old 11-28-2005, 01:18 PM   #3
hermit
Member#: 26886
2004 WRX
the cel's went off by themselves...should i still take the car to get looked at?
thanks for the reply
edit: the car seems fine...it seemed fine when the cel was on...doesn't sound/smell/perform any different
Old 11-28-2005, 02:34 PM   #4
phantom338
Member#: 57277
i had p1095 a few days ago. Car ran terribly. Couldnt accelerate, but it went away a few restarts later, and everytihng was back to normal. Strange.
phantom338 is offline   Reply With Quote
Had CEL code P0021, a few questions about it Teksi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-24-2013 06:31 PM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 10:43 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 02:40 AM
ECU needs to be re-programmed- a few questions about my CEL codes Slvrblt New England Impreza Club Forum -- NESIC 6 04-26-2003 04:12 AM
