Old 11-26-2005, 07:37 PM   #1
imprezasti88
Member#: 31474
2003 Forester
2007 Frontier SE
Default How to: clean nasty/pitted fog/headlamp lenses
Posted this on i-club/scoobymods but here it is again:
Story Time
My car ('03 Forester 2.5x) has had a tough life. It spent it's first 45k in Wyoming, communiting from Chayenne to Laramie (~50mi each way with NASTY roads) 5 days a week. Then, I bought it and life has not gotten much easier, with now nearly 20k worth of mountain driving and sand to pummel it's front end. Needless to say, the headlamps and foglamps were pretty damn messed up and looked terrible. I saw things such as Meguiars PlastiX but didn't believe it would do anything, so I decided to put together all the things on wet sanding and such into my own meathod.
How to: Clean those nasty fog/headlamp lenses
First, I removed the foglamp assemblies. This was simply to make it easier to get at the strange shaped areas of the lens. Removing the foglamp is pretty easy (Here can be found how-to for the forester).
Before cleaning, after removal:
What you need
1. 400 grit wet/dry sandpaper: If your lenses are only lightly pitted, then skip this and go to 800. However, if yours are deeply pitted like mine were, I would suggest using 400 first.
2. 800 grit wet/dry sandpaper
3. 1000 grit wet/dry sandpaper: maybe a little overkill, but I used it because it came in a set of assorted sandpaper purchased from Autozone.
4. 1500 grit wet/dry sandpaper: Overkill again, but it worked for me
5. 2000 grit wet/dry sandpaper: VERY IMPORTANT! I thought I could get away with just 1500, but I had to go and purchase 2000 to get rid of a lot of the larger scrapes.
6. Turtle wax: Really, any wax or even polish will do, but this is what I had handy.
7. Meguiars Chanuba wax: A harder shell to go on top
8. Some sort of other protectant: I ignored this step as I am installing Rockblockers tommorow, but you need somesort of clear coat to protect the shine.
Optional: Buffer, which I used and helped shine up the lenses.
Directions
1. Clean off the lens thoroughly with Windex or other glass cleaner. I then used rubbing alchohol to get rid of any remaining contaminants.
2. Begin wet sanding with either 400 or 800 grit sandpaper, depending on how deeply pitted your lamps are. For those of you who do not know the process of wet sanding, your goal is to keep the paper and surface wet at all times. This way, all the things you are rubbing off run off instead of sticking to the surface. I had the faucet running lightly the whole time I was doing it and every 15-20sec would put the paper under it and occasionally wash off the lens. You should begin to see the water turn white from the clearcoat/plastic you are rubbing off. Furthermore, your lens should start to look very scratched up from the sandpaper, but don't worry this will go away.
3. Continue process with 800, 1000, and 1500 grit sandpaper spending aroudnd the same amount of time on each grit (~5-7min)
4. Continue same process with 2000 grit, except be VERY thorough this time. I spent 10-15 min per lens at this level to remove the last imperfections. Do not worry if even after this level, it still looks very scratched up as that is how it should.
5. Clean the lens VERY WELL. I used windex, soft scrub, and finally rubbing alchohol to get all the particles off. It should look slightly clearer after this step. If you have a buffer, buff the surface after you clean it.
6. Apply turtle (or other hard-shell) wax. Cover the surface so it is almost entirely covered and let dry COMPLETELY. Wipe clean, and you will see how great your lens is going to look.
7. Apply Meguiars chanuba wax (or other final-step wax) in a similar meathod, and after dry wipe clean. Now you will see how great your new light looks!
8. Buff if you have a buffer to remove any final scratches.
9. Apply protectant or rockblocker. I am not entirely sure this step is neccecary, as other things I have read ignored this step. I'll update after I drive a few days without rockblockers and take the car to the wash once.
Now you have nice, new looking head/foglamp lenses without the $300 price tag. There will still be some of the deep imprefections left, but they will feel smooth to the touch and look much better.
After:
I also did the headlamps, but did them while on the car. The method is the same, just in done while on the car. I protected the bumper with cloth and tape just to make cleanup easier.
Hope this helps!
Cheers
-Jeff
imprezasti88 is offline   Reply With Quote
Old 11-26-2005, 07:54 PM   #2
bitterWRX
Member#: 49624
04 AW WRX
13 SWP STi
Great write up! Now if only I had time haha
bitterWRX is offline   Reply With Quote
Old 11-26-2005, 08:50 PM   #3
Usaf*STi
Member#: 88063
06 STi
Black as night
written very well and very informative. thanks for the info.
Usaf*STi is offline   Reply With Quote
Old 11-26-2005, 11:09 PM   #4
Subaru of Plano
Member#: 52637
Nice job! Between steps 8 and 9 you need to remove every single bit of wax polish etc. Then cover them to save yourself a lot of work down the road!
They are also available in a tough clear version
www.hot-subaru.com
Subaru of Plano is offline   Reply With Quote
Old 11-27-2005, 12:24 AM   #5
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Thanks! And good work, too; those lamps look fantastic!
Cheers
specialev is offline   Reply With Quote
Old 11-27-2005, 02:08 AM   #6
imprezasti88
Member#: 31474
2003 Forester
2007 Frontier SE
www.hot-subaru.com
Just ordered a set though rockblocker: Clear headlamps and yellow fogs.
As far as how long it took: About 2 1/2 hours for two headlamps and two fogs.
Cheers
-Jeff
Old 11-27-2005, 07:00 AM   #7
dr3wby
Member#: 92163
Wow what a difference that made. Good work!
dr3wby is offline   Reply With Quote
Old 12-24-2005, 04:46 PM   #8
njskatchmo
Member#: 94618
2002 Bugeye
I just did this, The headlamps came out smooth yet cloudy. Any ideas.?
njskatchmo is offline   Reply With Quote
Old 12-25-2005, 03:16 AM   #9
precariousbyte
Member#: 101097
2008 WRX
Red means fast
i did this about a month and a half ago.
my initial reaction was "holy four letter word, batman! i can see again!"
precariousbyte is offline   Reply With Quote
Old 12-25-2005, 11:28 AM   #10
njskatchmo
Member#: 94618
2002 Bugeye
I used clear coat over the headlamps. It comes out shiny and smooth. But when the lights are on its a cloudy.
Old 12-25-2005, 11:55 AM   #11
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
After wetsanding, I used some Meguiar's Scratch-X to smooth everything out. Then I cleaned everything off again and clearcoated them.
Did wonders to my 15 y/o headlights.
IronMonkeyL255 is offline   Reply With Quote
Old 12-25-2005, 02:15 PM   #12
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Next time put some 3M clear bra on 'em!
How-to: Cleaning ABS Speed Sensors sagelwwa Brakes, Steering & Suspension 15 01-04-2016 09:17 PM
How To: Fogs/Driving Lights With High Beams jdubya301 Electrical & Lighting 5 03-17-2010 08:13 AM
HOW-TO: Parking light switch rewired as auxillary/secondary fog light switch relliMmoT Electrical & Lighting 6 11-17-2009 07:40 PM
. How i clean 2006 Impreza Fog light glass ( from inside ) ?! any help!! ahmad7610 Electrical & Lighting 5 04-22-2009 04:50 PM
How To: Remove eyelids/clean headlights SacksLax Interior & Exterior Modification 6 02-08-2009 02:38 AM
